http://infolab.stanford.edu/pub/voy/.../Google15R.jpg
http://infolab.stanford.edu/pub/voy/...0-4-Google.htm
^awsome!!!!!
A frontal view of my case and fan controller.
Yeah the plastic wrap is goofy, I did that because I was experimenting with pressure, I had to screw that up because I have no front panel to turn on my pc..., I reach through the top of my case where there's an 80mm hole to turn it on...
I just haven't removed the rest of the plastic wrap yet, it ran quite a bit cooler when she was sealed up though.
I was gonna use hot glue, but I thought plastic wrap was a better choice, which it was at the time.
http://img849.imageshack.us/img849/784/hpim0789.jpg
This is the top view of my fan controller, I modded it, the reason why I'm posting this stuff here ;).
All those caps are rubycon mbz's 1500uf 16v.
I added a coil to the power input because of the way the controller works, it adds resistance to the ground to do it's controlling, so the only way of adding a filter to it without having to add one to every chan was to add on there where I did.
http://img197.imageshack.us/img197/9940/hpim0806q.jpg
This is my stock cooler with 2x delta tfb's zipped tied to it lol.
Didn't help get me stable though, they are setup at a voltage level that's just about silent, my panaflo 120mm on the back of the case is louder.
http://img685.imageshack.us/img685/2213/hpim0812.jpg
I tried to find the dvi -> vga adapter that I modded a while back but I don't know where that is at the moment.
I broke a pin off to prevent it from reading the edid as an experiment, that way I didn't have to mod any cables and end up regretting it or something.
Btw the dates are way off on my pics, I just took them a min ago...
That's kind of lame...
Sorry the pics are so blurry.
My cam goes in and out of focus all the time, I have to take 10 pics of each view just to find one pic that is ok'ish.,
Usually I get cleaner shots then that though :\.
Had to take pics while she was off because my cam flips out when there's uv in the shot, all my leds are uv...
Holy Dust Balls
:eek:
Lol, if you think that's bad you should of seen it a month ago before I cleaned it.
I could of made a dust bunny shirt from all the times that I've cleaned it.
I definitely need some sort of filtering, either for my room or my pc.
It really sucks having a transparent case where you can see all that.
I don't recommend acrylic...
If I can get enough lego's together I'll build one out of those.
Either that or find a decent steal case that has alot of 5&1/4 drive bays.
This tread is awesome! So many different innovations!:)
so I have no job atm... = no $$$
& I was sick of not having a black interior to my case.... I had some 3mm MDF & 2 cans of black spray paint lying around... :D
before:
https://lh4.googleusercontent.com/-D...0/IMG_6682.JPG
after:
PC off -
https://lh3.googleusercontent.com/-k...0/IMG_6687.JPG
PC on -
https://lh4.googleusercontent.com/-p...0/IMG_6691.JPG
https://lh3.googleusercontent.com/-s...0/IMG_6693.JPG
I'm happy with the result :)
Holy mods
WOW!!! Hope them bits of tape stay put!!!
Awesome thread, so many creative people here :)
