Originally Posted by
vrdublu
Try increasing your FSb VTT to 1.28-1.30, lower you CPU voltage but only after you get stable. Try this for your NB GTL .85/NB Voltage=your NB GTL, I think it's either your FSB VTT or your NB GTL that is holding you back, that was the problem in my case. Then you can setup your CPU GTL's, do some reading in the forums on this, I promise it will help. Also, run OCCT, I find it;s better for overall system stability, and it will only require a 1 hour run. I have now got my system completely 100% stable and rockin:shocked:. Here is how my bios looks.
AI Overclock tuner: Manual
CPU Ratio Setting: 8.5
FSB Strap to North Bridge: AUTO
FSB Frequency: 533
PCI-E Frequency: 100
DRAM Frequency: 1068
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: Auto
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: Enabled
AI Clock Twister: AUTO
AI Transaction Booster: Manual
Common Performance Level [10]
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.4000V Bios / 1.384V Windows
CPU GTL Voltage Reference (0/2): Auto
CPU GTL Voltage Reference (1/3): .620 Lots of reading helped in this area.
CPU PLL Voltage: 1.62 / Higher fsb requires higher PLL.
FSB Termination Voltage: 1.36 / Above 500fsb I found increments of two helped with the erratic reboots.
DRAM Voltage: 1.92 / This used to be 2.11V in previous bios, whereas 2.02V and above was 2.20V, strange.
NB Voltage: 1.40 / 1.36-1.4 I could run above 500FSB but couldn't get past mem checkers until I worked out the NB GTL issues.
NB GTL Reference: .600 / Again lots of reading makes a big difference here.
SBridge Voltage: Auto
PCIE SATA Voltage: Auto
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : Auto
NB Clock Skew : Auto
CPU Margin Enhancement: Performance Level / Still don't know what this does ?????
P.s. has anyone checked the voltages on the latest 1805 bios, my multi meter is on the frits, I need to know if the voltages are what the bios says they are.
