i worked on this os for more than 2 months
3884Mhz with low ram freq will update soon ;)
here we go :D:D
http://photodorp.com/out.php/i635_screen009.jpg
very fast hiwa!!! nice :D
thanks bro :up:
Now, go and do a run that fulfills the purpose of this thread, that is, the lowest speed with which you can get under 9 mins. :p:
i am playing with my os,will try ;)
Cpu:I7 965 @ 3874.4
Mobo : P6T WS Pro
Ram: Kingston T1 3 X 2GB Elpida ICS 1005 7-7-6-18-60-5- rest auto
VGA: 7500 PCI
2K3 Full Tweaked
waza :1.610 one Bigfile
http://photodorp.com/out.php/i650_screen010.jpg
:up:
awesome work bro , you did a great job for sure ...
keep 32Ming it
thanks bro
and why not sub 10?
Cpu:I7 965 @ 3455.6
Mobo : P6T WS Pro
Ram: Kingston T1 3 X 2GB Elpida ICS 1007 7-7-6-18-60-5- rest auto
VGA: 7500 PCI
2K3 Full Tweaked
http://photodorp.com/out.php/i652_screen001.jpg
I have several question!
Do you people use the ramdisk for 32m, and which version?
Can some help me with settings of ramdisk for 32m?
One more question, how much memory you people use for the maxmem. When I use 512MB, results are worse then with default settings, but this is with no ramdisk?
Thanks in advance! :up:
i don't use ramdisk on these results
you need a nice OS and good tweaks(waza,maxmem etc ) for 32m :up:
I use thes same maxmem and i had the best results...I think is the best...!
2784.1......cheapseats.........14.59.328.....6x464 .....928mhz.....7-6-5-15....1/2...X48
LSC on / core 1 affinity / realtime / explorer closed / 512-512 page file /
1 disk / 2 partition / maxmem 680 / SpiTweaker v1.0 CDT (680MB file) D>C (SPi C)
http://i447.photobucket.com/albums/q...32M_14m59x.jpg
Thanks mate I will try today :)
I have i7 965 - 3x 1GB DDR3 2000 MHz Super Talent - Win Server 2003 (thanks to Andre Yang) :wave:
Settings that works for me :)
1. D: Pagefile size - 512 -512 mb
2. maxmem 680 mb, spitweaker 600 MB (C to D) - 128kb file size 30sec wait
3. with no spitweaker I have 3-3,5 sec lower score, at 3.8GHz (1900 MHz mem 8-8-8-25 1t)
My question is, do you people use ERAM for 32m, and can I improve my setting little more?
Happy to hear that Spacemaster,here i tried to write you step by step and some small tweaks for 32m
2K3 i don't know which language
maxmem :600 reboot
copywaza : 1625MB c:\ > d:\ .... d:\ > c:\ .... c:\ > D:\
pagefile : 512/512 reboot
AlwaysUnloadDLL"="1
NtfsDisable8dot3NameCreation"=1
NtfsDisableLastAccessUpdate"= 1
DisablePagingExecutive"=1
LargeSystemCache"=1
ClearPageFileAtShutdown"=1
AutoEndTasks"="1"HungAppTimeout=5000
MenuShowDelay"=400
WaitToKillAppTimeout"=4000
WaitToKillServiceTimeout=4000
EnableSuperfetch=1
EnablePrefetcher=1
reboot
3 services enable (RPC, EventLog, SHD)
reboot
open spi 3 X 16k 0.94 open 32m
Priority = High
CPU = 0
Closed Explorer
9 proccess
finished Copywaza >> stop 10sec >> cloesd task manager
Run
http://photodorp.com/out.php/t655_42.jpg
wow
fantastic run
