Originally Posted by
kgtiger
Now were talk'in.
Solvent cement opens up a whole new way of thinking. :yepp:
The only thing is, why are you notching a slot in the perspex.
You could just bond the the SSD mounting plate to the bottom pump floor/shelf, cut the top pump floor/shelf in half to fit neatly behind the full lenght SSD mounting plate
and then bond the two together.
As the pump is behind the SSD mounting plate, you don't need any perspex in front.
This would stiffen the whole thing up by join it all together and incorporate both the SSD mount and the two pump floors/shelfs as one.
Of cause this all depends how this whole Zero Gravity Chamber all fits together.
I understand that your renders are simplified some what, but if both the SSD mounting plate and pump floors where joing together you could simlpy just slide it all in as one
and the floors would bolt onto the L bracket you already have.
4 bolts for the bottom floor and 2 for the top floor, all done. :up:
