@xFEARx3,
Aquacomputer coolant?
@xFEARx3,
This time I used EK red coolant.
very nice rig ! awesome...
Neoprene tubing ?
The new home for the SR-2 build i did last year, only this time with a lot more cooling power( 5 radiators and 20 fans and 5 pumps) and using 2 power supplies, since a single silverstone 1500 watt couldn't handle it in the long run with everything overclocked....
http://i765.photobucket.com/albums/x...2/P1030506.jpg
http://i765.photobucket.com/albums/x...2/P1030509.jpg
http://i765.photobucket.com/albums/x...2/P1030512.jpg
http://i765.photobucket.com/albums/x...2/P1030513.jpg
Yes the last picture shows a pair of 1200 watt power supplies....
And btw.. it's called Norprene cause it's NO Neoprene.
Here are a few pics of my recent (mostly) completed project. It's just a small CPU loop, nothing fancy. It's clean though and I enjoyed building it. The case is a Lian Li PC-V750. :)
http://www.overclockers.com/wp-conte...inished-02.jpg
http://www.overclockers.com/wp-conte...inished-11.jpg
http://www.overclockers.com/wp-conte...inished-17.jpg
More photos are in the build log here (start @ post #19).
you can count me as a Jr. Member :ROTF:
still working on wiring for fan controllers (really just single potentiometers) and pump.
http://www1.picturepush.com/photo/a/...12-part-25.jpg
Hi all.
Few days ago I updated my system. GTX480 has been replaced by GTX 680, I added 6 GB of RAM and sereval terabytes of HDDs.
http://sanbase.org/tmp/comp.jpg
http://sanbase.org/tmp/comp_inside.jpg
The system:
CPU: I7 920 (3.8Ghz)
GPU: GTX 680 (1200 Mhz)
RAM: 12 GB
HDs: 15 TB (3TB+3TB+2TB+2TB+2TB+1.5TB+1.5TB) + SDD (80GB)
My main task was to make a silent system, because I hate the noise of the fans. Since I work mostly with the video (I generate the video sequence on the GPU in a real time), the amount of memory and the power of the video card are very critical (see http://sanbasestudio.com).
Wow thats a tight fot for all that gear!
Manicdan, is that a custom case because it looks awesome. If so specs?
all custom starting with a few sheets of acrylic and sketchup and over 6 months of planning and development.
its the same as my sig, just in tower rather than briefcase and ended up about 20% smaller and lighter. i plan to do a full work log once im done sorting through all the photos. what i put up sofar was done with a decently sized photo tent and my brothers SLR. i have plenty more to show off in upcoming weeks.
