You mean this diode indicated below ?
http://img382.imageshack.us/img382/1...odes9ki.th.jpg
This diode is a schottky diode IR1F and it is part of the VGPU regulator (the same component is also used for Vmem regulator, see the same foto).
Since you got considerable temperature increase with your setup temperature sensor MUST lie in that area.. but where ? There are not too many **unused** diodes nearby. There are two diodes sited near regulator (see foto above) and at least D505 is part of regulator. But how about D504, at least the position would be optimal (=near the hottest MOSFET's) ? This could be proofed by freezing D504 while observing temperature value
:rolleyes: (maybe I'll do it later)
