http://clubit.com/product_detail.cfm?itemno=CA4838942
229.00 and great customer service.
That is the bulk version which I am pretty sure means OEM which is about the same at newegg for the OEM version and other places. I needed to go retail because I own 0 cords and will need them etc. Thanks for the site though.
get the OEM version and order some nicer cables. OEM cables look like crap.
Already picked up the board through newegg so I am set. Hoping Ram works with the board now.
Originally Posted by situman
actually the cables that come with the BX2 don't look to bad. They look UV reactive. Even the sata ones.
Originally Posted by gtj
Hmm, well not a biggie, but you would have thought that Intel could have easily fixed the voltage read/reset thing by now since it happened in the BX1 also. I don't think I have ever heard this on another chipset before. I called Intel and logged yet another case re: the Marvel disabled HDD light issue as well as the voltage thing. I guess if enough people call, they may fix it eventually.
Does ultimate v3.5 reset the vcore or only everest basic?Quote:
Originally Posted by heikis
So did you get your BX2 setup ?Quote:
Originally Posted by xgman
got it today but haven't even started. Going to do some pencil mods add a couple NB fans, rig a cmos config switch and then probably boot up a DOA board. (just kidding about that part) :)
Ultimate 3.5 beta 3.50.841 definitely does.Quote:
uggg . . . that's a real shame. I use the OSD monitor all the time.Quote:
So does it drop vcore while still in Windows or only while restarting?
Everest is up to 3.50.850 in beta if that may help.
try going back to bios 2333Quote:
I don't know why but with 2395, 400+fsb = no boot
back to 2333 and everything is fine :)
Go to Computer/Sensors and poof. Immediate hang.Quote:
I had to go several rounds with the battery and jumper but it seems stable for me now.Quote:
Originally Posted by Supertim0r
2395 has a tighter timing table on 1067 strap, so if you want to run 400+fsb you may need to try 1333 strap (333 reference) and tweak the timings down a little to gain back the bandwidth.
I also found some of the ram timings not working as they should on 2333 so flashing back may give you some issues also.
If you have a 6800 you may want to try this.
Set 200 reference, set 533 for the ram (3:4) and 333fsb for the CPU. If you have good memory you should be able to set 4-4-3-8, TRAS dead low will actually hurt performance.
Now with the 6800 you will set a 12 multi for 4GHZ or 11 for 3.6+.
Access latency will be somewhere around 6ns faster in this config than running the ram 1:1 even if you are running well over 900 1:1 in 1067ref mode.
Im trying to source a 6800 to test here, im stuck with a 6700 so 10 multi is all i have but I have some data i can share.
Goldmem pro used for bandwidth, everest for latency.
CPU speed was manipulated with the strap to force given ram speeds, even though 4:5 267 REF at 888 had the highest bandwidth its access latency is no where near as good as 888 200REF, which will make the 200REF setting faster.Now I know the CPU would be faster at 355fsb but we are looking at the memory here not the final CPU speed.Code:memspeed FSB REF Strap ratio bandwidth latency
833 333 267 4:5 4736 61.4ns
833 311 200 3:4 4639 55ns
888 333 200 3:4 4965 51.5ns
888 355 267 4:5 5041 57.6ns
Remember C2D does not need tons of bandwidth, it just needs to use the bandwidth more efficiently. Lower access latency = more performance.
Tony
No X6800 here :(
I'll try tomorow with Q6600 and see if its working with 9+ multi
Can you give us the best settings for the 6600??? Please?? Thanx!!Quote:
Originally Posted by Tony
I second that!Quote:
Originally Posted by malachi1313
Just pulled the trigger and bought BX2!
Now wondering how to get the best from E6600 and G.Skill PC2-8000 HZ. I hope I won't need to go with slower RAM :(
ah, so the reference frequency is actual control over the chipset strap. I was originally under the impression that it was just a way to force dividers on the memory controller.
for all you e6600 users this doesn't really help you out. At lower strap settings the ultimate stable FSB is significantly lower. It boils down to you having to test things out for yourselves (i know you despise this). With the ability to control the chipset strap, you have to make the trade off between memory latency and CPU speed (FSB speed). Basically you will have to bench at your max FSB on each of the strap settings (200/266/333) and go with the one that gives you the best stable numbers for the application you are most interested in. As with anything there is no "best setting" for any given CPU, each is different and it all depends on what you are most concerned with.
Tony, how does the chipset strap influence stability of a given speed on your memory? for instance if you were to run on the 133 strap with a 1:3 divider at 166 fsb. That would put your memory at 1000. All the stress would be on the memory controler, not the CPU or the actual FSB. I'm only asking without testing myself because I have no video card ATM.
edit: and i'm probably answering my own question, but I'm guessing that at this low a FSB you are killing your bandwidth to the point where any gains in lower latency are completely overshadowed. But i'll be testing for myself as soon as I get my video card.
<3 EVGA step-up
Glad you found your board, but to set the record straight it is the boxed version, One way to tell besides the fact that they would have to list it as an OEM is the color of the sata connector at the bottom of the board, the boxed one the connector is red and not so on OEM.Quote:
Originally Posted by Teratism
i was using the 1333 strap all along (333MHz referene frequency). but it wont even POST at 266MHz reference frequency. i tried playing with the voltages and so on. anybody have this problem with the lates bios (2395)?
I'm glad I stumbled across this thread... I was wondering why everest crashed my system! It did a hard reset and I had to toggle my bios configuration jumper to post. :)Quote:
Hi,
Recieving BX2 tomorrow and have downloaded 2395 BIOS from Intel site. Reading posts about not able to hit 400 FSB with this BIOS, can anyone post/link the previos BIOS 2333 or 2330 as I can't find them on Intel site.
Edited: Found them on Intel site...
