Mike, is that true for same fsb and ram frequency? ;) Or I'm I missing something? I think he's making a performance argument.
mikeyakame/Cryptik:
Thanks for the long post on the last page. I haven't posted here for quite some time...
It appears that my mainboard hasn't read your posting yet, since my system would only get stable setting all references to 0.69 +-0.2.
Any larger difference in any of those references leads to calculation errors in IBT. If my memories don't fail me, keeping the difference 0.04 between adress and data did not even work on default clocks.
Here a quick summary of my current settings:
CPU: Q9550 E0
FSB clock: 460 MHz (465 and more will cause hangs and BSODs)
FSB term V.: 1.36V
NB Volt: 1.40V
CPU PLL Volt: 1.56V
CPU clock: 3910 MHz
CPU GTL 0/2: 0.69x
CPU GTL 1/3: 0.69x
NB GTL: 0.69x
CPU and NB skew do nothing for me, they only cause instabilities (BSODs, system hang) if not set to AUTO. More than 200 ps even keeps the system from posting.
Does that make any sense in relation to your last post on why ASUS is keeping that 0.04 difference?
omg this is very helpful thanks for the information i hope i will setup the right values
Big Thanks to Cryptik for starting this thread & Mike for his detailed analysis :up: (had to read some of it twice!! ... uh well maybe three times!!;)) I've had a ton of fun with my RE & E8600 but was rather dissappointed that I couldn't reach the magical 600fsb that I had seen posted all over this and other sites, AUTO settings at that!! I'd gazed at this thread a few times and then it a fit of desperation @ 4 in the morning decided it was time to play with the GTL's. Well, booted in 2nd try @ 9 x 600 PL 8 after doing the math!!:D Didn't think it was necessary with the E8600, thought I would read the thread when I put my quad in but WOW!! Been busy the last few days and had problems getting into Xtremesystems for the last week but now that I'm back on just had to say a BIG THANKS.. I'm sure this will really benefit me when I go for the QX9650!! Here is where I finished off the other night....
Holy crap 1.72V, Phase? ^^
I'm afraid I'm going to have to bump my earlier question seeing as I'm afraid it fell behind :/
Originally Posted by BUMP
Sorry haven't been in here in awhile. That description of the 0.63x data and 0.667x address makes perfect sense, however does the same situation exist when you factor in increased vcore and very large FSB/clock frequency increases? Is the data bus as resistant to ringback and is the address bus as resistant to jitter under the completely different circumstances created by overclocking? I found with my system that the data bus is the most sensitive, perhaps the ringback starts to needs compensating for at higher BUS/clock speeds, and responds to (is stabilized by) increased Vref much more than the address bus, which can almost be left at 0.667x with a slightly raised Vtt even up to ~534 FSB.
I have not had much luck setting the vRef for the data bus the same as the NB Vref. My boards NB default multi is 0.640x whilst the default data bus multi is 0.635x. To be completely stable, my NB GTL Ref is -40mv, and the data bus GTL Ref is +60mv, my NB will not tolerate 0.64x + GTL Refs and the cpu will not tolerate less than 0.635x on the data bus when at high speeds (4GHz+). This may be a function of the changes occurring due to overclocking and the requirements of both the CPU and NB under these conditions. It seems at least with my system, that at elevated speeds the NB and CPU need to be tuned separately to maintain valid data transfer between source and destination.
The use of clock skews is imperative to achieve stability, especially it seems with quads. However each system appears to exhibit unique behaviour, some preferring a delay of 100 - 200ps on the NB with the cpu left at normal, and others prefer a 100 - 200ps delay on the CPU with the NB left at normal. This may be either due to the CPU used, or variations in components on the board, or other factors. To a very limited extent you can overpower the need for NB skews with increased NB voltage but in a lot of cases a decrease in NB voltage can be achieved with correctly set NB skew.
