Hahah man you killing me ;) I'm trying to get my stable at 2,8ghz now :) Will work my way up there even if it takes me a month :D
On a Hyper6 ;) (I'm sure I've posted these pics beforem but maybe not in this thread :p: )
http://img281.echo.cx/img281/4245/10x290spi32m0fb.jpg
Damn that's nice!
Now I'll talk to OPB and ask for you adress and then you will wake up tomorrow without your Venice :) I might take the heatsink aslo hehe.
Hell, if you can make it halfway around the world in less than one day's notice just to take a cpu, you would have definately earned in :p:Quote:
Originally Posted by NiCKE^
No I will send my secret agent, 0064 :D
NiCKE^ what is your cooling and stable oc for now ?
I have same apqw 0484 with stock hs and cant stabilize it 9x300 @ 1.5v-1.65v
It's like a wall...Am I missing something ?? running dfi ultraD 414-1
0484 is the batch number? 9x300 @ 1.45 24/7 SLK948U+Vantec Tornado @ 5v.
yes
Well I dont think it's a T° issue regarding my bad results but I'm waiting for a xp90c.
My 3200 0517BPEW doesn't oc well too !
I'm so lucky...
Gotta be some explaination about it. But if you uses the stock HSF you might should wait before clocking ;)
I hope
maybe my 20 pins 350w enermax
Can be the reason why. If you don't get it to work just add me on icq or msn and I will try to help out.
Thanks ;)
I added you in my msn contacts
you guys just doing superpi....which means nada.....
try S&M 100% load and long .....or prime small with 3dmark2001 all in once :D
Looking damn good Overcrash!
Vroom I didn't get any message about it, are sure you added?
Originally Posted by TEDY
:slapass:
if u can play games stably or do anything else perfectly fine, forget prime :p: :p: :p: :p:
Hehe ;) SPI 1M is fun :)
Nada is all relative ;) And yeah, staring at a computer for 24 hours watching prime 95 run isn't exactly what I'd consider exciting.... :p:Quote:
Absolutely. So many other things you can do in the meantime. :)
Looks like my 3000+ 0517BPEW is getting better and better.
Had it running CPU Burn-in last night at 2700, 1.488V.
Has been running Prime for 5 1/2 hours now at 2755Mhz, 1.488V.
Leaving CPU Burn-in run all night now at the same speed.
2.8Ghz should be possible, more would be even better.
It's funny to have Vapo's front+rear fans at 100% and sleep in same room to get 24h shot of Prime :hehe:
Not funny, more like windy :DQuote:
Originally Posted by Dani
3Ghz in water :banana: just with 310 BIOS i'm verry happy :banana: :banana: :banana:
http://wowgame.free.fr/3000+%20939/L...able+graph.jpg
http://wowgame.free.fr/3000+%20939/L...7-CPUGraph.gif
http://wowgame.free.fr/3000+%20939/L...7-VoltCore.gif
now testing prime :D
:toast:Quote:
Originally Posted by overcrash86
I got my 3200+ SP8M stable 3103MHz 1.5V :)
good :) with phase change ?Quote:
i'vent seen any other 3Ghz watercooled was i first :confused: :banana:
Yes with Vapo, I think 3110MHz is the last stable SP8M with 1.5V
Ouh, got to sleep now..
BTW, dont know about WC WR :rolleyes:
I use only ZM7700CU, Vapo and CO2 :woot:
