Originally Posted by
xaver
i've tried BLEND test, and it run it for 2h without problems. Cpu temps are max 65-66'c, NB is not very hot, memory is hot but same memory run on 2.1 and was much hotter, and i have found that it runs fine with lower voltage, so now is 2.00-2.02v
As i said, my problem is not with running under load, but runnng at idle.
It's not clear to me why is that happening ... tried everything but sudden crashes occures form time to time, even when noone uses a computer.
I heard that "loadline calibration" option can produce peaks and drops in voltages so i guess i may be the source of my problem
