nice!
nice!
nice!!
http://i47.tinypic.com/sol8jm.jpg
hey guys what do you think about my rig?
here is my photolog of the projec:
http://www.facebook.com/media/set/?s...1¬if_t=like
see ya!!!
some very nice rigs in here,great work and nice and tidy!
How are You going to fill it with pump not connected directly to reservoir? :)
@ UlyssesCazuquel why do you have the videocard output to the cpu block output instead of input?
AweSome YING! Very Nice and Clean Mod!!
Got a second 5870 and watercooled them.
http://i305.photobucket.com/albums/n...x/IMG_4958.jpg
http://i305.photobucket.com/albums/n...x/IMG_4961.jpg
http://i305.photobucket.com/albums/n...Stacker017.jpg
http://i305.photobucket.com/albums/n...x/IMG_4947.jpg
Some really nice builds in here guys! Keep it up :up:
euro, that's some awesome black coolant
Nice work! :up: You should consider watercooling your CPU.
Hi everybody! This is my small system assmbled with recycled hardware:
- Core i7 860
- Gigabyte H55N-USB3
- 8GB G.Skill Ares
- Asus HD5850
- Crucial M4 128 GB
- RAID1 Seagate 7200.12 1T
- LG Optical drive
- Scythe card reader
- Corsair GS700
- Aerocool QS-202
Loop:
- Ybris Black Sun on CPU
- EK 5850 Nickel
- Pump EK DCP-4.0
- EK Multioption Res 150
- Feser 240 radiator with coolermaster R4
- Alphacool connectors
Attachment 129837
Looks neat :)
Killer Penguin 2.0
Hardware:
Lian Li V600FX
ASUS Rampage 4 Gene
Intel Core i7 3820 @ 5Ghz
Mushkin Redline 16GB 1866Mhz C9
AMD HD 7970
Intel 330 180GB SSD
Seasonic CP860W with custom black and white sleeved cables
Water Cooling:
Dangerden Monsoon D5 Bay Reservoir
Watercool MO-RA3 4x180MM Radiator with White Silverstone 180MM fans
Watercool Heatkiller 3.0 Black Nickel CPU Block
Watercool Heatkiller HD 79x0 Nickel GPU Block
Bitspower Matte Black 1/2" Barbs
Primohill Primoflex Pro LRT 7/16" 5/8" Clear Tubing
Mayhems Pastel White Concentrate
http://img542.imageshack.us/img542/8017/46236578.jpg
http://img16.imageshack.us/img16/6434/6copyly.jpg
http://img42.imageshack.us/img42/7088/img9642copy1.jpg
http://img411.imageshack.us/img411/1033/img9645copy.jpg
Few more pics here: http://forums.overclockers.com.au/sh...postcount=3049
Nice and clean...good work!
MO-RA3 +4x180 ... efficient and extremely quiet, the essence of LC :up:
Hi everyone, this is my first time posting (anywhere) so please forgive me if i am uber noob.
After weeks of looking over this forum and wowing at everyone else's rigs, i decided it is time for me to build my own. (Made even funnier by the fact that i work in IT but didn't even have my own PC).
Whilst i have built 100's of pc's, never have i worked with watercooling. Being who i am, i had to go completely overboard with my build, and chose to extreme watercool it. I wasn't aiming for benchmarks and i don't think i'll even overclock it, watercooling for me was more Aesthetic and wow factor. Yes there were many jokes going around work with the other IT guys, saying i need a pool pump to run it or that it would be easier to drown it, but that didn't stop me.
Have to give kudos to Leo for telling me i have to give it a name, which i chose "Venenum Umbra" (Latin for "Poison Shadow" to go with the Green/Black theme). And to the other guys i work with for always giving me crap about it, lol.
Anyway about the build, i had many ups and downs, 1 faulty rad and 7 faulty comp fittings and a faulty SSD, but managed to get it up and running anyway.
I have spent over 250hours building/configuring it (Individually sleeving PSU cables was about 150Hours, but i was padantic and sleeved all of them including all the fan cables, case cables and light cables, told you i went
I will give you an inventory below the pics, but for now i hope you all enjoy. I couldn't get a decent photo of the bottom half, if i can i will post a link to it later on:
Attachment 129870
Attachment 129871
Attachment 129872
Attachment 129873
Inventory:
Water Cooling Parts:
Koolance Coolant 700ml x2
Koolance Hi Flow Shutoff Female Threaded QDC x2
Koolance Hi Flow Shutoff Female QDC x1
Koolance Hi Flow Shutoff Male QDC x3
Koolance 1 x 120mm Rad x3
Koolance 2 x 120mm Rad x1
Koolance 90 Degree x1
Koolance 45 Angle fitting x1
Bitspower flow meter x1
Bitspower Water Temp sensor x1
Bitspower Stop Fittings x3
Bitspower 90 Degree rotary x3
XSPC m20 to 1/4" Adaptor x1
XSPC RAM Water Block x1
XSPC CPU block x1
XSPC Dual Bay Pump/Res x1
Heatkiller GPU gtx680 waterblock (Painted black) x1
Heatkiller GTX670 Backplate x1
EK 1/2 ID 3/4 OD Comp Fittings x16
Primochill 1/2, 3/4 Tubing 3ft x1
Artic Alumina Ceramic Thermal Paste x2
Hardware:
Gigabyte Z77x-UD3-WB Motherboard x1
I7 3770k CPU x1
Corsair Dominator GT 16GB 2133mhz Ram (4x4GB kit) x1
Gigabyte GTX 670 OC 2GB x1
OCZ Agility 3 SSD 240GB x1
OCZ mSATA SSD 30GB x1
LG Blu-ray/dvd combo drive x1
OCZ ZX 750W PSU x1
Scythe Kaze Master Fan Controller x1
CoolerMaster CM690 Advanced 2 USB 3.0 case x1
Coolermaster 80mm slim fan x1
Coolermaster 120mm fan x5
Coolermaster 140mm fan x1
MS Windows 7 Ult SP1
Kaspersky AV 2012 x1
Other:
Nexus Vented PCI Brackets x4
Fan Cable splitter x2
ModSmart UV Green sleeving kit x1
Modsmart sleeving spool UV Green x1
Modsmart Acrylic Panel x1
UV Green sata cables x4
5mm LED Green x2
3mm LED Green x4
5mm LED UV x4
Modsmart uv cable ties
Bitspower Cold Cathode UV 10cm x4
Bitspower 30 cm cold cathode x2
