Originally Posted by
Leeghoofd
Why don't you try 445FSB and 1066Mhz on the rams... also for the ram plz set TRFC ( row refresch Cycyle time ) at 55 for 2GB dimms.
And don't put in so high FSB Tern and PLL voltages. Learn how your own CPU's responds to volts.... you tell the story yourself : 1.28 : 1 hour, 1.3 1 minutes : so lower the value then :rolleyes: instead of increasing... think logic !
And if you try tweaking the GTL values (only because it's not stable in Blend ) just trying 0.630 and 0.635 is far from enough... with a quad take your time. A Wolfdale almost doesn't need any NB/CPUGTL tweaking till 550FSB stability (unless the CPU is totally overfed with volts)
In your case I would drop down to 400FSB and learn how to setup the CPU. Get it stable with the lowest values possible of FSB and PLL : testing with prime SMALL FFT !! no IBT plz. Then work ya way up to 425FSB, restest the cpu again. And so on... you guys are all aiming too high from the start and then get lost, copy templates with settings that ( in my humble opinion ) are overkill. And then finally you get frustrated and ditch the board.
P45 needs proper volt tuning, same for the 45nm CPU : MORE VOLTS ISN'T ALWAYS BETTER !!
Start off with FSB Term 1.2, PLL 1.5 and NB Volt at 1.2 at 400FSB/1000mhz ram and most ram timings to AUTO besides 5-5-5-15 TRFC 55, Static Read Disabled.
