:woot: 39 x 10 = 390 MHz. Is that still faster than my P2 @ 400MHzQuote:
so the real question, 3t will it beat 975 super pi?
also does 3t aloow higher mem clocks?
This is interesting indeed...Quote:
Originally Posted by Revv23
Just a typo, I am sure, he probably meant 390, no 39 ... come on, give the guy a break, I mean if you're trying to test this board and give us info from time to time, I bet you might make a typo once in awhile ... :rolleyes:Quote:
On my board and memory settings, 3T is slightly faster than 1T at 1M/4M, 3T is about 30 seconds slower than 1T at 32M. Tony is the memory guru on this board but so far I see 3T being a killer in just about everything. The problem with this board is that once you make a change, it actually does something. :D That is not really a problem as I love it but I promise you it will take a good four or five days of tweaking to figure out the optimum settings and it all changes as soon as you switch out memory or CPUs. It might not show in all of the benchmarks, but the feeling behind the keyboard is that once you hit on that perfect setting, the board is silly fast. ;) Back to RAID testing.....Quote:
I'd say this board is more for the hardware enthusiast than the serious gamer.Quote:
Originally Posted by 2000army
It's good if you want to spend hours tweaking everything to get a nice OC, but if you're a serious gamer who wants to play games, just get a D975XBX2 - very stable board and it's not like you'll ever be able to tell a FPS difference in your games.
4 CPU's died and 20k boards sold...kinda makes you feel that the cpu burn issue was a none issue;)Quote:
Originally Posted by BenchZowner
1 person posting on a forum can look like 30 people with the same issue, its one of the bad side effects of an open forum.
was no typo, RGone is JSP testing (Joe sixpack) IE the user who just plugs in and plays. We have to make sure the board works from cmos clears etc.Quote:
Originally Posted by AKHandyman
No time to test this right now, i have to pull this board out to test 680I Asus tomorrow :(Quote:
what the.... OMG, get rid of that Asus board!!!
more tests more tests!!! :)
hmm so 3t seems great but overall how much further were you able to oc the memory? jw than 1t or 2t.Quote:
Originally Posted by bingo13
well... how smart of dfi to put a passive cool on it!:slapass:
especially with those stupid Intel clips for heatsink... I do not see the way to replace it with IceberQ for example.Quote:
Originally Posted by rpg711
Keep in mind the clips don't require quite as much space on the board as a large hole does. The engineers might have decided it's best to go this route so traces on the board don't get unnecessarily complicated. At least they have 4 on there so a waterblock can sit securely.Quote:
Originally Posted by mnemonik23
And I'm sure the HR-05 (among other sinks) will fit well enough, if the stock one doesn't suffice for you. ;)
it doesn't run hot at all compared to 680i... and probably a little less thatn 975x. Guess ati is making up for their heat in the gpu department heh. The Crossfire express 3200 used I believe around 15watts less at load. I'm not sure. than an nforce 4 ultra. The 680i is I think 20w+975X(relatively equivalent to the Nforce 4 Ultra).Quote:
This baby is up on the DFI website
http://tinyurl.com/ylcm4s
EDIT: Its 12:10am EST 12/15/2006 do you know where your Mobo is? :D
if it goes on sale it will be at 3am est probably
Newegg post 8am to 12pm PST.
It has been on DFI site.
Looks like im staying up to see I know of 3 sites with listings for it right now US/EU/AU plastics at my side and autofill :toast: heres hopin :stick:
care to share?
After all the hype watch, it won't break 350 FSB with retail. :p:
zipzoomfly (of course)
Nintek australian, and I believe OCUK will have it
I'm saying up also, if I find any new listings, I'll let you guys know :)
i will aswell....im checking newegg
so what do you guys think.....E6600 or Xeon 3060?
