You set trimmer on max,100k ohm? And then how much was the voltage ?
At 100kohm it is about 1.38vgpu
You must have done something wrong
Got Gigabyte HD3850 to mod- it has non-reference pcb with Nexsen PWM controllers on it.
Card has Zalman cooler and blue pcb, but I think same mods can be used for other cards with same PWM chip.
Vgu mods- I measured 10K resistance between GND and FB pin.
This is without mods!
Red line is connected to FB pin and any point of it can be used for "fooling" feedback voltage to chip.
http://www.oc.pri.ee/vmods/Gigabyte_...a3850_Vgpu.jpg
Vmem mods- same story.
http://www.oc.pri.ee/vmods/Gigabyte_...a3850_Vmem.jpg
Actual mods on extra pcb:
http://www.oc.pri.ee/vmods/Gigabyte_..._3850_mods.jpg
and schematic diagram:
http://www.oc.pri.ee/vmods/Gigabyte_...ga_3850_sh.PNG
Voltage monitoring poins are knows already I think.
Mods working fine, Vgpu is limited at ca.1,75V with extra resistance on Vgpu, if you need more, use resistor with lower resistance.
I am that lucky guy who got this mod on my Gigabyte HD 3850 512mb card. :D
Right now 860mhz on core is max what i get out with this "locked" bios. Without that mod and 1,256 v i got only 805 mhz max stable under benching. Memory is Hynix 1.4ns and right now i could get stable bench clocks with RTuner 1044mhz with stock vmem.
3DMark06 skore is 13568
http://service.futuremark.com/compare?3dm06=5461767
Not bad :cool:
Now in need of a good bios mod. So can go for 1000mhz.
And about temps. I have default Zalman cu700, bench temps i saw in load with RT monitoring were 81C. But those were with very high vcore, wich i just put on, knowing that those will be enough to pass with 860 core speed. Now try to lower them to optimize.
Thanks Jaan!
could someone clarify what is that buzzing noise coming from video card when clock is big or framerates are high.
and is that dangerous if i can hear it almost all the time?
well its producing that sound even with default clock and current (under load).
but now its pretty much constant when playing. how is one supposed to fix it? :rolleyes:
Hynix mems have 1.834V by default. How much voltage could it handle and what do you guys think would be normal to run for 24/7.
http://www.xtremesystems.org/forums/...1&d=1203732548
The third resistor down is connected to the FB pin.
FB pin to ground is 5.72k
Resistance of the actual resistor is 3.64k
Jimbo Mahoney try to shade with a pencil a bit the third resistor and see if the core can handle more Mhz if so then use a 100K Trim pot 25 turns from the FB to ground it souled work
raibemunn 2,2V souled be fine for DDR3 Mems ;)
Random Murderer I saw you posted a pic of the blue pcb. I have HIS 3870 which uses blue and I have done the pencil mod, but I want to hard mod. Should I just add 100k trimmer to the pencil mod spot here or is there a better place?
http://img402.imageshack.us/img402/3573/img03933aq0.jpg
Here u go.
Ok will do, thanks. I can use the ground to next to the VGPU read pt ya?
This works to?
yes but it is way harder to solder there than the other spot
Which other spot are you referring to?
My card: http://ceemic.pri.ee/hardware/hd3870/hd3870_13_1.jpg
Wanted to solder tomorrow morning. I don't know, if there is any other spot to solder...
Any of the green spots(they are all connected by a trace that i highlighted in green)
http://img.photobucket.com/albums/v6...mg03933aq0.jpg
Random Murderer, do You know any other spot to solder on my Giga's 3870? I have card here right now and DMM too, if it helps...
Very good, thank u sirs, will mod this weekend.
