who can tell me what software Tweaks I can do to get a better score ??
week 46:
CBBHD0446SPAW
3000+ does 285*9 @ 1,5Vcore.
This is a friend from oc.dk "Palmen", my own (exactly the same) is still on my table :|
do any of you guys use memtest for stability testing or just plain prime 95?
:/ pretty much like any newer previous 3000 regardless of socket.Quote:
Originally Posted by TS_PHI_PERRY_78
although not at 1.5 :cool:
For a really cpu intensive test use : CPU stability test or CPU bUrn.. Both pretty demandingQuote:
Originally Posted by DevilsRejection
This is about all I can squeeze out of this chip on air I think. Still not bad though. The picture is fuzzy as i had to reduce it a little for the 200kb size limit on files.
Wow its finally letting me post, anyway picked up a 3000+ retail from monarch and an epox 9NDA3J from newegg, and I'm priming for over an hour now at 2.65 ghz 294.5*9 (adjusted down from 2.7 ghz using clockgen - thats why i get .5) :banana: :banana: I could get into windows at 2.85 ghz, and could adjust to over 2.9 ghz with clockgen all at 1.47 V according to CPU-Z
stepping info:
ADA3000DIK4BI
CBBHD 0447UPCW
I have the same week and stepping on my 3200+ max screenstable 2951Quote:
Originally Posted by socrilles
A64 Max Screen AIR
http://www.biwa.ne.jp/~yok/HIGH-CLOCK.htm
The first place is take by the same cpu as mine only with a High VcoreQuote:
Originally Posted by boblemagnifique
Hej, what is the highest voltage you can use using a BOX cooler?
my 3000+
V-CORE ORIGEM
http://img145.exs.cx/img145/8206/28ab.jpg
http://img70.exs.cx/img70/9087/30s13eh.jpg
UP to 2850 and v-core 1.5
If it aint to warm (50-55°C), you can use it up to 1.65-1.70v ;)
POFXXX 307MHz 2.5-3-3-x with 2x512?
what ram u using?
How high do you go with a BOX at 1.65?
A-Data 512Mb PC4500 DDR566 yep 2 ramQuote:
Originally Posted by Mrki
http://img135.exs.cx/img135/5120/255...339285v6rj.jpg
50 or 55 +/-. ar ?Quote:
Originally Posted by S!1v3rB@cK_Dk
http://img127.exs.cx/img127/5923/picture0698wv.jpg
Which volt at the memories did you use?
Gigabyte K8NS ultra (bios F7 roxxxxx :slobber: )
adata bh5 (3.4v only)
3200+ 0.09 Cbbhd 0447 tpew (1.4v)
Full AIR :)
http://www.membres.lycos.fr/boblemag...nie@365fsb.PNG
http://www.membres.lycos.fr/boblemag...nie@324fsb.PNG
http://www.membres.lycos.fr/boblemag...nie@316fsb.PNG
Originally Posted by POFXXX
now i understand ... thats 2T ;)
Or very very vad timnings.
i've read many pages of this thread but not all of it.
do the newer winchesters still suffer from the subzero bug? or is it motherboard related?
I'm runing 2.5ghz and i'm gettig 36sec on 1m on PI. No worries here I think all we got to do is tweak the timings on the memory but i'm running all stock settings except memory timing to 2.5-3-3-7 @ 270 HTT @ 9x. All on stock setting :)Quote:
Originally Posted by stelleg151
New record on PiFast:
Screenshot
PiFast: 43.31 Sec
Little confused here, could do with some help from you lot as a64 overclocking is new to me.
System is 100% stable at 3 x 300 htt x 6 ( remove cpu bottleneck ) see screenie below.
This is with ram set to 100 in bios ( 150 real ) but if i up ram to 133 ( 180 ish ? ) pc does'nt boot.
ram is ballixtic pc4000 and runs perfect at 10*250 fsb 2.5-4-4-10 @ stock volts. so i know the ram is good to 250 fsb.
have no idea at all where the cpu limit is, really difficult to find it's limit. ( what programs/tests are people using to test stability ?? ) the pc is used for gaming so need's to be 100% 3d stable always 24/7. ( heard about problems with prime95 so maybe 3dmark05 instead? )
cpu does 300 htt at stock volts no errors/problems ( is that normal or ? )
Is there anyway to get this situation with my current setup.
a64 3500
2x 512 ballistix
msi k8n neo2
1.5xx bios atm.
sata hd on sata port 3.
Id like to be running
the ram at 200 2-2-2-5 ( it does this already ) but the cpu at highest possible cpu speed.
so do i try to find a answer between ram deviders 133-166 and so on and htt speed and exactly how do the ram clock's relate to htt like when i set to 100 and run htt at 300 ram runs at 150.
Thank's in advance for any info a64 clocking is alot more stressful than nf2 mobile 2600 clocking lol that was really easy ( 2.8 ghz ).
Wish this was as easy :p
oh and not sure on cpu week number forgot to check before i stuck the waterblock on which i dont wanna take of again :P, but the cpu was bought 2 month's ago from overclockers.co.uk if anyone know's what sort of batch's they had back then, they've been outta stock for ages now on winnie 3500's.
