hi
ripjaw 1600-4GBRM 7-8-7-24 with serial 10111040 and 10171040 (2 kits 2x2gb) with the production weeks is possible to know if they are psc X or T ?
thanks for any help
hi
thanks for any help
You can never be sure, but you have a nearly 100% chance of both kits being X-PSC, afaik GSkill starting using T around midth of year 2010, and even afterwards there were lots of kits that used X
I guess both kits have a high chance of PSC X-series, though I'd probably go for the earlier kit ( 1011 ) to be safe. Do you own the kits already?
no
have them in a auction site in my country
there are 3 but they are not cheap, thats why i asked, i have allready bought enough t?s :-)
thanks for your help
will try to get them
Got a question for you guys...
I just noticed today for the first time (I'm slower than most :) ) that not only are there two versions with different timings of the GSkill Trident DDR3-2000 CL9, one being 9-9-9-24 and the other 9-9-9-27, but there are also different variants that have what I refer to as (A) the "single-sided" PCB, which has all of the SMC that are located just above the gold contacts mounted on one side of the PCB, and (B) the normal "double-sided" PCB which has those same SMC split up and mounted on both sides of the PCB.
Here are some pics of what I'm referring to.
Pic of the side with the SMC:
http://i558.photobucket.com/albums/s...07-2014_01.jpg
Pic of the label side without any of the SMC:
Pic of a pair of "normal" D/S modules, with the SMC visible on both the front and back sides:
So my main question is whether or not anyone has pulled the spreaders off one of these S/S PCB versions and confirmed that they use the same ICs as the D/S (0640=BBSE)? Typically the modules with S/S PCBs are in fact, single sided modules, but I know that at least some of the 4GB Crucial Ballistix DDR3-1866 CL9 use this S/S PCB, yet sport memory chips on both sides of the PCB, therefore it could very well be that both PCB styles are using 16 chips of BBSE. A follow up question would be, if both PCB styles use the same 16 BBSE memory chips, whether or not one performs better than the other.
I'm just trying to find out whether or not the Tridents are the same as those Ballistix I mentioned above, or if by chance the S/S version is using a different IC, for example, a single row of the Elpida ICs used in the "ver2.12" Corsair 2x4GB kit which msimax posted about here:
http://www.xtremesystems.org/forums/...=1#post5228187
On a side note, I also found similar S/S PCBs being used in a Trident DDR3-1600 CL8 kit with PSC chips. Can't hardly believe that I never noticed this before, but I guess since the release of single-sided 4GB MFR modules, I've been more aware of the single vs double sided module.
Pic of the 1600 CL8 kit (PSC based):
Anybody have any experience with these single-sided PCB modules?
These are single sided, afaik G.Skill used BCSE
Speaking of Tridents:
single-sided 1GB and dual-sided 2GB modules use 1Gbit ICs - those are BBSE, PSC, Hypers or whatever, depending on spec and SN.
single-sided 2GB and dual-sided 4GB modules use 2Gbit ICs - I guess those should be BCSE.
Single-sided (SS) and dual-sided (DS) modules do indeed have different SMD arrangement on the PCB.
As you mentioned, SS have dense SMD arrangement on one side (compared to DS modules) and the second side empty.
Exclusions do exist, but mostly on old (pre-2010) modules.
Thanks for the replies. So then there is definitely some value to noting whether the Trident 2000 kits are single-sided or double-sided.
Just continue to be amazed that I never noticed that there were single-sided versions of the Trident 2000 C9 kits.
Referencing these two statements posted above:
Originally Posted by websmile
Would BCSE be a reasonable guess as to what is being used by Corsair in that Dominator 2x4GB 1866 CL9 ver2.12 kit that msimax was testing at 2600+ (the one I linked above)?Quote:
Originally Posted by TaPaKaH
Yes, I think so. Elpida's earlier and later 2Gbit ICs that I've seen or tried were much worse than the "typical BCSE" so I can't imagine anything else as a potential candidate for DDR3-2666.
After RMA , my BBSE change to EBSE :D (xxxx0690xxxx)
https://fbcdn-sphotos-f-a.akamaihd.n...27718667_n.jpg
I've never seen EBSE before. How do these clock?
Crappy Hynix BFR (Ripjaws X 2133 9-11-9), won't do tRCD=11 at 2400 :mad:
http://i947.photobucket.com/albums/a...psba254a2f.jpg
Have two sets I've been trying to bench but I don't have a clue what I'm doing and setting the fsb in bios yields me a locked computer and upon restart I get overclock failed on the first set of 1600mhz @ 1866mhz. I have no clue what to do from this point and my attention span has been burned out with this mess. I've read overclocking guides but everything in each one is way over my head and I don't understand any of it so meh
4x4gb GSkill Ripjaws Z 1600MHZ (0160)
01xx - Micron
0140/0160
4X4gb GSkill Ripjaws X 1866MHZ (1800)
x800 - Elpida
0800/1800
3800 MxH-E Hyper
That's where they sit on the charts. I can't get the heat spreaders off to see exactly which chips they have. My thoughts were to keep the lower benching set because I just don't bench for my life. Then flip the other set to make back some money on a combo deal I did on Anandtech with a MIVE and 2600K. I only purchased the combo for the cpu and expected to flip the board easily along with the ram once I got it benched. (Keeping one kit or the other.)
