I dont see any silk screening above ram slot 1 or any of the ram slots for that matter, but the sticker next to the ATX connector says A02. My board claims to be rev 2.0 if I remember correctly.
My G Skills Trident 2000Mhz PC3 16000 cannot run at 2000Mhz, is that normal?
And what have you tried to get them there ? QPI voltage how high ?
must be unless you are blowing AC over it
what are you using for temps?
Karlitos no that is not normal, post up your voltage settings
Check out my 2000MHz memory 24/7 settings for hot summer days :)
Hope it might help.
Code:Target CPU Frequency 4200MHz
Target DRAM Frequency 2005MHz
LN2 Mode: Disabled***
QPI Loadline Calibration: Enabled***
Sync Mode [Enabled]
AI Overclock Tuner [Manual]
OC From CPU level Up [Auto]
CPU Ratio Setting [21.0]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
C1E Support [Enabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetcher [Enabled]
Intel(R) Virtualiyation Tech [Enabled]
CPU TM Function [Disabled]
Execute Disable Bit [Enabled]
Intel(R) HT Technology [Enabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [Enabled]
Intel(R) C-STATE Tech [Enabled]
C State package limit setting [Auto]
BCLK Frequency [200]
PCIE Frequency [100]
DRAM Frequency [2005]
UCLK Frequency [4009]
QPI Link Data Rate [7218]
Memory Configuration Protect [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency 7 [7]
RAS# to CAS# Delay 9 [9]
RAS# PRE Time 7 [7]
RAS# ACT Time 21 [21]
RAS# to RAS# Delay 6 [Auto]
REF Cycle Time 88 [88]
WRITE Recovery Time 12 [11]
READ to PRE Time 7 [Auto]
FOUR ACT WIN Time 28 [Auto]
Back-To-BackCAS# Delay 0 [Auto]
Timing Mode 1N [1N]
Round Trip Latency on CHA 59 [59]
Round Trip Latency on CHB 61 [61]
Round Trip Latency on CHC 62 [62]
WRITE To READ Delay(DD) 8 [Auto]
WRITE To READ Delay(DR) 8 [Auto]
WRITE To READ Delay(SR) 19 [Auto]
READ To WRITE Delay(DD) 8 [Auto]
READ To WRITE Delay(DR) 8 [Auto]
READ To WRITE Delay(SR) 8 [Auto]
READ To READ Delay(DD) 7 [Auto]
READ To READ Delay(DR) 6 [Auto]
READ To READ Delay(SR) 4 [Auto]
WRITE To WRITE Delay(DD) 7 [Auto]
WRITE To WRITE Delay(DR) 7 [Auto]
WRITE To WRITE Delay(SR) 4 [Auto]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Full]
CPU Voltege OCP [Enabled]
CPU PWM Frequency [1000kHz]
Extreme OV [Disabled]
Extreme OC [Auto]
CPU Voltage 1.303 [1.31250]
CPU PLL Voltage 1.812 [Auto]
QPI/DRAM Core Voltage 1.396 [1.41250]
DRAM Bus Voltage 1.654 [Auto]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM DATA REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
IOH Voltage 1.244 [Auto]
IOH PCIE Voltage 1.508 [Auto]
ICH Voltage 1.111 [Auto]
ICH PCIE Voltage [Auto]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [Disabled]
DRAM Spread Spectrum [Disabled]
***on-board jumper dependant
No, but I found a solution :)
DRAM Timing Mode: 3N
VTT=1.425V
http://img266.imageshack.us/img266/5604/422000.jpg
which bios and program version?
Still 0402, and TurboV Evo 1.0.12.2. Guess I need to flash.
I've never had a dual BIOS board before, I assume it has two copies of 0402 currently...
I figured it was a bug, but wondered if there was a fix. I guess I need to flash the BIOS. Tbh I kinda like this BIOS though.Quote:
I had the same problem reading CPU PLL value until I flashed with latest BIOS 0602 and now it is OK, but I am sure it is a bug
is the 0602 Bios the latest Bios?
My Xeon W3520 run not very god :shakes:
splave you still on bios 534?
should i be puttin in 1.9v pll? less or more i'm @ 1.84 now
? safe for qpi vtt volts
ulk frequency is it the same rule as per a 920?
tks
i got her stable 4.4 1.39v 4.5 needs 1.44v for linx
eva2000 has a good guide for the uncore rules and guidelines for the 980x's
Intel Core i7 980X - guide to optimal cpu vtt & vdimm voltages Uncore to Memory frequency ratios
i got a swiftech was cheaper n thev ek was soldout
you will see a 10-15c drop in nb and sb temps and i'm sure the pwm will be cooler
i even replace all that yellow crap asus had on the nb and sb
i'm @ 2214mhz cas8 stable @ 4.4ghz so far cpu:1.39 vdim:1.65v qpi vtt:1.4 :)
i'm in the ballpark n will work on lowerin cpu volts
for 4.5 i need 1.44v
nice memory clock and OC zsamz:thumb:
i'm stumped
why so low bandwidth
