I've come to that conclusion - I am not talking about the theoretical.Quote:
Originally posted by Jabo
You are all right here but as usual we are talking about different things thinking that we do about one.
I am not at all concerned with the dT of any (single) substance in this matter. dT implies that a material (not two different sides of it!) has changed temperature.Quote:
... if dT equals zero ....
Imagine a phase change system being capable of removing only 100watts of heat. Our cpu produces 100watts of heat and asa result we have a cpu running at ambient temps. Now imagine a cpu giving away 120watts of heat with the same system hooked up. As you probably catching my drift by now it will be hotter than ambient by these 20 watts
No, that is not a proper observation. What is important is the evaporating temperature that the refrigeration system is rated perform the 100 watts of work. Typically a compressor rated at 100 watts, R-404A @ -60F evaporating temperature, will perform perhaps 200 watts of work at -10F, and perhaps 300 watts of work at +20F. This is due to the increase in density of the return gas (resulting from the higher pressure) which increases the volumetric efficiency of the compression cycle and allows the compressor to compress more (pounds) of gas per unit time. This is what is referred to as "The rule of thirds" in my industry, pertining to guestimation of compressor performance.
If you exceed the design load of a system, the system just does not become "static". The system balances. As the load increases the capacity of the system increases accordingly, hopefully not in excess of the maximum rated capacity of the individual components.
DT is still equals 0 since it’s max work but it’s not nearly enough to cool our 120watt core.
errrrrr.... wrong. Work is still being done. At even a greater rate than the design (lower) capacity.
Okay, I'm imagining.... Now, since the load is light, the suction pressure/evaporating temperature is going to drop (colder) which results in less dense gas returning to the compressor which in turn decreases the efficiency of the compression cycle. As such the system balances at a lower temperature to perform the 100 watts of work. Oh, and the TD will increase, being a factor in the system balance equation.Quote:
Now imagine the same 100 core but a new system which is capable of removing 300watts of heat.
I think I just did....Quote:
If my line of thinking is incorrect, please do correct me.
You are a breath of fresh air on this forum, Jabo.
:toast:
The "sides" of the plate are NOT changing temperature. The sides are "different sides, NOT one side changing temperature (dT). It is TD they are different sides. if one side went from 0degF to 10degF, the dT would be "10". If one side is 0, and theother side 10, the TD is 10 and there is no dT, because one side is 0, the other 10, and they still are for the sake of calculation.Quote:
lower ‘local’ dT I am using terminology of local and global as not to confuse temp difference between coolant and core which the bigger the better and local for temp diff b’tween ‘hot’ and ‘cold’ sides of base plate.
