Looks like you need more cpu power to get a good score from these two beasts. SoF is getting better score with 2x hd 4870...but their cpu is working at higher clocks
Well here is a screen with all three 4870s and some high NB. Not scaling the way I had hoped.
@ Ben Brown
add a lil more HT link speed, 2200 or so and run it again.
I tried six different times to try and run it with 2200, adjusting voltages on just about everything but it would always crash (3DMark06 not the pc)at the same exact spot everytime (right after the second cpu test). Not sure what is causing it other than the higher HT. Any suggestions?
can you guys write out your systems specs
cpu mhz, gpu model and gpu clocks:up:
3DMark Score ??? 3DMarks
SM 2.0 Score ??? Marks
SM 3.0 Score ??? Marks
CPU Score ???Marks
ex.
Total Score - 12,569
SM2.0 Score: 5,094
SM3.0 Score: 5,712
CPU Score: 3,608
AMD Phenom 9500 @ 2.6GHz
Abit AX78 Mobo
4GB (2GBx2) DDR2 @ 948MHz
eVGA 8800GTS 512MB @ 775/2160
Phenom II 940 BE (ES) @ 3987MHz
3x 4870 512MB @ 810/1035
Total Score - 23,324
SM2.0 Score: 8,545
SM3.0 Score: 12,667
CPU Score: 5,547
Gotcha Ben CPU score, just running a Sapphire 4850 ATI 8.11
http://service.futuremark.com/compare?3dm06=9567921
3DMark Score 13454 3DMarks
SM 2.0 Score 5014
SM 3.0 Score 5681
CPU Score 5584
AMD Phenom II 940 @ 3.780GHz
ASUS M3A32-MVP Deluxe wifi
4x1GB DDR2 @ 1120
Sapphire HD 4850 690/1180
http://img66.imageshack.us/img66/246...rk06378fb4.png
What do you have your voltage set at for that high of ht?
Kinda freak result here while testing the M3A79-T
http://demoncomputers.pwp.blueyonder...bug_score2.jpg
Ben i found myself wth the phenom9850 that to get a stable HT 2200-2400 nb volts around 1.32 & HT 1.30 (not nb-vid)
Well I actually got my HT higher last night. I got it all the way up to 2750 and for the most part either made no difference in score or made it worse overall. I thought that was weird.
http://service.futuremark.com/compare?3dm06=9574142
Stuen4y that is a completely stock system.
CPU is obviously 2.5ghz 2ghz HT 2ghzNB DDR@1066
CNQ enabled > powermode set to high performance
UPDATE
3DMark06
3DMark Score 21484
SM 2.0 Score 7763
SM 3.0 Score 11845
CPU Score 5056
AMD Phenom II 940 @ 3816 Mhz
DFI LanParty 790FXB-M2RSH
2X 2GB OCZ Reaper DDR2-1066 @ 424 Mhz
2x Powercolor HD4870 X2 in Crossfire @ 800/970
http://service.futuremark.com/compare?3dm06=9582187
http://img.photobucket.com/albums/v1...pdog/21484.jpg
http://service.futuremark.com/compare?3dm06=9579655 (200 x 16.5)
3DMark Score 17985 3DMarks
SM 2.0 Score 6641
SM 3.0 Score 9439
CPU Score 4507
http://service.futuremark.com/compare?3dm06=9579863 (200 x 17.5)
3DMark Score 18749 3DMarks
SM 2.0 Score 7046
SM 3.0 Score 9757
CPU Score 4663
edit.
bios is 12.26.08
updated........................................... .nice job fellas
20604 http://service.futuremark.com/compare?3dm06=9597616
phenomII 940
4870x2 / 4870 trifire
this 4870 is crippling my 4870x2 that and i need a bios update for this foxconn
3.35ghz,Phenom 9950, 4850x2 @ 750/1150
score 17,813
sm 2.0 6702
sm 3.0 9158
cpu 4524
http://service.futuremark.com/compare?3dm06=9309990
i finally broke 20k ;)
20405 3Dmarks
http://service.futuremark.com/compare?3dm06=9598583
PhenomII 940 @3712MHz
2x2GB Mushkin BlackAscent @928MHz
Sapphire HD4870X2 @stock cat8.12
wohoo.. 5th in the orb when u search for 3dmark06 results with phenom processors
what??
how come i canīt boot at 4ghz then???
i saw some screenshots of ur cpu at 4ghz and also some with the nb around 3ghz. i canīt do that with mine... did u boot with those clocks or did u just pull them up with aod and then took a screenshot?
hopefully asus is working hard on a new bios with functional acc and let me use high dividers. i hate crippling my ram to frequency way below 1066mhz.