500 FSB on a quad is not something we see often, perhaps as much due to people not wanting to push the chip that hard as opposed to the same speed achievable on a higher multi as a lack of boards to support it. The only quads ive seen doing 500 FSB with reasonable volts are the occasional 65nm and the occasional low VID 9650 on a suitable P45. The A3 revision P45 chipset seems much more capable in terms of quad overclocking, and although only possessing a 6 phase analogue PWM, the Gigabyte UD3P is handling them very well, with 4500 MHz and 500 FSB 24/7 stable able to be achieved. The Max II Formula, which has the same 16 phase PWM as the Rampage Extreme, seems to be able to handle it too but not many of the guys with one have chips that are 500 FSB capable at volts they are comfortable using. Also the M2F seems quite capable at 4500 MHz on duals, with no CPU/NB clock skewing or ram skewing necessary for complete stability. Choice of board is very important when intending to push the limits of your hardware.
There's no hard and fast rule to this, You can feel free to experiment with every combination of the GTL Refs. For example I set +20mv for all my GTL Refs the other night doing some testing, you are not going to hurt anything unless you have a very high Vtt and the Vref goes over 1.10v.
You can try for example, +50/+10/+50/+10 or +50/+20+/+50/+20 or +50/auto/+50/auto or +40/-5/+40/-5 would give you your ~46mv difference if you find that to work better.
The default multipliers for GTL Refs 0/2 are 0.635x and the default multiplier for GTL Refs 1/3 are 0.667x, so to get the same Vref when multiplied by the Vtt you need different modifiers for 0/2 and 1/3, ie: 50/10/50/10.
I guess the way to tune GTL Refs differes person to person. To roughly tune them, I prefer to make sure ram/NB is stable, manually set Vtt, and, using a vcore that is slightly too low for the given speed, use either orthos small FFT or Intel Burn Test to see what GTL Refs give me the longest fail time or least errors, respectively. You must be certain the rest of your system is stable though or you will be wasting your time. You can also somewhat fine tune the GTL's by also examining the Gflops output with IBT, they should be very similar to each other, and correct adjustment of the GTL's can achieve this.
You're not the only person with a 9550 that requires high GTL's. Just use whatever works for you best, GTL settings dont port over from other peoples systems. You may need more Vtt, vcore, vPLL etc as GTL's can't make up for a lack of vcore etc.
Cheers I'm glad this thread has turned out to be useful. Mikey's fantastic explanations have also been a very valuable contribution.
That's a great result, congratulations! Glad this thread helped, and yes dual cores are also effected by GTL's not just quads. Any particular reason why you are buying a QX9650? From what I've seen from other peoples results the Q9650 E0's clock much better than the QX chips, and the RE seems to be able to handle 470 - 480 FSB so 4.23 GHz should be achievable on much lower vcore than on a QX with your RE.
Clock jitter gets worse with increased frequencies and voltages. Not much you can do about it really besides make compensation adjustments. Each board and its components will vary the effects of it as nothing is perfect, traces, capacitors, resistors, chips, everything has a part in it. Gigabyte UD3 from my understanding behaves so nicely mostly due to the increased thickness of copper between PCB layers which helps to minimize trace leak and interference. Probably why it can get away with a smaller VRM and be more consistent. All that Asus have done with adding more phases to VR is offset against the trace losses and interference that the PCB design incurs, and jitter produced when driving the clocks internally as phase timing for Vcc gets gradually worse and more inconsistent.