I'm about to just put up one of the kits for sale and call it done because I don't know what I'm doing with memory benching and don't understand it.
Benching my cpu and trying to get it stable over 50x100 pretty much burned me out and today is probably the last cool day we have until fall so yea.
Can you give us more info about your setup and what you've tried?
Don't expect too much, both kits aren't known for being overclocking monster.
Well I set everything to a T from this guide other then the ram @ 1866mhz. I'm sure it needed voltage adjustments or something but it would keep cycling after I saved the bios settings and never showing a screen other then black. Until it would lock up and I would have to force shut it down. When I would turn it back on I got the overclock failed message.
As I said I just flat out don't understand the memory overclocking bit because it is way over my head and there is way too much involved in it. I really wanted to find out what they would do though so I can list them at their benched specs for sale. I see people all the time with ram for sale that does this on that and this with these timing's. Which is of course all greek to me but people look for that stuff when they are buying ram. Mainly I don't want to under price some fairly decent ram so I wanted to see what each set would do so I could sell the better performing set. Since I don't regularly overclock. Gaming shows no improvements in overclocking when your running 16gig or ram, 3770k, and 7970. If they did you would have to benchmark the gaming to notice any difference because the naked eye can't.
All I've been playing for the last 2 years is MWO when I'm not gaming I'm mining off my 7970 to fund my next gpu purchase. I have too busy of a life to game all the time. When I do have spare time I like to bench my system (cpu/gpu) in 3dmark. That of which I haven't had a chance to do yet with this build. (I've had this 3770k and 7970 for over a year if that shows you how much tinkering time I have) So you could imagine my frustration with spending most of the day (6am-2pm) benching my cpu trying to get over 5.0 to then drop into unknown territory of memory overclocking and not having anything I read be retained.
I can no longer read books and haven't been able to for at least 15 years. Once I get 5-6 pages in the first 1-2 pages I read are like an afterthought to me. It's very frustrating. So to read about what 50 different settings do but only know partially what the last couple do um yea I should just hang it up and pick which set of heat spreaders looks best in my build and sell the other one. Apples to oranges they would be ran at 1600mhz all the time or 1866mhz. Because I don't feel the need to overclock ram just to game. It would have just been testing purposes only and for future use when I have another cool day and time to actually run 3dmark on my new build.
I would love someone local to come over and explain this crap to me. It may actually make sense then. lol
Mystery Elpida IC + G.Skill, Round Two.
I took a chance on a 2014 kit of F3-12800CL6D-4GBPI on eBay, listed as new in the box. I could see the serial from the photos, 14151800, indicating Elpida chips, and they definitely appeared to be double-sided.
http://i947.photobucket.com/albums/a...ps7777dfd5.jpg
I got them in today. Looking under the spreaders initially, I was surprised to see white stripes on the ICs. Heated them and pulled the spreaders off.
http://i947.photobucket.com/albums/a...psdf0eb3a1.jpg
http://i947.photobucket.com/albums/a...ps8e1c5a6e.jpg
http://i947.photobucket.com/albums/a...ps7f4c3d27.jpg
They're definitely 1Gbit xxSE chips, and looking at the code, the key letter is "B". These are either BBSE or EBSE. No idea how in the world such ICs are showing up on 2014 kits (I assume this was an RMA replacement for the original owner similar to ihog6hog's post above).
What is more interesting is that these xBSE were apparently made (or at least labeled) at week1105, more than a year after production of BBSE has supposedly stopped.
Starting slow to see what they can do. Basic 2133 8-9-7-24-1T testing right now. Looks like they need 1.70v.
http://i947.photobucket.com/albums/a...ps1513a866.png
Not bad, what about 2133 7-9-7 and higher clocks?
As I said, don't expect too much from them, middle class RAM is very tighly binned today. For starters just set 1.65V Vdimm and 11-11-11-30 timings and try which divider you can boot.
Or just keep the higher spec'd kit and sell the other one.
Both of these kits guaranteed to be Samsung right? What exact ICs would I expect? Wanted to get both kits but was late on the draw and could only get one.
http://cdn.overclock.net/5/5b/5bde2f...05_211904.jpeg
I think both will have the same 4Gbit revision B Samsungs and there won't be much in between in terms of overclocking.
