lol i will try out 801 now
Yeah, they are. I just dont get what the hell it can be!! its obviously a bug with this specific ram. But this goes to show you ASUS's pathetic quality control. Since the ram works fine in P5B-D yet not a Commando? with same chipset! jeezQuote:
Originally Posted by Nanobot
I got my Commando up and running with a Q6600 ES.
The Commando support CD isn't working at all for me. My CD drives will not read the disc whatsoever...(the same drives I used to install Windows and other software.)
Also the CD is labeled as COMMANDO MOTHERBOARD: NVidia nForce 680i SLI Support DVD!!
So, this means I do not have any of the software that came with the motherboard......some are on Asus website, but most of it isn't!!
Anyone willing to burn me a copy of the CD and send it to me...I can send a few dollars through Paypal.
BL
WTF!! I just noticed the same thing, the Support DVD says NVIDIA SLI on it!!
God damn monkeys work at Asus i tell ya!
Same issue here and I can not read it. That may because I am running Vista however.Quote:
Originally Posted by BLHealthy4life
ive come to realize something important here.
On this Commando, CHANNEL A (dual channel memory config) will not boot with bios 801 beta. But if i use Channel B (dual channel memory config) it boots fine and its rock stable! BUT in channel B mode, i notice the ram voltage drop to 1.8v instead of the recommended SPD 1.9V!! i dont understand this issue
its clearly something to do with voltages .. they better fix this in next bios
hi
does any one know where i can get a listing of the bios codes for this MB. most of them are pretty straight forward i know but i keep gettin one sayin CPR FAIL (yip CPR not cpu).
it happens when i try to go for a 450 fsb anything under that and it posts fine cant post at 450 or anything over it.
suggestions gratefully recieved
cheers
CPR is probibally Taiwaneese English. There are lots of spelling and grammer errors on the Asus web site, on labels and in other areas. Lungists they are not but they are sure fine engineers.
Hi all, I received my Commando yesterday :).
Same here. Yesterday I was on Vista too - so I thought for one second (after reading Your post) that on XP (on which I'm at this moment) it will be fine - no luck, DVD still isn't working... :(Quote:
Originally Posted by Baer
I have an E6400 (FSB wall @ ~510 on P5B-Dlx, same with Commando) and I thought that with Commando it will be possible to run FSB 500+ on 1066 strap. Again, no luck - today's best was 505MHz (2V NB @ BIOS, ambient ~5°C, NB heatsink temperature ~26°C measured with multimeter). Not 1M-stable even on FSB500... On 5-5-5-15-5-35-10-10-10-11 (pretty default settings) I reached ~490, 5-5-5-15-6-42-15-31-15-31 gave my this 505.
Maybe there is some sweet point in RAM subtimings or something else? Does anyone know how to improve this result?
Where are you folks buying your boards from???:eek:Quote:
I wonder if they really did send out the incorrect disks with the Commando. I will call them.Quote:
Originally Posted by JMKS
nah, mine said 680i, but it had all the intel drivers on the disk... just a misprint.
I loaded the RAID drivers but nothing else from the disk. Is there anything else I need in there?
Nothing you can't download newer versions of elsewhere... Oh there's a registered copy of 3DMark 06 if that flicks your switch.
ok this might fairly be the noobest thing but i got a problem with my hd.
bought a new seagate 80gb drive for boot en bench.
now after testing it a little i noticed huge speed drops in hd tune.
heres a pic
http://users.telenet.be/hitman316/help.JPG
Im running the drivers in AHCI with the latest intel drivers.
any help would be more then welcome.
So I'am not the only one who did mention huge drops in hdtune (seagate 320GB 7200.10 Sata). I will test another harddrive ( IDE interface) to be sure it has to do with sata.Quote:
Originally Posted by DoomSayer
well i have 2 seagate 7200.10 320GB and a maxtor DM10 250GB and they run fine.
Only the drive with windows seems to be affected by this.
these drops seam to happen whenever a program needs to start or a service is being used.
also i noticed in nero info tool that only the bad performing drive has dma on.
http://users.telenet.be/hitman316/help2.JPG
yea the ICH8 seems really flaky on this board. I have unsual speed drop from those benchmark as well. However, this is my first 965 board so I'm not sure if all the 965 boards act the same way. I know the P5W wasnt like this at all.
well if anyone knows a fix it would be more then welcome
Anyone got decent 5-5-5 clocking on this board ? 3-3-3 and 4-4-4 is looking good, but 5-5-5 stability is very very poor (lower Mhz than 4-4-4).
Hi, my first post here, :)
BIOS 702
400X9
http://bbs.ocqq.com/attachments/foru...DWst1vX9zp.jpg
445X9
http://bbs.ocqq.com/attachments/foru...feGLPZVAOc.jpg
500X8
http://bbs.ocqq.com/attachments/foru...e4Df6bVHX2.jpg
BIOS 801, 400X9, 7sec faster in superpi32M
http://bbs.ocqq.com/attachments/foru...ZrDMQxFNpC.jpg
I have same DVD and it work without problems. My DVD-RW (BenQ) read it and i can installQuote:
the driver & software from it.
On my DVD were only Intel driver, 3DMark06, Kaspersky, PCProbe and other software. I think its wrong labeled?
Got my Commando today, lousy cooling on chipset, both SB and NB. Will post pictures later, now I am going to start lapping the NB and SB heatsinks, apply Ceramique and start the board.
Yes this was mine Commando Heatpipes whatever mobo i get i always repast as 1st job:D now.Quote:
luck:)
Originally Posted by Supershanks
wow, next to nothing touching. :(
