So around 1.3v it is. Good to know. Thank you guys both :up: :up:
i found that the sweet spot on my 4850 is 1.32 to the core,good for 865 in all my benchmark games and still runs cool e-nuff for 24/7 use on my as1 for cooling.
as a matter of factly it seems that it does not scale well with volts after 1.35,max clocks at 1.40v only modest increase to 885 from 1.32v 865.
even with temps 27c ilde 45c load
ok ty, i wasnt sure. thats why i asked. i've only done a few volt mods in the past.
i dont really understand most of what i'm doing with electrical componets, but i'm good at following directions. everyone i've tried so far have worked.
i did flash the bios on my 4870 with better fan speed, and increased the 3d voltage, but i dont think it worked. 830 on the core is still my max stable.
So there is a sweet spot for vMEM as well:
At EXACTLY 1.075v I am rock stable at 1200mhz:shocked:. Any higher or lower, and I cannot be stable. So the ram is capable, you just have to find the right voltage. Stability is checked by 1 hour Furmark, 6 loops of crysis benchmar, then 3 loops of 3dmark06. If no artifacts, I'm stable.
Also, it gets really hot at 1200mhz. I have some beefy heatsinks on it, and they still get pretty hot.
Yup. Just tried 1225 for the first time and it works great. Real glad about it. Time to try 1250... who knows, it might work.
That made me chuckle wesleyclark! :)
How are you getting on with the HD4850 moddin now?
I've bought myself a MM but at this point have no idea how to use it, however mine did come with a battery . . . I'm on a roll! :bounce:
P.S I love these XS animated icons :hrhr:
vddc reading spot fixed, the picture in the article now points to the correct location
Argh! :( Well, guess I'll just have to try it anyway, the hell with it!
Btw, could you give me some more info in what way it couldn't handle it? Didn't run at all, was crashing, or you just couldn't OC it?
As right now, I'm just looking at it WORKING out of the box with this PSU and CPU .. even if I'll have to lower CPU clock a bit (or a lot)
Tnx for the info anyway
What resistance should I be shooting for across the resistors for the 4870 MVDDC and MVDDQ pencil mods?
Is there a nother spot to solder to ??. the pad pulled off.
http://i284.photobucket.com/albums/l...Picture011.jpg
solder wont adhere to it since the spot is greatly reduced to solder to. from a grain of sand size now to a pin piont.
It is wrong again, look at this
http://www.xtremesystems.org/forums/...&postcount=524
thats basically the same spot, mine is just easier to reach imo
So I'm reading up on volt modding in preparation for my 4850s' arrival. Are there any good reading sources for guides, etc.? I've read the VR Zone review here.
I'm still reading through this thread (LOL it's long), but I would like to know where the measuring points for the DMM are. I plan on finding the max OC on stock voltage with WC, diting the BIOS with RBE (I'm familiar with this...) and finding the max OC, then performing the pencil mod and finding the mac OC....
I have a cheap little soldering iron and a radio shack multimeter, but I'm not comfortable enough with the soldering iron to solder such small components without more practice.......however the radio shack DMM should suffice.
I was wondering. I did the vmem mod for the HD4850 with a 100K VR. The lowest voltage I can get is 2.10v , without the mod it's 2.04v After reading that there seems to be a sweet spot at 2.075v i want to redo the mod so i can get a lower voltage. Should I replace the 100K VR with a 50K VR?
I have the same question/problem with DemonEyez. We need 50K VR or 200K VR to achieve what we want? I think 200K VR , right?
If you haven't read this, you should ;) : http://www.xtremesystems.org/forums/...d.php?t=115387
