Problem with resume after sleep/hibernate
For all with problem with resume after sleep/hibernate and Internal PLL Voltage Enabled.
Hereīs a quote from Gary Key (ASUS Technical Support) about it, Official ASUS Response to Resume/Hibernate Problem with Internal PLL Voltage Enabled
"Good Day,
After lengthy discussions with Intel and R&D this morning, it turns out that the inability of a system to properly resume from sleep/hibernate with Internal PLL Voltage enabled is a documented problem from Intel with the current base firmware code for Sandy Bridge/P67. We are working with Intel on a solution. I will update this thread as additional information becomes available."
Yeah, I know thisīs the a Asrock thread, but this seems to concern all P67 chipset board no matter which brand, it seems like a lot of people have problem to resume after sleep/hibernate with Internal PLL Voltage Enabled.
So I quess we have to wait for Intel to solve this.
Ket, do you know if Asrock is working on it with Intel also or if itīs only the big ones who does?
@papatsonis
Have you tried to use "Turbo Mode Extra Voltage"?
