All nice builds!!!!!
Keep up the good work, makes me want to get one and mod it.
My HAF 932 is looking boring as of late!
there are some projects here that should get a Nobel :P
Indeed, there are some great builds in this thread.
oXcoRe - is that 3 pumps in series I see down the bottom there? Nice Job!
i7 965 extreme edition
DDR3 OCZ Reaper Edition 12800 3*2Go
Asus Rampage 2 Extreme
GeForce GTX 470
SSD 32GO + DD 500GO
Enermax 550w
Corsair 800D
watercooling
CPU : EK-SUPREME LTX PLEXI
GPU : EK GTX 570
Pompe : Swiftech MCP355 + Top Plexi
Radiateur : Black ice 360 GT
Réservoir : Balancer 250
Tuyau : Masterkleer 10/16
Embout : The Feser Company 10/16
http://img11.hostingpics.net/pics/742088P1020580.jpg
http://img11.hostingpics.net/pics/327761P1020579.jpg
http://img11.hostingpics.net/pics/355658P1020590.jpg
http://img11.hostingpics.net/pics/442698P1020591.jpg
this thread was such a huge inspiration to me.. here is mine (new RAM coming soon to replace the ballistix tracer reds)
http://farm7.staticflickr.com/6223/6...2a8fabb6_z.jpg
yet another red and black Corsair Obsidian addition to this thread
it also goes by the name Scorpidian 800D and was specifically built for a female user
(who also did almost all of this cablework...and in addition knows how to effectively use a dremel!)
https://lh3.googleusercontent.com/-g...kopritis-B.jpg
https://lh6.googleusercontent.com/-Y...kopritis-C.jpg
https://lh4.googleusercontent.com/-o...kopritis-A.jpg
http://i7.photobucket.com/albums/y27...kopritis-G.jpg
nice looking, i would go with red, but red hurts my eyes
Congratulations, perfect staging for that color so spectacular.
A greeting.
wow good job to all!
http://i.imgur.com/1mHhj.jpg
just to keep the thread alive :)
i will install GPU blocks soon :)
i have them at home
this is mine!
http://www.xtremeshack.com/immagine/...384999-001.jpghttp://www.xtremeshack.com/immagine/...6-sl385003.jpg http://www.xtremeshack.com/immagine/...1-sl384998.jpghttp://www.xtremeshack.com/immagine/...7-sl385005.jpghttp://www.xtremeshack.com/immagine/...8-sl385006.jpghttp://www.xtremeshack.com/immagine/...0-sl385008.jpghttp://www.xtremeshack.com/immagine/...9-sl385007.jpg http://www.xtremeshack.com/immagine/...1-sl385009.jpg http://www.xtremeshack.com/immagine/...3-sl385012.jpg http://www.xtremeshack.com/immagine/...4-sl385013.jpg
Obsidian 800D from Thailand.
http://upic.me/i/s4/gx601.jpg
http://upic.me/i/y1/9vz05.jpg
http://upic.me/i/zf/nqq13.jpg
http://upic.me/i/3z/0w317.jpg
http://img822.imageshack.us/img822/5898/dsc03460w.jpg
http://img267.imageshack.us/img267/9000/dsc03461z.jpg
http://img215.imageshack.us/img215/2549/dsc03464zz.jpg
http://img546.imageshack.us/img546/673/dsc03466u.jpg
http://img196.imageshack.us/img196/1772/dsc03456l.jpg
http://img545.imageshack.us/img545/8199/dsc03470f.jpg
http://img820.imageshack.us/img820/86/dsc03469k.jpg
http://img826.imageshack.us/img826/7909/dsc03467q.jpg
http://img813.imageshack.us/img813/9954/dsc03468t.jpg
Awesome job Gonzalo! Couple questions on your build...
It looks like you used a rotary 90 degree fitting for the cpu pump top to cpu block... how do you get it to stay in its current position? It looks like there is quite a bit of tube pressure that would cause the rotary fitting to want to move to point straight up.
What material did you use for the white divider covering? Looks great! It looks like there is also a bitspower screw cap mounted to it... what is the purpose of that?
Can you post some pictures of what is happening below the white divider? Did you follow a guide to remove the bottom hard drive trays? If so, can you link it? Assuming a rivet remover would be required, correct?
Again, excellent work - thanks for posting.
the same tube keeps it from that position
use white acrylic and caps serve no function, forget it there
photos of the process I have nothing, because just at that time did not have the camera. if you need a rivet remover but do not need any guide is to give the skill to remove it, not very complicated, the only thing is that you have to disassemble most of the case to remove them
PD: sorry for my English :D
Finish
http://img38.imageshack.us/img38/6425/dsc03472g.th.jpghttp://img46.imageshack.us/img46/1166/dsc03473k.th.jpghttp://img33.imageshack.us/img33/4421/dsc03477ps.th.jpg
http://img42.imageshack.us/img42/81/dsc03487sd.th.jpghttp://img198.imageshack.us/img198/8...03490gc.th.jpghttp://img826.imageshack.us/img826/5...c03514o.th.jpg
http://img830.imageshack.us/img830/8...c03491g.th.jpghttp://img685.imageshack.us/img685/6...c03492y.th.jpghttp://img41.imageshack.us/img41/9021/dsc03493xq.th.jpg
http://img28.imageshack.us/img28/6638/dsc03495q.th.jpghttp://img848.imageshack.us/img848/8...c03501x.th.jpghttp://img600.imageshack.us/img600/2...c03506p.th.jpg
http://img96.imageshack.us/img96/5669/dsc03507z.th.jpghttp://img256.imageshack.us/img256/8...c03512g.th.jpghttp://img163.imageshack.us/img163/7...c03513o.th.jpg
http://img823.imageshack.us/img823/2...c03515h.th.jpghttp://img689.imageshack.us/img689/1...03548lt.th.jpghttp://img27.imageshack.us/img27/9206/dsc03560hy.th.jpg
