Yes temps are fine. I don't know why Orthos has decided to fail after 9 hours but to be honest I'd just keep your system as it is. Nothing you do from day-to-day will stress it like that, or at least it's very unlikely. :)
hello...I want to ask you, how much is overclocking potential on E8400 with batch number Q818A210, it is revision C0...thanks
It's impossible to base overclocking potential on batch number alone - every batch has good and bad chips; some batches have more good than bad chips and they are misleadingly called "good" batches. Most E8400s do 4GHz quite easily, however the C0 chips tend to get a lot hotter than the E0 chips. :up:
i wanted to go over 4.0 though, as you can see the memories can go at least 500 i havent tried more, what can i do to go up to 4.2 then?
4200/9 = 467, so that should be the speed of your FSB and memory for 4.2GHz. You will need more CPU volts but since you already have 500FSB stable you shouldn't need to change much else.
These are my settings at the moment...
Ai Overclock Tuner ................. [Manual]
CPU Ratio Setting .................. [9]
FSB Frequency ...................... [466]
PCIE Frequency ..................... [100]
FSB Strap to North Bridge .......... [Auto]
DRAM Frequency ..................... [933]
DRAM Clock Skew on Channel A1 ...... [Auto]
DRAM Clock Skew on Channel A2 ...... [Auto]
DRAM Clock Skew on Channel B1 ...... [Auto]
DRAM Clock Skew on Channel B2 ...... [Auto]
DRAM Timing Control: Manual
1st
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : Auto
Row Refresh Cycle Time : Auto
Write Recovery Time : Auto
Read to Precharge Time : Auto
2nd
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
3rd
Write to Pre Delay : Auto
Reado to Pre Delay : Auto
Pre to Pre Delay : Auto
All Pre to Act Delay : Auto
All Pre to Ref Delay : Auto
DRAM Static Read Control ........... [Disabled]
DRAM Read Training ................. [Disabled]
MEM. OC Charger .................... [Enable]
Ai Clock Twister ................... [Auto]
Ai Transaction Booster ............. [Auto]
____________________________________
CPU Voltage ........................ [1.35]
CPU GTL Voltage Reference (0/2) .... [Auto]
CPU GTL Voltage Reference (1/3) .... [Auto]
CPU PLL Voltage .................... [1.54]
FSB Termination Voltage............. [1.30]
DRAM Voltage ....................... [1.98]
NB Voltage ......................... [1.26]
NB GTL Reference ................... [Auto]
SB Voltage ......................... [Auto]
PCIE SATA Voltage .................. [Auto]
Load-Line Calibration .............. [Enable]
CPU Spread Spectrum ................ [Disabled]
PCIE Spread Spectrum ............... [Disabled]
CPU Clock Skew ..................... [normal]
NB Clock Skew ...................... [normal]
CPU Margin Enhancement ............. [optimal Mode]
What do you think Lenny?
I ran IBT but after that i ran prime95 but computer just froze after 20min, then i tried to restart and when it got to windows it just restarted by it self... damn :( whats wrongs? what am i doing wrong here? do i need more volts anywhere? those are my latest settings but couldnt get it stable...
Here is mine
Batch# Q831A779
I will try to push it further, still learning about all of this so ill get there eventually.
I thought it wasn't too bad for a days effort :D
Its stable with Linpack/Prime95 etc etc. Can run for hours no problems
Thats what i wanted on mine but seems like im the only one getting problems getting there, if there were people here with a P5Q Deluxe and a 8400 that could give me a hand...
I will drop the vcore a little as i go, its stable as it gets for now.
I did attempt 4.5ghz, but keeps crashing on SuperPI 32M
So ill have to do some more reading i think and work that out.
Boots to windows no worries @ 4.5, just not stable but then i might need more volts still. Something for another day
Actually under load its 1.296vcore - seems it wasnt loaded enough when i took the screen dump :)
I tried these settings:
CPU Ratio Setting .................. [8,5]
FSB Frequency ...................... [495]
DRAM Frequency ..................... [990]
1st
CAS# Latency : 5
RAS# to CAS# Delay : 6
RAS# Precharge : 6
RAS# ActivateTime : 18
2nd
3rd
CPU Voltage ........................ [1.37]
CPU PLL Voltage .................... [1.56]
NB Voltage ......................... [1.30]
CPU Clock Skew ..................... [Auto]
NB Clock Skew ...................... [Auto]
CPU Margin Enhancement ............. [Optimal Mode]
And i got this...
http://img300.imageshack.us/img300/9179/45213872hz6.jpg
only ran 6min...
Godmyster, why the 8.5 multi? You'll need more vcore the lower the multi. I'm really lucky to have a chip that can prime at 1.35 vcore 4.41GHz, but that's 9.5 multi. Overclocking is no easy task, so don't expect 4.2GHz to fall into your lap if you're not experienced. :)
This is my results. I think it's perfect for C0 :clap:
This is what i tried on my last run...
http://img383.imageshack.us/img383/8861/99550072rk2.jpg
i want to get to 4.2 at least!!! :confused: :confused:
How do you know when to change the CPU and NB clock skews?
I know at first when..I got mine..I went straight to 4.5ghz to see if would do it and it did but was'nt stable and the volts was high...It's kinda fun to find out where you can be stable at with certain amount of volts you need to the Ghz speed right now I'm at 1.296vcore under load at 4.104ghz..and testing
how far..I can drop the vcore volts to be stable at 4.1ghz less volts less heat
also..
Ye i was wondering if it was a matter of giving it more volts to get it stable or not, something i didnt have time to do that day.
I just let my mobo recover from the crash and just backed it off again.
Must admit the recover of this mobo is great without having to hit reset buttons etc etc (been a few years, so tech obviously has come a long way)
I reckon i can maybe drop it 1-3 points (lots of options in my BIOS), maybe even 4... but testing that will take a while with each drop.
I will add more once i go faster, or drop... or both!
I'm fairly sure the memory i have is A-OK, i could probably even drop those timings a little as well, although what gains ill get remain to be seen
cranked this out yesterday
http://i48.photobucket.com/albums/f2...table45ghz.jpg
crap vid cpu though 1.25 but its low volts high oc so whatever.
batch q824a540
E8400 Q832A446 : stable at 4.3 with 1.22 under load, and boot Windows at 5 with 1.37...in progress
