PSU ( Power Supply Unit ) = Corsair HX1000 ( 1000W )
CPU = Intel QX9650
RAM = OCZ DDR3-16000 Platinum Edition 4GB Kit ( OCZ3P20004GK )
HDD = Western Digital Raptor ( 300GB x2 Raid 0)
VGA1 = PNY GeForce 280GTX 1GB
VGA2 = none
VGA3 = none
SPU ( Sound Card ) = AuzenTech Auzen X-Fi Prelude
NorthBridge Cooling = Bitpower water block
SouthBridge Cooling = Bitpower water block
CPU Cooling = custom water cooled with Swiftech water block
RAM Cooling = OCZ Memory Cooler
nFORCE Chipset Drivers Version = nVIDIA nFORCE Drivers v15.23
ForceWare/GeForce Drivers Version = nVIDIA ForceWare v177.83
Sound Card Drivers Version = X-Fi Prelude RC7
BIOS version 0901
BIOS Settings
Extreme Tweaker
CPU Level Up = Auto
Memory Level Up = Auto
AI Overclock Tuner = Manual
CPU Multiplier = 9.0
FSB - Memory Clock Mode = Linked
FSB - Memory Ratio = Synch
FSB (QDR) MHz = 1800
MEM (DDR) MHz = 1800
LDT Frequency = 5x
PCIE Bus Slot 1 & 2 MHz = 125 There's a minor performance gain but so not worth it, will need more NB,SB voltage thus gets your mainboard hot.
PCIE Bus Slot 3 MHz = 100
SPP<->MCP Ref Clock, MHz = 200
SLI-Ready Memory = Disabled
Memory Timing Setting
P1 = Disabled
P2 = Disabled
I have the same ram at 1800MHz also. This option is vicious, at 1800MHz of ram you might have corruptions which windows corrects for you. The erros are detectable in memtest86+ (10+ loops), note that it needs more vNB rather than vDimm.
tCL ( CAS Latency ) = 8
tRCD = 8
tRP = 8
tRAS = 28
Command Per Clock (CMD) = 2T
tRRD = Auto
tRC = 46
tWR = Auto
tWTR = Auto
tFAW = Auto
tRD = Auto
tRTP = Auto
tRFC = 102
tREF = 7.8us
I know these settings are quite relaxed for your taste (from what I can tell) but if you want 100% stability, the settings above are tested for 22 loops memtest86+ and 24h prime95 blend. Been playing lots of games, much encoding for a month now and no corruptions whatsoever.
Over Voltage
CPU Voltage = 1.36250V (actual 1.41)
Loadline Calibration = Enabled
CPU PLL Voltage = 1.60V
CPU VTT voltage =1.4V
Memory Voltage = 1.88 averaging actual should be 1.9
NB Core Voltage = 1.56 with 1800FSB
SB Core Voltage = You can safely run this at 1.5v if you revert PCIE Bus Slots to 100, SPP<->MCP Ref Clock to 200. Note that I am running raid 0 stripe at 1800FSB and I don't need more than that.
CPU GTL REF0 Ratio = -36mv
CPU GTL REF1 Ratio = -40mv
CPU GTL REF2 Ratio = -40mv
CPU GTL REF3 Ratio = -36mv
I'm curious, do you get load drop while 100% load on prime95 blend with these cpu gtl refs?
NB GTL REF Ratio = auto
DDR3 CHA1 Ref Volt = DDR3_REF
DDR3 CHB1 Ref Volt = DDR3_REF
DDR3 CHA2 Ref Volt = DDR3_REF
DDR3 CHB2 Ref Volt = DDR3_REF
You don't have to change these, but auto stands for that.
CPU Configuration
CPU Internal Thermal Control = Enabled
Limit CPUID MaxVal = Disabled
Enhanced C1 (C1E) = Disabled
Execute Disable Bit = Enabled
Virtualization Technology = Disabled
Enhanced Intel SpeedStep(tm) Tech. = Disabled
CPU Core 2 = Enabled
CPU Core 3 = Enabled
CPU Core 4 = Enabled
Spread Spectrum Control
CPU Spread Spectrum = Disabled
PCIE Spread Spectrum = Disabled
MCP PCIE Spread Spectrum = Disabled
SATA Spread Spectrum = Disabled
LDT Spread Spectrum = Disabled
If your cpu temps are fine then you can run 2000FSB with ram at 9-9-9-30-2T, tRC 50, tRFC 110 and voltage at 1.9,1.92 (actual 1.92,1.95), vNB 1.6 (actual 1.62)
Other than that, you can say hello to utmost stability.
