God damn thats a lot of white fans? Sharkoon 1000?
im lovin the case man, nice black and white combo! what fans are those?
P80B so that means its black from factory ?
Dude what speaker is that?
Im pretty sure that they are the Sharkoon Silent Eagle GolfBall, probably the 1000RPM model here: http://www.performance-pcs.com/catal...ducts_id=20897
Yes.. I'm using Sharkoon Silent Eagle Golf Ball 1000 rpm. :)
Yup, black anodized. But for the inside, i'm using black satin powdercoat. :D
It's Edifier S550D 5.1
Ok i thought it comes out as all black from factory since i also have a P80
I've finally got.............a CASE :D:D:D:D:D:D
http://www.abload.de/img/unbenannt-1ht8d.jpg
^^^ something about those small form builds drives me nuts. Fantastic :up:
Love that small build. I've got 2 LAN parties in just over a month and that would come in SUPER handy. Dragging my Stacker around kinda sucks. :D
to emoners
I spy 2 Lamptron switches and... FC-2 fan controller? with side knobs removed?
Is that the new tuniq?
Yeah that looks like the Tuniq 2 but I also noticed that there is a similarity in design to the Alpenfohn Nordwand with this. The underside seems to have a wiere copper chip thing just below the heatsink.
thanks Chicken Patty & Jodiuh! :D
actually, it's a Scythe Kaze Q 3.5" Fan Controller with the housing removed :D
my true black rev. c
http://img8.imageshack.us/img8/8383/img1411n.jpg
Very nice :wave:
If you want your Noctua S12 (exhaust) to be fully eficient cut down the grill behind it. You lose a lot of airflow atm because that fan is not designed to have any static pressure, so any small grill behind it will decrease most of it's airflow.
I ran into the same thing on my plain case. It had a lot of restriction so I cut out the fan hole and put in a less restrictive plate that come with the fans anyway. It blows twice as much air now than it did and the fans are turned down and MUCH quieter.
It helps with both air flow and noise.
:D:D:D
