thanks for the help vern i did it myself works as a charm
unlocked volts to 1,2 and fan min 30% rest idles the same and loads the same :D
http://img819.imageshack.us/img819/2847/unlocked.jpg
Uploaded with ImageShack.us
Hello Vern :)
Could you unlock the max voltage and set the min fan speed to 30% for my Gigabyte GTX460 1GB OC please?
Thank you very much!!
sup mate
save it on .ROM with nvflash, not on bin format thats what you attached
put nvflash files on a bootable flash drive and boot
then type nvflash -b original.rom so you will be saving the exact rom
then post it again i can mod it for you if you want now i learnt and tried all ma self thanks to vern and the guide for nvidia fermi editor
Cheers :up:
Sergio
Hey Sergio, thanks for your help. I've done what you said, here is the file :)
(PS: i added you to msn messenger just now)
Opss again
Your BIOS : http://www.sendspace.com/file/ytrca2
Good luck
Thank you Andre and Vern!
Too bad I can't beat 850 mhz OCCT stable because the card gets too hot :(
1.15v and 1.2v :P
glad mate you liked the bios
vern dont get angy on me i learnt how to do the stuff lol
cheers for all
Sergio
i used inspector modded but really i dont know what the hell does i have all set at max for ex BC2 or MOH i dont really see any changes on level of detail...
here is the latest thread i saw you there
http://www.xtremesystems.org/forums/...ght=lod+nvidia
cheers !
Sergio
Can someone do mine?
30% fanspeed and 1.2v limit?
http://www.mediafire.com/?d8v08dnjamza1nb