I understand that's the case anyhow, though GB's approach of shielding from signal interference and minimizing transit loss over traces is the correct way to handle the problem. What Asus does by improving VR capacity and output stability by adding more phases to the design is no different than a PSU manufacturer like ThermalTake who jacks up Rail Current Output and keeps introducing models with more and more W to sidestep electrical design flaws and weaknesses instead of releasing a unit that is much more efficient and can do the same job with 500W less capacity. Sidestepping a problem only makes it happen later on, handling it and managing it correctly is difficult and costly, but eventually it saves more than it costs. Problem is with Asus method is that all they are doing is band-aiding the CPU, while other devices on the board still have same poor behaviour that only gets worse and eventually cripple the system before the potential of the 16-phase VR can be reached. Designs like this aren't meant for everyday at high frequency, only stable benchmarking. Gigabytes designs are meant for everyday stability, I applaud that and wish Asus would take a leaf from their book. No point being able to run 600mhz fsb if my sound card is so crackly I can't hear the actual audio, or my HD speeds are so abismal that it's faster reading and writing off floppy drives, OR my NIC drops out so frequently I might as well switch to wireless. heh.
And for your entertainment, heres a HD Tune screenshot taken of my 4x320gb Raid 0 running off ICH9R on my Rampage Formula at 476Mhz FSB.
It looks more like a seismograph's output during an Earthquake :rofl: Asus should be proud of their engineering brilliance, turning my raid array into what appears to be an earthquake :D
That's a good point about the added copper layers in the Gigabyte boards, I wasn't aware they reduced trace leakage and cross talk/signal interference. Hopefully other manufacturers follow suit. I was saying to someone about a week ago how I didn't think the 16 phase PWM on Asus boards was the bottleneck with their performance, and that other components/design limitations were what was the limiting factor. Under load with quads though the UD3P's are emitting a high pitch squealing which indicates things are getting towards the limits of the design, and when you consider the amount of current a quad at 4 GHz+ is pulling and the fact it has only 6 phase then its no wonder. There's one guy running 4.4GHz 24/7 on a 9650 so if he keeps that up it should be a good test of the boards longevity under that kind of pressure.
The M2F seems to be a bit hit and miss, some guys (like me thankfully) got solid boards that are predictable and perform well, other guys seem to luck out, one thing ive noticed is no two boards behave alike, even guys that have had 3 using the same exact hardware had markedly different experiences with each board. The new gigabytes seem quite consistent from what i can see from the thread. My board is running flawlessly at 4.3 GHz (478 x 9, DDR2-1147, PL8), no crackles in the sound, no NIC dropouts, nothing at all, it's rock solid. It's hardly an extreme clock for 24/7 but it's well out of spec, however things may change if it was at 600+ FSB.
@ bobly .....yup, SS Unit from Little Devil.
@ Cryptik ......Thanks for the reply and I've had the QX since they first came out. It sits right now in my main system @ 4.2 Ghz, 1.4V on air. I was very leary to try any higher as blowing up 900 euros would REALLY hurt!! Now that I've got the phase and a little more experience I was going to put it "under the cold" to see if I could improve my 3D Mark scores. You are right about the NB GTL's. Many combinations seem to work but stabilty for me means I have to set the NB GTL -30 to -40 lower. Thanks again guys!!:up:
Ok Guys so I might need your help Currently Running this E8600 @ 4.5ghz on water chip is great runs fast with low vcore im loving it now I want to try some bench runs on water and with the Rampage extreme it seems to be finnicky like one dash of anything will cause it not to boot lowering voltages makes it more stable most of the time and once its stable its steel but you need to get there first so here is the question
is my math correct
VTT of FSB voltage = 1.43
1.43x0.667 + Y = VTT x 0.635
0.95381 + Y = 0.89535
Y = 0.89535 - 0.95381
Y = -0.05846
Y= -58mv and round it to -60mv
so I would set core 0 and core 1 gtl ref to -60mv ?
Im currently not using the GTL ref (auto) because its been stable rock solid at these settings but when I want to do some benching these values become more important at higher speeds.
mikeyakame,
thanks a ton on that insight how actually Gigabyte is achieving that. I have had my gripes about ASUS recently, frankly. And I might change over to Gigabyte next time, per chance when I am getting a Socket 1366 system. Gigabyte seems to spend more professional thoughts into board design, while ASUS may become the victim of their own 'coolness'. 16 phase power looks stupid to me.
