Well, basically you can tell the actual core that is in the CPU by the CPUID and the socket the CPU is run on.
I've simply decided to go by the same route as other ID programs to prevent confusion for users.
Thanks for testing this, I wasn't sure I was doing it correctly, since the Thuban is not yet in the official docs.
There also seems to be a big with the placement of the load labels.
Could you please post a Register Dump file? (Go into Tools menu and click Register dump)
