Amazing volts Dumo ;)
Sorry for the slow reply Sergio...... I now have my IHS glued back on but can say I did not notice any die damage at all in the month or so I had my chip with the loose IHS & LM.
The die is much more resilient than you may imagine..... as I understand it the majority of what we see is just a big blob of silicon & the business end of this where all the transistors are is at the bottom of this hence just like in the AMD Athlon XP 2500 days you can get away with knocking the edges off & it still works.
Thanks C-N i kow the die is resitant as i scratched one and still working :) but as im lazy to take out mobo again and put the chip i do it with the mobo in so while im installing the chip to hold it i have to use finger and of course the IHS dances over the die :) till the bracket can hold it thats my concern
This is why I glued my ISH back on.... I figured the amount of times I had the chip out of the socket & had to fiddle about to get the IHS centred properly annoyed me. Sometimes I had to do several re mounts to get even temps so I figured get it right & glue it back on & that'll be the end of the drama. Besides its easy enough to cut it off again anyway.
Decided to glue it onfrom the beginning. Much easier to work with, especially if your board is in a case.
what can people run in 3Dmark Vantage after mod ? 2D is quick test
my can almost achieve 5GHz on water without mod in vantage
??? i can why not ?
this is at 4.8HT tough 2800 CL11 my 24/7
http://i.imgur.com/17S5z.jpg
I have little mem problems at the 5GHZ = the bandwidth on my mem,here is 5GHZ an vantage AMD HD7970 1360/1750 home mod GPU block from old XSPC Chipset block,an no mod whit the cpu,I use watercooling
there is a big jump whit vcore from 4.8 to 4.9 an 5GHZ ;)
This is not my best score
win 7 64BIT Ultra no tweak,is a gamer pc/oc
http://imageshack.us/a/img11/4743/vantage5ghzp.jpg
it would be nice to see a little 3Dmark tests, instead of all the 2D test, to see how much more it can now also provide, as 3D requires a bit more of CPU :)
also to hear about tempen keeps all the way home
here u go Martin same all on my 24/7 settings
http://i.imgur.com/hapOE.jpg
can see we use the same vcore at 5GHZ
Sergio, are you running 1.5Vcore 24/7?
About 2 weeks after IHS MOD
Same ambient temperature,same test
4.3 Ghz - 1.10 Vcore
Attachment 130763
Core 1: 60 °C
Core 2: 65 °C
Core 3: 65 °C
Core 4: 58 °C
Improvements: temperature are finally stabilized,vcore needed to be stable is less
FOTO an vantage an nice temp,no mod on cpu 5GHZ I use 2x360 radiator form XSPC RX an 1 TFC 360
http://hwbot.org/image/855325.jpg
I see this on spanish forum...yes hurt !
3770k Rest in peace
Attachment 130853
Attachment 130854
I opened a 3570k yesterday that had a zone on those large pads of the IHS that was really really hard to open. Once open I almost :banana::banana::banana::banana: myself in the pants it had a huge marking on the PCB under that pad zone. It couldn't have been me with the blade, no way I could have done that. That pad zone wasn't flat as it should and I think it might have been intel doing when assembling the IHS at the factory. I just couldn't get my mind in how did that CPU work with that mark... but after all it indeed work when I put it back into the motherboard :O
Delidded my 3770k using CoolLaboratory Liquid Pro.
Just used an exacto blade and som alcohol as lubricant and had the lid off in about 15 minutes or so.
No too hard if you are careful!
Pretty much a 40C drop. I am using it between the IHS and the die as well as teh ihs and the waterblock. 5.1 ghz right now at 1.45V max temp running Wprime is 63C. Intel burn test maxes out at 73 on the hottest core.
