I haven't seen it.... what is the 4 pins conector used for ?? It is no longer used as PCIe SLI extra power?
Originally Posted by Enz0
Nah, it really works, cuz when you play 4 dimms tccd DDR600, you will know what's the difference,;)
do you mean when playing with 4X DDR600, I have to disable interleaving?Quote:
Originally Posted by Onepagebook
When you use 4 dimms is when bank interleaving does increase to 4-ways, so it makes a bigger difference if you enable/disable it.
So OPB means that you will notice a bigger difference if you use 4 dimms.
My X2 gone to rma and the store borrow me a venice 3200,and with a Ultra D and later with a Asus AN328 (trade for a expert fortunately)the temperatures were 38 on load and now with the expert they drop 10 degrees,so becarefull because wen you read 38 it´s probably 48/47,with my 148 cab2e i'm at 300X10 but my gskil 4400Fcl refuses to work at 2.5-4-3-6.Don't now if it´s the memory controller of the cpu or the timmings .Any hints please?
my Expert shows 38c too when I bench with superpi32M @1.55+109.6% (differ with my ultra-d shows 42c @same volt).Quote:
Originally Posted by bullit
And my Ballistix cannot run @stock speed and timing, but with my ultra-d can,
is it BIOS problem?
I've just mounted this motherboard... I have 1 problem.
It can't run at >190Mhz with 4x512MB BH5 2-2-2 2T (rest of timings at AUTO)... it doesn't boot into windows and memtest goes crazy (shows ASCI codes), even with 3V.
With 2 modules runs very fine (250 2-2-2 1T no problems).
I've tried with the default bios and with the newest one (7/12).
Do you have any idea? :stick: :(
PD: It doesn't have this cut: http://www.techpowerup.com/reviews/D...mages/cut1.jpg :)
And its Rev. AA0
Edit: Seems that needs A LOT of vdimm (compared to my SLI-D) to run 4x512MB BH5 fine.
When I was using my old SLI-D, I could notice the difference with 2 dimms.Quote:
Many people use 2 dimms, so, it would be nice if DRAM BANK Interleave works with 2 dimms.
Just read the hole thread.
Has anyone been able to do 4X512 TCCD anyware near DDR 600 2T
I have searched the everyware with no luck I am on my second Expert Board and hade absolutely no luck:( each pair of my 4800 does 600+ on my Nf3 Ultra but thease board top at DDR 500 with the 4 sticks.
I Would appreciate any help
Thanks!
anyone?
dear friend, which bios that has fixed temp error reading?
Hi Guys,
which Bios do u use finally for BH/UTT ?
thx for a little hint ;)
cu
and which dram drive strenth do you recommend?
I have serious problems with my bh5/utt ram and cant hit 260Mhz like on my sli-d.
any hints?
same to me. I tried every setting like 8/4, 8/3, etc...Quote:
Originally Posted by C3
cu
I am using 5/3 with the latest 07/12 bios. Perhaps you can give it a try. It was the best for my winbond utt ram.
thks mate, i will try this ;)
cu
Hi,
after testing a couple of hours i found out that my memctrl dont like my good old BH5 sticks. I switched over to my Mushkin´s and used 5/3 as Ozan recommend.
Here my results on the Expert with modded Vapo.
SPI
http://www.xtremesystems.org/forums/...1&d=1139910491
01
http://www.xtremesystems.org/forums/...1&d=1139910682
cu