I am not so much concerned about the high GTL ref. of 0.69 on myboard. I only discovered today that my system is running stably at setting NB and both CPU GTL references to 0.63, which somehow did not work for me initially.
What I don't get is:
I had a Maximus Formula board before which only had one BIOS setting for all CPU GTL references. The next generation ASUS P45 boards introduced that split up of data and adress GTL references. And since I can only run my Q9550 at NB and CPU GTL references set to the same values, this likely means for a well part of the P5Q/P5Q3 users that ASUS' approach on keeping the references apart failed. Or it introduces more setbacks than gains, whatever they are.
I just wish I could hook up a good oscilloscope to the onboard traces and really SEE what's going on, to see the effects of my BIOS settings on the actual signals.
I wonder what awaits us on the QPI bus! Perhaps nothing fancy for a while, until that new bus getsto its limits in several years future :p:
Ah ok no problem then, its should go pretty nicely with cold, it's already doing well for that type of cpu, better than some 9650 E0's, so it looks like you got a good one.
0.635 x 1.43v = 0.90805v
0.667 x 1.43v = 0.95381v
0.95381v - 0.90805v = 0.04576v (rounds to 46mv)
So for example you could set:
GTL Ref 0 = +10mv
GTL Ref 1 = -35mv
GTL Ref 2 = +10mv
GTL Ref 3 = -35mv
or
GTL Ref 0 = Auto
GTL Ref 1 = -45mv
GTL Ref 2 = Auto
GTL Ref 3 = -45mv
However there is no harm in setting the GTL refs to only 40mv or less apart, so play around and see what works best for your system. My cpu seems to like the data bus Vref raised but raising the address bus Vref doesnt seem to make much difference.
(*)I tested my CPU on prime95 small fft's on 3.6GHz 1.42v 9x multi at 1600FSB and passes 8 hours.
Ram at stock, memtest 8h pass. Still get freezing on blend.
I have been at this for a year now, only thing left is gtl refs.
Raised voltage to sensible levels but still higher than needed.
I've tried from +50/+10/+50/+10 to +90/+50/+90/+50
tried minus too +30/-20/+30/-20
core 0/3 from 2/4 always 40 difference. If I'm out of the calculated result i get instabilities even sooner.
But I always leave the NB at +50 (+46 needed,calculated).
I need to know this:
if I get bsod and restart means is the CPU gtls(*)?
If I get freezing is it the NB gtl?
Also should I decrease or increase the NB gtl? VTT is at 1.49v, NB is at 1.5v
Trying +80mv now, all the way from +50mv are unstable for me. Strange, they take almost the same amount of time to freeze or gimme the the BSOD then freeze.
I don't recommend actually calculating NB GTL Ref. You need to find through trial and error what gives the most stable results. Leave it auto to begin with, and see how you go. I tested my NB GTL Ref from -100mv to +100mv and found my sweet spot at 445 FSB on 5:6 divider was -60mv, and at 478 FSB on 5:6 divider was -40mv. Other guys with the same board as me require different NB GTL Ref settings for stability, some cant even boot on my settings.
It's important you experiment with your board and find exactly what it likes at a given FSB/clock/memory speed etc.
There is no specific rule that defines what causes what kind of error, it could be anything, ram timings, vcore, Vtt, vdimm, vNB etc. Try to isolate specific items like cpu, ram, NB and try to stress each one to find the problem.
The fact you pass 8hours of small FFT's but fail blend to me indicates a ram/NB instability. Try playing with NB GTL's as I suggested above, and also adjust your ram timings/vdimm. You may also need to experiment with clock skews on ram if you have them.
When I said calculated I meant (VTT x 0.667) - (VTT x 0.635) = 0.046 for me to use on my CPU.
Isn't the NB the same? Anyway used -46 on NB for now (I'm guessing I should go lower, upper means more unstable) and testing CPU again small fft. Ram is fine because I tested it a few days ago, its running on stock frequency, volts and timings.
