This one didn't come out so well.
http://i930.photobucket.com/albums/a...y/IMG_6363.jpg
http://i930.photobucket.com/albums/a...y/IMG_6365.jpg
http://i930.photobucket.com/albums/a...y/IMG_6369.jpg
http://i930.photobucket.com/albums/a...y/IMG_6374.jpg
cabbspapp love it! what case is that? it looks like the mini-version of mine :D
Thanks! It's a Lian Li PC-A05.
air cooling FTMFW! That is a 260 CFM there in silver :)
http://i517.photobucket.com/albums/u...1/DSCF0613.jpg
I painted the side of mine with that white rubber stuff that is used on metal roofs. It is sort of like a rubber band when it dries. It works well but it may be a bit of over kill since it is pricey. I just happened to have some left over when I built mine.
:D :D
Is that the Raven?
it is an industrial strength San Ace 120... model 9SG1212P1G03..you will ifnd very little info on it unfortunately, very rare. Blows 260 CFM, moves paper 10 feet away,, removes fingers indiscriminately! Howls like a jet! two in tandem...ULTRA COPPER TRUE FTMFW!!!
http://i517.photobucket.com/albums/u...1/100_1422.jpg
http://i517.photobucket.com/albums/u...1/100_1423.jpg
http://i517.photobucket.com/albums/u...lie1/true2.jpg
NO VERTICAL MOUNTING LOL
What should i do further to my case?
(that is easy to do - as i dont have time atm to dismantle system again)
PS - these are 5mp images.....
http://i186.photobucket.com/albums/x...923_184838.jpg
http://i186.photobucket.com/albums/x...923_184900.jpg
Ask if you want extra images/without the man mount there
bit hard to take pics where it is.....(door to my room in the way)
cabbspapp something i noticed about that is the psu exhaust blows out the front of the case but there is an intake fan right above it which blows air over the hdd's - does that cause a problem?
Thanks! It's still a work in progress:p:
Yes, it is a bit a pain to mount on the Classified. The Megahalems is actually right up against, touching, the NB HS. I think that might be in some way effecting the performance because I was getting better temps, at idle, with my Cooler Master V8. But when it comes to load performance, it beats the V8 by about 8-10C. If I were able to do it over again, I'd probably go with a different air cooler.
@zaxis. what is that?
Tuniq Tower 120 Extreme it seems
