The tubing is UV reactive, right ? It looks a bit blue.
I like the Backplate !
radiators in parallel?
Yep! but I don't like the UV color so next time I will get non UV tubing or just sleeve it with techflex sleeving ;).
About the backplate, this is the old one, the new one is going to be like that:
http://img31.imageshack.us/img31/109...oloroutput.png
Nice ! I made several backplates some years ago - handmade via dremel tool :)
http://www.abload.de/img/redtest5qfksw.jpg
http://www.abload.de/img/129-2968_imgxdjt4.jpg
http://www.abload.de/img/img_0330aqk5a.jpg
http://youtu.be/P3oo4DrOqp8
first rig Post for me sorry if it sounds like an add :(
i hope you all like.
same name for bf3 Faithlesssoul gamer tag if any one plays :)
Nice rig Faithless! I sent you a bf3 friend request.
http://file.si/pthumbs/large/235591/DSC_0282.JPG http://file.si/pthumbs/large/235592/DSC_0283.JPG http://file.si/pthumbs/large/235593/DSC_0284.JPG http://file.si/pthumbs/large/235594/DSC_0285.JPG http://file.si/pthumbs/large/235595/DSC_0286.JPG
Rig I built for a buddy of mine. 2D calculations + some modern games. Funny thing, this CPU does 4.9GHz with same voltage with just 16GB RAM, with 32GB the limit is 4.7GHz.
Hardware:
Ci7 2600K @ 4.7GHz
EVGA P67 FTW
4x8GB GeIL Evo Corsa DDR3-1333 C9 (32GB total)
MSI Radeon HD 7950 @ 950/1500MHz (barely clocked)
Corsair TX 650W
1x WD Caviar Blue 1GB HDD
1x Adata S510 120GB SSD
Cooler Master HAF-932 Advanced
Water cooling:
- EK-Supreme HF - EN (Nickel) /w nickel plated mounting plate
- EK-FC7950 - EN (Nickel) + EK-FC7950 Backplate
- EK-RAM CoolStream XT 360 + 3x Scythe GentleTyphoon AP-14 (1450rpm)
- Tygon Norprene 10/13mm cevi + EK-PSC 10mm + one EK adaptor 90°
- Laing D5 vario + EK-D5 X-TOP
- EK-BAY SINGLE Reservoir - Acetal
And another really nice picture.
More here: https://www.facebook.com/media/set/?...2842090&type=1
Kind Regards
a nice refreshing view after countless red and black builds.
gorgeous build there LD:clap:
Does this count as liquid cooling?
AMD A8-3850 @ 3.2 ghz
graphics core @ 800 mhz
4 gigs 1866 ram
intel SSD drive connected via pci-x adapter
450 watt power supply
motherboard and power supply are attached to a custom acrilyic tray.
I made custom connetions from the board to the lid so there isnt any loose wires going from the lid to the tank.
the whole computer can be lifted out by the acrylic tray so it's not to hard to work on or upgrade :)
http://img832.imageshack.us/img832/6601/079dl.jpg
http://img812.imageshack.us/img812/1576/077l.jpg
http://img15.imageshack.us/img15/4632/056es.jpg
http://img837.imageshack.us/img837/7258/055or.jpg
http://img850.imageshack.us/img850/9537/054mg.jpg
http://img35.imageshack.us/img35/7536/053mx.jpg
http://img718.imageshack.us/img718/4682/049nn.jpg
http://img854.imageshack.us/img854/6752/051ukd.jpg
http://img716.imageshack.us/img716/2098/078ea.jpg
http://youtu.be/5Ef-bFhRLPE
@ Ale10 : Absolutely Amazing
P.S. : Forza Juve ! :D
:yawn:Another "Rossoneri" themed Obsidian 800D build
(i know, this color scheme tends to outnumber the classic blue builds we used to see all over the place a while back...but what can you do, almost everybody seems to wants one!):yawn:
http://i7.photobucket.com/albums/y27...lackerXL-A.jpg
The case got a brand new middle floor plate with fillports to connect the loop to the lower compartment
(1 triple XSPC on the top and 1 dual at the bottom)
http://i7.photobucket.com/albums/y27...lackerXL-C.jpg
White smd led stripes hidden in black powder coated aluminum canopies light the interior
(adjustable via the lamptron FC-2 fan controller in the front)
http://i7.photobucket.com/albums/y27...lackerXL-B.jpg
Phobya fans, red coolant and a few red details to light up the black interior
http://i7.photobucket.com/albums/y27...lackerXL-D.jpg
"Aluminum tube clamps"
In other words, a good way to bring back those barbed fittings out of the closet!
Ale10, what res/pump combo is that?
must be BitsPower DDC Mini Tank
Thanks josk1, I see that the bp mini tank serves as both res and pump top for the ddc. Am I correct?
That's not flow meter (which meters/measures flow giving value), but flow indicator, which by turning can only tell if water is flowing or not (imho worthless money spending for it & two corresponding fittings for almost no function but bling).