Its hard to believe the cpu has been stable at 3.8 with 1.54v at 1800 fsb small fft's (q6600 G0, 1.26vid) but blend has been unstable even at 2.4(stock)/2.8/3.0/3.2/3.6 GHz
New question: Is something done different on the Asus Striker 2 Extreme?
People post GTL settings that look similar to this:
GTL ref 0: +50mv
GTL ref 1: +10mv
GTL ref 2: +50mv
GTL ref 3: +10mv
Except on my S2E, 0 and 3 have the same options (going from +14 to +224, and then negatives) while 1 and 2 have different options (going from +13 to 208, and then negatives). Does that mean I should be setting mine like so:
GTL ref 0: +50mv
GTL ref 1: +10mv
GTL ref 2: +10mv
GTL ref 3: +50mV
Edit: Arf this is crazy, I'm nearly stable, primed for 18h without errors and IBT works too (with GTLs on auto) but sometimes I randomly get system freezes, I've noticed they happen more often when I'm transferring a lot of info from one hard drive to another (either SATA to USB or SATA to eSATA) or when playing Assassin's Creed. It's weird but while all other games will work fine and sometimes system freeze every 24-48h, Assassin's Creed will system freeze within 15 minutes >.< Everest reported VTT of 1.28V so I've set it to that in the BIOS for now...
Edit Edit: Worklog
X means pass, a fail will be indicated by the symptom of failure. First X means it posted, second means it booted into Vista, third means it passed 5 passes of IBT (not a real test, but it gives me a rough idea of if I'm on the right track or not, fourth one involves general use, usually crashes within 30 minutes on Assassin's Creed if incorrect).Code:S2E w/ Q9550 REF0 REF1 REF2 REF3 POST BOOT IBT STABLE
FSB 1866 42 0 0 42 X FAIL
Multi 8.5 14 39 39 14 X X FAIL
Memory 1600 -7 26 26 -7 X X BSOD
CPU-Z V 1.36V -14 26 26 -14 X X X FREEZE
PLL Auto 28 65 65 28 X FAIL
VTT 1.28V -21 26 26 -21 X X X FREEZE
Memory 1.9V -21 13 13 -21 X X X
NB 1.5V
SB 1.5V
My Vdimm (memory voltage right?) is set to manufacturer specs which are 1.9V 1600MHz, 7-7-7-20, it should be stable at those settings. On a smaller overclock I had the Vdimm set to 1.86V while still remaining stable, I only put it back up to 1.9V to stay within specs.
What's the rule of thumb/a good voltage to start with for nb gtl? Should I then raise it higher or lower? Is there a maximum one shouldn't go over?
I'm noticing that negative GTL References seem to fail less than positive ones, could thing mean something else? Maybe my VTT is too high?Code:S2E w/ Q9550 REF0 REF1 REF2 REF3 POST BOOT IBT STABLE
FSB 1866 Auto Auto Auto Auto X X X FREEZE
Multi 8.5 -29 13 13 -29 X X X Testing
Memory 1600 -21 13 13 -21 X X X FREEZE
CPU-Z V 1.36V -21 26 26 -21 X X X FREEZE
PLL Auto -14 26 26 -14 X X X FREEZE
VTT 1.28V -7 26 26 -7 X X BSOD
Memory 1.9V 14 39 39 14 X X FAIL
NB 1.5V 28 65 65 28 X FAIL
SB 1.5V 42 0 0 42 X FAIL
What did you test the ram with? Bootable memtest or HCI memtest? Blend is harder on the ram that bootable memtest in my experience.
If it is failing at completely stock speeds, timings, voltages for cpu, ram and NB something is not right at all.
Yes it looks like your striker bios is a little different. Probably using 0.635/0/667x/0.667x/0.635x from top to bottom by the looks of what you posted.
If you are getting lock ups when accessing HDD's perhaps your southbridge needs more voltage. Try increasing it a little and see if it helps.
