The links don't work! ;)
Originally Posted by GravediggA
Works fine here
Maybe bcs u have an gmail account and the most other users not?! :rolleyes:
Use www.imageshack.us, and all ppl can see it! :)
They work fine for you but send the rest of us to the Gmail login page.
G
okay, fixed ! !
what do you think ?
Really clean and good looking setup, but no comment about the cooling-components! :p: :D
wow nice water coolers cant wait til i get mij thermaltake bigwater
already have a thermaltake kandalf case
Do not get the TT BigWater. It's absolutely worthless.Quote:
Originally Posted by silence112
Then don't make i worse!!! :DQuote:
/Thomas
*shame* i'm dutch as well.... :p:Quote:
I guess he doesnt know the word *bigwater* is a really bad thing on XS :slap:
Well, here's my new rig and case :)
http://i3.photobucket.com/albums/y55...Z/AUT_0209.jpg
http://i3.photobucket.com/albums/y55...Z/AUT_0212.jpg
http://i3.photobucket.com/albums/y55...Z/AUT_0210.jpg
The loop is like this: Pump-radiator-CPU-pump. What do you guys think?
the system is too ordered but the radiators can't aspire air and your prestation diminish
sorry for my bad english :p:
hmm, what do you mean ? its bad ? is it something that I can do better ? and btw I MUST have two 90degrees bends there.
the position of radiator is too bad, put it up or out of caseQuote:
Originally Posted by LenniZ
No, its not space there
put it out of caseQuote:
nah, why is it so bad to have it in the bottom of the case? In my last pc with an acrylic case, I had it outside, and that sucks because its not good for LANpartying. Btw: I will put the wheels on the case so more air get to the radiator.
ok do like you believeQuote:
even if the tubing is a little longer, you can get it to bend slowly instead of making the water do this: :brick: (I could do that w/ no angles and not move anything else) Your system will thank you immensely. Get coolsleeves if you need them. You have a big case & space- USE it! :D
(Gotta be someone in teh case gallery w/ this combo, start from teh beginning, I bet you'll find it :hrhr: (Oh and the rest looks okay and getting rid of the bends will help especially given the pump size)
And sure you're gonna carry that behemoth to lan parties :rofl: (I've lifted one of those things, they're build like a tank and feel it)
As for Diablos, that is the why the case is designed that way so you CAN put the rad on teh bottom :D
Well he is using the nicely curved angles and not the eeeeevil L shaped ones, also he only uses 2 not a whole lot, so it's actually not that bad.
lol most everyone with stacker cases put the rad at the bottom
LolQuote:
Originally Posted by mad mikee
:banana: Yeah it is :banana::banana::banana::banana:ing heavy :fact:
Originally Posted by diablos
The bottom of his case (Stacker) has got a hole so that the air can be sucked from under it. There is also wheels on the case so its clear of the floor by 6cm.
There is no problems with having the radiator where he has it.
is that rad mounted to the case or just sitting there?
Most recent build :)
Specs:
Lian Li PC65 anodised
PCP&C 510 SLI
DFI Ultra-D
X2 4400+
7800GTX
2 x 1GB Crucial Ballistix Tracer PC4000 memory
2 x 74GB raptors
160GB 7200rpm Lacie external (back-up storage) drive
Audigy 2 ZS Gamer
2 x samsung DVD-rw
1 x floppy
Nexus fan controller
Matrix Orbital MX222
4 x 80mm blue coolermaster fans
2 x 120mm antec blue fans
thermochill 120.2 rad
RBX cpu block
Maze 4 gpu block plus OCZ ramsinks
Aquaxtreme 50Z pump
1/2" blue primoflex tubing
DangerDen fillport
EP-UK fan grills
Dell 2405FPW UltraSharp LCD monitor
Logitech Z-5500 5.1 speakers
Logic3 rumble gamepad
Logitech multimedia keyboard
Logitech MX510 mouse
Icemat II mousemat
Now its quite messy :( , it was cable free but I had to keep changing things over and became more and more frustrated. One day I will get round to do the cabling again.
