and the game, the smaller is the best too?
i upped my vcore to 1.32 now and changed fsb termination voltage to 1.26, still not stable :/ one of the cores fail 1024 within 10 minutes
v8.7.0.1007?
I get these errors on my P5Q Deluxe every once in a while using v8.6.0.1007 of the floppy AHCI drivers. The bluescreens seem to have stopped but the errors haven't. I thought the newer drivers would fix the problem but apparently not. I might revert to v8.5.0.1032, one user said that this version solved the problem.
does any1 seen such a screen? whats that?
http://img10.imageshack.us/img10/644...tionpt0.th.jpg
Happens when?
seen this?
after posts screens just b4 OS load =/
It happens from time to time...
Unless some1, who encountered this and knows the solution, answers your question,
my suggestions would be:
1. try if it still happens without the overclock
2. try OS on different hdd (or at least replace sata cables)
Hi
I'm new here and have problem whit integrated soundcard. I have connected PC whit optic cable whit my home cinema but I get only stereo sound. I'm using WIN XP profesional SP3. Is it possible to get 5.1 sound via optical audio cable? The back boxes doesn’t work. The most movies I have have AC3 sound but I get only stereo out. I tryed whit original DVD and there is only stereo.
hello
in this mobo no cant pass cas 4-4-4-11 at 4-4-4-10 or more low
setting:
DRAM Read Training: disabled
MEM. OC Charger: enabled
AI Clock Twister: lighther
AI Transaction Booster: AUTO
dram voltage 2.3-2.5
Does anyone know what can cause this to happen? All I did was move this system into the living room to use it as my HTPC and connected my VFD display and installed my 9800GTX and hooked up the SPDIF for my HDMI cable to provide sound.
at first it started as a display driver issue as the screen would go blank during install and lock up. I uninstalled the drivers (181.22) and let windows install the latest drivers (178.13 I think)
after I fixed that, the next morning when I turned it on I got nothing at all except a blank screen with spinning fans and some lights. I look and the power and reset buttons are flashing at me. I messed around with things it came back on, but no idea what I did to get it to come on.
any help would be greatly appreciated.
-=Mark=-
AI Overclock tuner: Manual
CPU Ratio Setting: 8.5
FSB Strap to North Bridge: 400
FSB Frequency: 500
PCI-E Frequency: 100
DRAM Frequency: 1000
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 55
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Read Training: Disabled
AI Clock Twister: Light
AI Transaction Booster: Manual
Common Performance Auto
CPU Voltage: 1.33125 bios 1.320 cpu-z
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.56
FSB Termination Voltage: 1.30 (ive tried from 1.20 til 1.30)
DRAM Voltage: 2.10v
NB Voltage: 1.36v
NB GTL Reference: AUTO
SBridge Voltage: 1.1
PCIE SATA Voltage: 1.6
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : Normal
NB Clock Skew : Normal
Advance CPU Settings
CPU VID: Disabled
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
i cant get this thing to get stable!!!! small fft's do just fine and blend fails in 1024k! any another suggestions?
With 1702 BIOS I need about 0.4-0.6 less voltage on RAM than with 1201, anyone tested real values?
ah crap sorry, i meant 1.26 for the vNB. i was tired lol. i set pl to 10 and switched the skews to auto. it just passed 896k so im hopeful, will report back later
computer crashed midway through 768k :S, that was with .630 nb gtl
Is that with multi 8 or still on 8.5 ?
i have just a simple and short question:
is there any way to read the PWM temps on this board?
i'm in the process of building a NEW WC system and hve to decide if i stay with the stock pipe, go for some enzotech pwm coolers + NB waterblock or put the whole board under water (Q9650)
Hi my names Nik, I have been reading this thread for a few days as I'm having trouble getting stability at 4.25Ghz. I can pass 20 runs of LinX and Orthos small fft's no probs but large and blend just seem to bomb out after a few mins (5-8). I was hoping that one of you more experienced wolfdale oc'ers might be able to point me in the right direction. Thanx in advance
ASUS P5Q Premium Template :
JumperFree Configuration Settings
AI Overclock tuner: MANUAL
FSB Frequency: 500
PCI-E Frequency: 101
DRAM Timing Control: MANUAL
1st Information :
CAS# Latency: 5
DRAM RAS# Activate to Precharge: 18
2nd Information :
3rd Information :
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
Common Performance Level [10]
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.450
CPU PLL Voltage: 1.58
FSB Termination Voltage: 1.46
DRAM Voltage: 2.00
NB Voltage: 1.40
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: ENABLED
CPU Margin Enhancement : Performance Mode
have E8600 batch Q820A747 Asus P5Q DELUXE bios 1702
Manual
Cpu ratio setting 10.0 Fsb frequency 399 Pci and frequency 100 Fsb strap car Dram frequency ddr2 1063mhz Cpu voltj 1.24375 (bios) Cpu gtl 0,630 Cpu gtl 0,630 Cpu pll 1.60 Fsb terminator car Dram volt 2.1volt Nb volt 1.40 Cpu clock skew delay 100ps Nb clok skew delay 200ps Cpu margin enchancement optimized
24/7 that I can raise or to go down to improve my oc =?
Ventilador Big Tyfon
just got Q9550s (E0 stepping with 65W thermal specification)
http://img24.imageshack.us/img24/5783/51502960.th.gif
Asus P5Q Deluxe mBios 1702
Intel Q9550s @ 4ghz
4 x 2gb Transcend AxeRam 1066+ (default 2.0v)
I need some suggestion....this is pritty stable but it happen that one specific core fail in prime after 2+h (i ran prime few times)
I dont know what to change.
I tried to get stable with 3 x 2gb but no way. Simply P5Q dlx cant get stable with 3 slots, or a least specialy with this mem type. With 2 sticks work well, with 4 sticks works without raising NB and VTT voltages
With 3 sticks i tried various diferent voltages on NB and VTT (up to 1.4v) but no sucsses
On other Pc is Maximus II Forumula wich works with 3 sticks of same mem without problems
FSB Strap to North Bridge: 333
FSB Frequency: 471
DRAM Frequency: 1132mhz
1st Information :
CAS# Latency: 5
Row Refresh Cycle Time: AUTO
2nd Information :
3rd Information :
Common Performance [08]
CPU Voltage: 1.40625
CPU PLL Voltage: 1.60
DRAM Voltage: 2.02v
NB Voltage: 1.36v
SBridge Voltage: 1.10
PCIE SATA Voltage: 1.50
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
CPU VID: Disabled
You can't get C4 stable ?
http://users.telenet.be/OAP2/signature.jpg
hi Leeghoofd
533 FSB you bios settings please post :up:
E8500 ,OCZ 1066 Repaer 4Gb HPC , bios 1702 P5Q-deluxe
My Mobo 533FSB*8.0 =4260Mhz VDrop Cpu
517*8.5 Stabilty
520*8.5 low stability armed assaulth game problem
533*8.0 my cpu crayz
510*8.5 full auto bios settings vcore 1.41V stability
6cm 4 fans my chipset and mosfet cooler
my setting 533FSB and not stbility
CPU Ratio Setting: 8.0
FSB Frequency: 533
DRAM Frequency: 1066
1st Information :
CAS# Latency: 5
2nd Information :
3rd Information :
MEM. OC Charger: auto
AI Transaction Booster: Manual :auto
CPU Voltage: 1.40 -1.41
FSB Termination Voltage: 1.26 -1.30
DRAM Voltage: Auto
NB Voltage: 1.28 -1.32
SBridge Voltage: auto
PCIE SATA Voltage:auto
CPU Clock Skew : auto
NB Clock Skew : auto
Aoptimised
CPU VID: Disabled
okey my cpu 4450 limit
high FSB an low cpu mhz
550FSB
my setting 550FSB dont stability 550 FSB 7/24 bad ??:shrug:
FSB Frequency: 550
DRAM Frequency: 1100 my ram OCZ 2*2048 OCZ 1066 RepearHPC
DRAM Timing Control: Auto
CPU Voltage: 1.40 -1.42
FSB Termination Voltage: 1.30 -1.34
DRAM Voltage: 2.10 -2.16
NB Voltage: 1.32 -1.40
optimised
CPU VID: Disabled
my bios settings bad ? ,Thank you helping me
:shrug:
bad english soryy
Hi guys, could anyone tell me the difference between Optimized/Performance/Compatible modes and when to use them?
For higher FSB about ~460 do I need to be using Performance mode?
I am having an extremely hard time getting above 9x462FSB stable in OCCT Ram test no matter what PL or Ram frequency or vcore and I have tried up to 1.42NB/1.40VTT. I can boot into windows at 8x500FSB or 9x470 and run small ftt's all day but when I try to run the 2hr OCCT RAM test I get bsod or freeze ups. Thanks
