Originally Posted by
kevinali
Hey Guys and Gals
I have a quick question,
My system is currently set up using the following settings
Q6700 @ 3.0 Ghz (333 x 9 or 12% OC) at a vcore of 1.236 (My VID is 1.2500V) (prime stable for 24 hrs), with a TRUE 120 and Synthe F fan (idle temps are 33, load temps are 46)
I have 8 GB of DDR2-667 Crucial ram (4 x 2gb @ 5-5-5-12 @ 1.8V @ 333 Mhz or 1:1 ratio)
The system runs like a charm, but every once in a while i get a blue screen with the IRQL_NOT_EQUAL message
My north bridge voltage on my Asus Maximus Formula is 1.360 V....
Given the fact that i have all 4 DIMM slots occupied, is my northbridge voltage too low and causing the errors, or should i bump up vcore (i would rather not, to keep the temps down)
What do you guys recommend for a northbridge voltage setting for a super stable system
Kevin
