Manage to complete the update now. Thanks. Took me a while though.
So...I need your CFR secret!
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
I binned all of my CFR sticks and found two that will boot 3000C12 on the OC Formula, but not together. It will only boot with a single stick even though individually each stick is capable. I'm at a loss as to why they won't run together.
I think this may be the best I'm going to get out of this board with CFR; I had to use boot BCLK 100 and eventual 102.3 and manually key in RTL/IOL using an Asus guide. 32M fails immediately.
http://i.imgur.com/4IsBDbh.jpg
Guys no save to USB flashdrive the USER OC profiles on the Z87M OC formula ?
Anyone else find that the Etron USB 3.0 drivers for Windows 7 causes Windows to freeze on shutdown/restart?
board came with bent pin i fixed it, but i have no HDMI wich of course i care...with the things that this board do lol
here pic lets see i you guys find it now :)
http://i.imgur.com/fR40AxF.jpg
@Shiraniu: I give up trying 4 sticks at 3k mem freq. Hahaha. CPU is not up to it. It will boot to Windows and I can take screenshot and all, but 32M will fail at the 2nd loop.
I am trying to borrow a different brand of motherboard to try.
Sorry about using a different tool, but the Timing Configurator is not reading the memory speed properly.
http://valid.canardpc.com/3jngxb
http://i402.photobucket.com/albums/p...vexir/Run1.jpg
Strong board :up:
http://s9.postimg.org/ora7zgnun/ghb.png
This one looks bent.
http://minidriven.com/Z87mOCF/Pintest.jpg
Thanks. :D
It's probably fine. If it boots and everything works I don't think there is any problems. The pins on the Z87m OC Formula mb look more heavy duty than the ones on the gigabyte mother boards with the "Gold" tipped pins. Gold is good conductor but those pins are so delicate and with the pressure of the CPU its very easy to bend the pins a little.
@ Reefa,im sure Splave will let you know how the plate is,I also bought this and it is really good.I have a little SS danfose that I thinks only gets about -20 or so on cpu and I ran it on that plate on memory and had no problem getting -10-15 on my little SS.On my PSC that do 8-12-8-28-@1368 on air and had no problems running 7-11-7-26 @1333-1368 on the plate @ -10-15.I really think if you have a SS or even a Cascade the plate is a nice thing to have
Yeah, mine goes to -48 to -50c load on haswell low voltage 2c2t. The mems got to -40c inside the spreaders, the kit I was using did not seem to like cold XD 2720 8-12-8 only.
I timmed between the ss and plate and between the plate and dimm tops though kinda messy but best.
Bullant has the crazy imc/mem combo :)
I just want to find a freq chip some day :(
Thanks for sharing your thoughts and comments on the plate.
Any tips on cracking 40K on memory read with this board? What kind of CPU speed and memory speed/timings would I need? Keep in mind I'm using AIO water and don't have any really high binned Samsung, best is 2400C9 Trident X.
Got 40K on the read and write, now just gotta do something about that copy speed!
http://i.imgur.com/SUa6C5K.jpg
looking good nice and tight :)