Okay well I'm currently on -21/13/13/-21 and it seems to be doing okay, Assassin's Creed ran for over an hour without a freeze, though I've ran into the slight problem of having spent all morning playing it and needing a break :P I'm going to do some hard drive sorting though, swap a couple hundred GB around, see if that freezes it.
Before fiddling with the GTL refs I tried upping SB to 1.6V but that still didn't help, only made the NB get a little more toasty :P
Edit: Yup copying files did it XD Gonna bump the SB up a bit.
Edit Edit: First reboot with 1.6Vsb BSOD'd however I think that might have just been a freak accident due to the system freeze that happened during multiple file transfers just before. Since it's not crashed yet, I'll keep moving things around, have a go on assassin's creed again later, but hopefully it will be slightly more stable now :) Then I can prime overnight.
EditEditEdit: :( system freeze again... My computer hates moving files >.<
Memtest and yeah blend is much harder.
1: Loadline Calibration doesn't make a difference, but if I want to go over 1.5 vcore I enable it.
2: On full system load vdimm drops so I need even more voltage on ram at stock freqs and timings.
3: When I booted with memtest on stock fsb, I could get 4883MB/s. When I raised the fsb from 1066 to 1600, without changing anything (P1 & P2 are on Auto and when I double checked they are disabled) the ram did 5861MB/s. That is another reason I need 1.94v instead of 1.9 :shrug:
I definitely made some progress on gtl refs on CPU.
I used to think the same, that's why I have been clocking for a year with no success, until yesterday. When overclocking the first thing that's holding you back is the values you say you will keep untouched.
It seems that raising the fsb above cpu designed makes your northbridge run faster of course, so it demands more of your memory. If you are not raising the pci express busses or MCH SPP freqs, the maximum you want to keep your SB would be on 1.6 unless u go over 500 FSB (2000).
The thing with Vista is when you copy files to an external storage such as usb, requires a lot of memory, its the thing about vdimm.
See my previous post for details.
Hum I'll give it a go, see if it helps. You also mention disabling loadline calibration, would that not also mean having to raise CPU Voltages? Because it's already set to 1.4V in BIOS (1.36V in CPU-Z) and I can't really afford to raise it any higher for 24/7 use :/ (Water cooled but can reach mid 60s under load).
I have been following this guide http://www.anandtech.com/mb/showdoc.aspx?i=3283&p=1 quite helpful in my opinion.
My latest discovery is if you are sure you have you cpu 100% stable (prime95 small fft's at least 4 hours) then run your ram one notch higher than stock (vdimm) then test with prime95 blend, if it freezes, increase NB voltage, mine runs fine at 1800FSB on 1.6 actual. and 1900FSB with 1.65 actual.
Auto on all GTL refs seems the easiest and most stable option to me.
Bear in mind anandtech applied ceramic paste on NB and SB, they found that over the suggested it gets really hot and leads to instability. Even with liquid cooling, I wouldn't go over 1.7 actual.
PLL would be fine at 1.58v til 1900FSB at least with q6600 VID 1.26.
On LLC, I see what you mean; I was thinking the same thing not long ago.
If you hit a wall though, you still freeze and you have more than enough voltage on NB and ram then you might consider disabling it, or just check with everest or something similar for NB temps. If you suspect the ram is getting hot, touch it with the back of your hand or your finger (but not with palm skin, its denser there and you might think the temp is fine) and if you can hold with it there for 10 seconds that means is fine. If you can't hold it then consider some airflow on them.
Watercooled cpu get 60 degrees? What paste did you use? I have mine on 1.55 v ceramic paste air cooled with IFX-14 and the max I get is 66 celcius.
Once I am sure my whole system's stable I use these methods to lower vDimm and vNB:
Running blend with memtest for windows at the same time shows if ram's unstable
Vga torture test plus blend again to see how long it will last for the sake of adjusting vNB (usually crashes within an hour)
If you need any help considering MB just let me know. :up:
