I think ECC RAM is supported by this board.
http://www.asus.com/products.aspx?mo...11&l3=572&l4=0
says support :)
ecc, non ecc and unbuffered. really the best place to ask would be asus themselves... but good luck getting a timely answer.
*back to work on the ram, trying to get even close to the same bandwidth i had before*
Check the ram support:
Are you speaking in slang as in Bad is "good" or is it realy bad as in no good? And the runner, is a "good" runner or one to "run from"? JUst wanna make sure.
Yes, I am and have been since new, and so far so good, a bit more stable on overclocks.
YES, this mobo suports ECC but ECC RAM will not overclock like the ones most of us are using. Also, I was wondering, since Rampage and most X48 do not support, how does this effect the RF hack on MF? is ECC blanked out now?
beat you to it :p:
asus says they support ecc w/ the rampage. unless there is other published information saying otherwise?
http://www.asus.com/products.aspx?mo...11&l3=640&l4=0
*twice now!* :p::p:
just bought the asus formula a low end cpu watercooling system- good and silent though and an E3110
im pretty stuck here at 4.1 ghz , i can go higher but cpu seems to require a lot of voltage, and my siberian tiger really cant keep up with more....i can do orthos with temps below 65 now....but somehow i think it might be some motherboard settings i miss..most of them are at auto still..the pll and stuff really confuses me a lot, RAM isnt an issue at the moment, if i can get 500 fsb i will be happy.....
im giving the cpu about 1.45v which i consider a bit too high for the freq....i had no problems reaching 430 but above that the instability kicked in... i have adjusted nb and sb voltage and ram voltage....but i hope some of u out there can help me with some settigns that might push the cpu/board the last 50 fsb....on the other side it might just be the cpu, that is unlucky....some bios settings with others with a E8400/E3110 or like that would be helpful ...and yes, i have problems with raid in win xp pro as well as some ppl have in vista.....
Anand says the Rampage is non-ECC but on various sites selling it they say it is ECC and the asus website doesn't mention either...blah
it says it right on the page. i linked
4 x DIMM, Max. 8 GB, DDR2 1200*/1066/800/667 ECC,Non-ECC,Un-buffered Memory
they definitely could have made it easier to see... or used proper punctuation. looks like ecc is part of 667. but given your information, i would call asus. $250 is too much money to spend for something that "might" work.
http://www.station-drivers.com/page/intel%20raid.htm
there is version 8.0.0.1039 which is whql but non-official.. been good so far in vista x64
Originally Posted by Grnfinger
Potential n00b question here
Is anyone using the latest Matrix drivers from Intel??
RAID/AHCI Software - Intel® Matrix Storage Manager (5615KB) 7.8.0.1012 11/9/2007
I'm using the original shipping version atm 7.5.0.1017, wonder who if any were using the latest and if there is any benifit to upgrading, or should I not fix what is not broken??
I have tried almost all the settings posted and still have a BSOD 0x00000124 when priming - prime doesnt fail - it just bluescreens
Has anyone got a solution to this error - or should i just do Another fresh load of windows? [i had this problem with my old board also]
Anyone has the DET RAM f****** problem ? :bsod:
With my old OCZ Reapers 9200 I had some problems with DET RAM but managed to get them working @ 1128MHz with 2.3v and a lot of vNB and VFSB :(
Now with my new Corsair Dominator 8500C5DF 2x2GB I can only boot without the DET RAM "lock" at 800MHz :(
With no CPU OC and @ 5-5-5-15 - 1066MHz - 2.1v that are the default values for this sticks my Rampage refuses to boot, displaying DET RAM on the LCD.
Used also tRFC=55, vNB=1.50, vFSB=1.40 and no luck.
I'm becoming very pissed off with this board.
I've come from a P5K-E that run's 100% stable my Q6600 G0 @ 3600MHz and 2x1GB OCZ Reaper 9200 @ 1128MHz with only the vCore and Vmem changed !
Now for me to boot with the Rampage I've got to give more vCore to get the 3600MHz and I get this DET RAM sh*t :mad:
I know that the Rampage has a lot off settings to tune .... I know all that, but even when I was with the Reaper's and all tuned up @ 1128MHz (ex: PL:6) I got less or equal Everest Memory Benchmarks than with the P5K-E !!!
I really don't think that the ROG boards deserves the money that ASUS sells them. :down:
For me 1066 on the mem should be a walk in the park in current times , but it seems that the actual x38/x48 boards are very picky with the mems.
Any sugestions for the DET RAM problem ?
I'm usually all about cpu frequency but I'm very happy with this...
Next, I'll be playing with ram tweaks and see if I can maintain stability. NB is at 1.60v (everest), VFSB is 1.394v. I'll try to tweak these down a little bit.
Hi guys, I've finally got my tracers back from Crucial a few days ago.And I must say these feel and behave a lot better than my original red ones (these are double sided aswell). Anyway I got a 3.6 OC quite easy (stable and OCCT),I did manage to get up to 3.8 and 3.9, however it wasn't stable. Now I dont want to keep messing arround with it too much as this is my work machine aswell, and I dont wont to corrupt the OS. So I'm looking for your help to get me up to 3.8 or 3.9. My temps are 35c idle and 60-64 stress/load @ 3.6 and almost identical at 3.9. These are my settings.
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : 9
- Ratio CMOS Setting :
FSB Frequency : 400
FSB Strap to North Bridge :400
PCI-E Frequency: 100
DRAM Frequency: DDR2-800
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 4
RAS# to CAS# Delay : 4
RAS# Precharge : 4
RAS# ActivateTime : 12
RAS# to RAS# Delay : auto
Row Refresh Cycle Time : auto
Write Recovery Time : auto
Read to Precharge Time : auto
Read to Write Delay (S/D) : auto
Write to Read Delay (S) : auto
Write to Read Delay (D) : auto
Read to Read Delay (S) : auto
Read to Read Delay (D) : auto
Write to Write Delay (S) : auto
Write to Write Delay (D) : auto
DRAM Static Read Control: disabled
Ai Clock Twister : auto
Transaction Booster : disabled
Relax Level : 0
CPU Voltage : 1.44375
CPU PLL Voltage : 1.56
North Bridge Voltage : 1.51
DRAM Voltage : 2.08
FSB Termination Voltage : 1.40
South Bridge Voltage : 1.150
Loadline Calibration : enabled
CPU GTL Reference : .63x
North Bridge GTL Reference : .67x
DDR2 Channel A REF Voltage : auto
DDR2 Channel B REF Voltage : auto
DDR2 Controller REF Voltage : auto
SB 1.5V Voltage : 1.55
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : disabled
Advanced CPU Configuration
CPU Ratio Control : Manual
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Disabled
i flashed rampage bios 0401 and now i cant boot any oc even with old bios lcd poster says det ram if try oc. before this i get 450mhz x9.5 4.3ghz @1.32 vcore. i have tryed every thing gtl, voltages, ram settings, another memory sets and mother board etc etc no boot even little ocQuote:
Thanks for the link :up:
The Det Dram hang is a result of memory timing and wrong TRD/PL setting
for 1066 you will need a PL of 7 to boot, 6 is to strong of a setting, there is a table that can help when setting this
http://i237.photobucket.com/albums/f...mory_table.png
Anandtech goes into it rather well and there is a blurb about it on OCZ
here are the links
OCZ TRD calculator ---> http://www.ocztechnologyforum.com/fo...ad.php?t=36361
Anandtech Article-----> http://www.anandtech.com/mb/showdoc.aspx?i=3208&p=1
Once you understand this simple math your DET DRAM hang will be a thing of the past.
I have a E8400 4.4GHz setting that has very decent bandwidth, it might help you some....
http://i237.photobucket.com/albums/f...table_4400.jpg
Extreme Tweaker
- Ratio CMOS Setting : 9
FSB Frequency : 489
PCI-E Frequency: 110
DRAM Frequency: DDR2-1174
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 30
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Write to PRE Delay : 14
Read to PRE Delay : 5
PRE to PRE Delay : 1
ALL PRE to ACT Delay : 5
ALL PRE to REF Delay : 5
DRAM Static Read Control: Enabled
Ai Clock Twister : Stronger
Transaction Booster : Manual
Common Performance Level [7]
Pull-In of CHA PH1 Disabled
Pull-In of CHA PH2 Disabled
Pull-In of CHA PH3 Disabled
Pull-In of CHA PH4 Disabled
Pull-In of CHA PH5 Disabled
Pull-In of CHB PH1 Disabled
Pull-In of CHB PH2 Disabled
Pull-In of CHB PH3 Disabled
Pull-In of CHB PH4 Disabled
Pull-In of CHB PH5 Disabled
CPU Voltage : 1.475
CPU PLL Voltage : 1.50
North Bridge Voltage : 1.53
DRAM Voltage : 2.12
South Bridge Voltage : 1.050
CPU GTL Reference : 0.63X
North Bridge GTL Reference : 0.67X
DDR2 Controller REF Voltage : DDR2-REFF
Hey grnfinger, here are my latest stable settings. (i'm the guy who couldn't get to 3.8 stable). these are the settings I'm using atm for 3.6 with rampage bios 0401 on a mf non-se -
Extreme Tweaker
OC From CPU Level Up : Auto
-Ratio CMOS Setting : 9
FSB Frequency : 400
FSB Strap to North Bridge : 400
DRAM Frequency: 1066
DRAM Timing Control: Auto
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
Ai Clock Twister : stronger (don't remember exactly)
Transaction Booster : auto
-Relax Level 0
CPU Voltage : 1.381250
CPU PLL Voltage : 1.54
North Bridge Voltage : 1.49
DRAM Voltage : 2.00
FSB Termination Voltage : 1.26
CPU GTL Reference : 0.63x
North Bridge GTL Reference : 0.67x
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
SB 1.5V Voltage : 1.50
CPU LED Selection : CPU Volt
Voltiminder LED : Disabled
based on these settings, can you suggest what I might need to hit 3.8?
excuse me isn't CPU Voltage : 1.475 too much for a E8400?? Can I keep it for daily or what u suggest? now i'm at 480*8 at 1.3500V at 47°in full orthos (4hours), think I've to give more than 1.4Vcore for reaching 4Ghz, thanks
