First Post :)
Just got this last weekend ;)
http://i25.tinypic.com/2u4okg7.jpg
http://i27.tinypic.com/2vjaq8p.jpg
http://i25.tinypic.com/2eocuv5.jpg
First Post :)
it looks like this:
http://www.abload.de/img/dscn0073gool.jpg
it's called "lcd tv wall mount" and costs about 30-40$ you should find it in big stores
sorry! here you have them hosted on another site:
http://h.imagehost.org/t/0561/dscn0046afgq.jpg http://a.imagehost.org/t/0335/dscn0060vhk6.jpg http://a.imagehost.org/t/0236/dscn00632dwv.jpg http://a.imagehost.org/t/0051/dscn00714ptu.jpg
I bought it at a local shop here in Malaysia @Ringgit 289...
http://i878.photobucket.com/albums/a...ut/cm831-1.jpg
http://i878.photobucket.com/albums/a...ut/cm831-7.jpg
not close to being done but here it is so far. The internals are well a secret for now lol its been blacked out inside tho and paxmated and foamed up. Case runs silent and holds a 3.4GHz OC on a Q6600 at 60C Coretemp :D Its a wind tunnel in there lol 8 120mm fans 1 80mm lol :shocked:
Still undergoing sanding and clears
http://img140.imageshack.us/img140/3...150200orig.jpg
http://img246.imageshack.us/img246/2...150201orig.jpg
http://img6.imageshack.us/img6/6269/11450423338orig.jpg
Airflow layout, VERY OLD PIC! Not my internals right now...
http://img32.imageshack.us/img32/684...235889orig.jpg
Finally a picture that has some light on it. I can actually see something. :shocked:
:D:D
http://img.imagedash.com/bC37.jpg
http://img.imagedash.com/7zAC.jpg
http://img.imagedash.com/V9xp.jpg
They are camera phone pics also.....soz if they are crap (they are ok compared to some i have taken)
I keep the fan/card holder there as its a perfect mount for the fan that keeps my ram cool (they get very hot....Micron D9GMH chips - i dont want them to die - they do 1300mhz +)
I got some aluminium from school and bent it into a shape needed....then screwed it in with meccano (love this stuff !!)
Last pic i have labeled the notable mods/features:
Meccano screws :D
Slot i made for the Sata Cables
Hole under that for the front panel stuff
Cut a part of the ledge for the sata cables to go through
Cut another part of the ledge to allow the other front panel stuff to get through and the power for the dvd drive.
Also - you can see the PCI-E power cable that i have going completely under the motherboard.....:D
What more shall/can i do?
Im planning on putting another PSU in there later(cheaper than getting another larger PSU) as i have one of these:
http://www.frozencpu.com/images/prod...in/cpa-167.jpg
So its cabling and the adapter will be behind the aluminium also....
What else can i do?
When i have heaps of time (after November - end of school - forever :D) i will put some blow holes at the top for my heatsink ti vent into - for now i have taken out the 2 water cooling holes to have some hot air escape via them
Well... Air cooling for the moment
http://www.abload.de/img/img_22091cbe.jpg
Nice with pic with the white LEDs^ :)
http://img35.imageshack.us/img35/59/dsc02363ymd.th.jpg http://img200.imageshack.us/img200/6...c02364w.th.jpg http://img190.imageshack.us/img190/9...c02366q.th.jpg http://img36.imageshack.us/img36/2892/dsc02368o.th.jpg http://img44.imageshack.us/img44/1552/dsc02369a.th.jpg http://img196.imageshack.us/img196/2...2370cfu.th.jpg http://img4.imageshack.us/img4/3091/dsc02371ooi.th.jpg http://img4.imageshack.us/img4/8738/dsc02372biq.th.jpg http://img12.imageshack.us/img12/1907/dsc02373w.th.jpg http://img27.imageshack.us/img27/226...2374rfh.th.jpg http://img42.imageshack.us/img42/9765/dsc02375v.th.jpg http://img42.imageshack.us/img42/3604/dsc02376x.th.jpg http://img36.imageshack.us/img36/2074/dsc02377g.th.jpg http://img34.imageshack.us/img34/770/dsc02378p.th.jpg http://img195.imageshack.us/img195/2...c02379w.th.jpg http://img11.imageshack.us/img11/135/dsc02380x.th.jpg http://img9.imageshack.us/img9/876/1001763x.th.jpg http://img3.imageshack.us/img3/1808/1001745.th.jpg
here is a few pics of mine hope u like:) :
http://i83.photobucket.com/albums/j3...00500-Copy.jpg
http://i83.photobucket.com/albums/j3...00499-Copy.jpg
http://i83.photobucket.com/albums/j3...Y/P1000514.jpg
And my second rig:
http://i83.photobucket.com/albums/j3...00501-Copy.jpg
Nothin showing up
wow dude tell us about this cooler , i am reading it matches ultra120 performance levels...
well nothing to tell yet..Quote:
just finished installing my rig few hours ago and didn't have time to do some benching..
wright now i'm thinking of replacing sanyo denkis cause they vibrate a lot (whole antec is vibrating)...
My Sanyo Denki's never vibrated that bad.
http://i930.photobucket.com/albums/a...y/IMG_6308.jpg
