You are running all of that with a single MCP 355?
http://dl.dropbox.com/u/20116032/Pro...0/DSC_9882.JPG
http://dl.dropbox.com/u/20116032/Pro...0/DSC_9873.JPG
http://dl.dropbox.com/u/20116032/Pro...0/DSC_9883.JPG
http://dl.dropbox.com/u/20116032/Pro...0/DSC_9895.JPG
Rads:
Magicool Slim 360
ThermoChill TA120.3
FeserXchanger 360
Blocks:
EK SupremeHF Full-Ni
D5noz
EK FC7970
EK-VGA Supreme HF Acetal/Ni
Pumps:
2x Swiftech MCP-35X
Fans:
12x GentleTyphoon 1850rpm
3x Feser Tribwerck TK-22
Tube:
1/2" ID
WCRF aren't you missing the last SLI bridge on the 4th GC?
In my Lian Li PC-P80 Armorsuit :)
http://nsm05.casimages.com/img/2012/...3849772387.jpg
Yes, I've had more complex loops running off one ddc 3.2 :)
They are the satin copper DD version but I just sprayed some DupliColor metallic silver paint. Looks decent but its a lot cheaper than spending $330 to plate them in nickel. I thought about getting new blocks but its hard to find used 480s, especially four of them, and the new ones are still selling for their retail price. I get one of the DD blocks from MicroCenter's clearance deal.
itīs time to clean up once again ... a new rad is on itīs way and the Mips Iceforce is coming back - before another block arrives
http://www.abload.de/img/120501004n8uhq.jpg
riwar your black and orange is exceptional!
My current bench build....
http://i.imgur.com/G6flc.jpg
http://i.imgur.com/TG5H7.jpg
Whats coming next....
http://i.imgur.com/xhs1i.jpg
@B Negative: In the last picture, I assume that's a 10mm pipe in 10mm push-in fittings? Great idea, because they're a lot cheaper than the BP crystal link connectors! I'll definitely look into it!
its an interesting look at the changing face of watercooling people using more of these nickel plated copper pipe runs.
the new murderbox made it look just so good.
Yes,I oc I5 2500K@5.0GHz Vcore 1.385
http://i300.photobucket.com/albums/n...elpiero/50.jpg
[attach=config]126339
my rad box
Hi guys!
My first post here :) Sorry for bad quality of picture, but i have available only phone atm.
Attachment 126422
Intel Core i7 3960x overclocked to 5GHz, Corsair memory Dominator GT 2400MHz 8GB, Asus GTX590 (waiting for GTX690 :) ), Corsair Force GT 120GB SSD ...
Water cooling setup: EK Supreme LTX, EK CoolStream RAD XT 360, EK DCP 2.2 Pump, EK Multioption RES X2 250, nickel fittings, red coolant, some Masterkleer tubing ... All setup is going to by replace piece by piece after GTX690 comes to the house ...
@sate i love the colored tubing weave!
MaverickCZ: your pump->CPU tube is way too long, and your radiator->reservoir return line too short or not routed properly (you'll have a kink in no time there) - i'd consider using one of the top ports instead...
BEGD: Ahh that sexy X500, do you have a link so we can see more of your build ? i'm curious to see how you fitted everything in there...
thats certainally creative. how does it perform?
