100% stabled @ 505FSB 1:1 with 1.4875
http://s2.supload.com/thumbs/default/505FSB.JPG
there's probably more than 1000 persons with C2D systems now in this forum, why so few results in the first page?
here is mine (although not final)....24/7 setup:
http://upshizzle.com/gallery/albums/...PCIe_12721.jpg
http://upshizzle.com/gallery/albums/...d_PCIe_x16.jpg
I'm still working on my benchable setup, but so far I have 3.4ghz @485 fsb somewhat stable..still tweaking the RAM timings for this setup.
Because KITT hasn't updated the database in over a month ;)Quote:
Originally Posted by fscussel
here is an update :toast: :woot:
decreased Vcore to 1.35 (from 1.3875), increased fsb slightly from 450 to 460, and this thing is purring like a cat!!!:clap:
another update:
http://upshizzle.com/gallery/albums/...on 3304ghz.jpg
I'm just starting the orthos 2nd part of test now, but so far so good...I''l post an update as it goes longer if you want....let me know.
http://upshizzle.com/gallery/albums/...3ghz_13006.jpg
http://upshizzle.com/gallery/albums/...006_orthos.jpg
Dual prime: 3770mhz @ 1.45V (ambient temp = 23.6C, in case - side panel off)
http://img182.imageshack.us/img182/7...esprimewp1.jpg
That's friggin' hot mate! No throttling?
Nope :DQuote:
Originally Posted by Jodiuh
But if I add only .0125V (1.46V), temp goes up to 85C and the CPU will throttle :(
Far too hot for only 3.769GHz, time for some WC :fact:Quote:
Originally Posted by rick_fx
Bloody hell ! so many C2D o/c threads, not sure which one to post em' in ... :slobber:
Please dont post your beloved PCWank/Mark Rodney :rolleyes: :p: :DQuote:
Originally Posted by IluvIntel
http://img179.imageshack.us/img179/1...b506memja8.jpg
1.475v in BIOS. Get's too hot w/ anything higher than 1.5v.
What cooling are you using ??Quote:
Originally Posted by vudoodoodoo
Easy for you to say, because you can't run them.:D :fact: :banana: :banana: :banana:Quote:
Originally Posted by alpha0ne
Arr you baitch :stick: :p: :D
Even better, phase change soon :fact:Quote:
I'm also going to lap the CPU, every little bit helps :)
My god, you have some balls.Quote:
So what do you guys think of my stable overclock of a 6300@3,2Ghz Vcore 1,32v on Air cooling. I'm very hapy with it at least:woot:
http://img247.imageshack.us/img247/6106/3200cw8.jpg
Water. I'm probably not getting a good mount or something. =/Quote:
Try a remount as those temps are very bad for WC, my E6600 ES only gets to 43C when tortured using ORTHOS @ 3.6GHzQuote:
Also try lowering your Vcore one notch at a time, run ORTHOS for an hour (only use large FFT's, small are a waste of time IMHO) and if no error try lowering Vcore another notch
If Asus Probe is showing 84c I wonder what TAT/core temp show:eek:
I´ve sent my HW to a friend....that´s all he could do
http://img220.imageshack.us/img220/3...528ddr2lk0.jpg
org from
http://www.forumdeluxx.de/forum/show...postcount=4517
its my HW and his cooling ^^
hmmm you should be in the 12sec low @ 4.2ghz
Originally Posted by VL125
Yes, it should be faster, but not sub 13s! ;)
Conroe @ 4200MHz is about 12.1xxs, normally.
