0924BPMW -> Gigabyte GA-MA790X-UD4 with flashed bios F2a,F3i,F3F,F3 and F4 -> Fail.
Time to try my other 550 a 0923EPMW with bios F5.
Another New BIOS for MA790X-UD4P.....
Download from ... F7 2009/08/12 Update CPU ID(AGESA 3.5.3.0 for PhenomII /AthlonII AM3 CPU)
http://www.giga-byte.com/Support/Mot...S&FileID=14928
http://img44.imageshack.us/img44/9540/biosf7.png
http://img31.imageshack.us/img31/4751/biosf7ram550.png
http://img197.imageshack.us/img197/2...osf7nb2700.png
QUAD @ 4.160
http://valid.canardpc.com/show_oc.php?id=652117
http://img3.imageshack.us/img3/10/cpu550x44160.png
Check out the NB
http://img9.imageshack.us/img9/2046/biosf7nb2900.png
Nice, looking forward to flashing F7 tonight :up:
Success with stock voltage - Prime95 blend (4 tests) stable
0922MPMW - ramrodcar - MA790X-UD4P - F5c - Success
Success here!
0922APMW running on a Gigabyte MA770T-UD3P (F2c BIOS).
OC'd to 3.6ghz with the stock CPU fan, no problem, but it ran a little hot (CPU maxxed out at around 64C during Prime95). Switched to a Core Contact Freezer, and it will now clock up to 3.8ghz stable, although I keep it clocked down at 3.5ghz. CPU idles between 31-33C, and never goes above 60C during Prime95 or OCCT.
Man, I'm loving this new system--runs Windows 7 Ultimate like a dream.
I'm hitting a wall with my overclocking. Can't get 3.8 to stabilize with up to 1.500V on Vcore, 1.450V CPU NB. Haven't really manipulated ACC yet since the computer crashes when using P95. Used to just have a core or two quit, which would make it easier to figure out which cores are causing issues.
Using PhII 550BE (unlocked to quad) and GA-MA790X-UD4P. Anyone got any insight on this one? :banana::banana::banana::banana:ty chip maybe?
0925APMW on AsRock AOD790GX bios 1.0-1.5 Fail.
Stepping - Username - Mobo model - Bios used - Success/Fail - Link
0923APMW - WSP - MSI 770-C45 - 1.4B1 - tri core success
success in unlocking one more core, but strangely, I have to populate ONLY DIMM slot 3.If I try to swap DIMM, it does post but wont make it to windows :(
http://img194.imageshack.us/img194/4...accauto.th.jpg
0923APAW - Mattlef - MA790XT-UD4P - F4 - success Link
yes that is not 100% success :D although I recall I did success in unlocking 2 disabled core fully working but not yet tested for stability/benchmark. here's the screenshot.
http://img33.imageshack.us/img33/8789/x4b502.th.jpg
but I forgot to remember which bios I used, and also forgot to remember bios settings. :(
as for downcore option, I dont see any bios setting which pointed at 'downcore' on MSI 770-C45
thread starter:any updates ?
there are already newer batches available...i called some of my stores in my country,they are getting week 29 amd phenom 2 x2550BE ones
0922APMW - Dark Star - Jetway HA07 - HA07A06 - Success
http://img27.imageshack.us/img27/8621/captureujx.jpg
A different validation http://valid.canardpc.com/show_oc.php?id=633755
0925APMW - Gigabyte GA-MA770T-UD3P - F2 - Success
About 5 hours test in Prime95 without any errors
Still no signs of later batch?
Im still having an issue with my 550,
I get errors with my memory at DDR2-1066 at 5-8-8-28 which is slower than what its able according to OCZ.
In BIOS (790x-ud4p):
CPU VID: +0.025
NB VID: +0.1
NB Core: +0.025
I would like to get my memory stable at 1066 so i can work on getting my CPU and NB rounded out.
hi...
is there good chances to get a x2 550 @ x4 on newegg?
I see all failed unlocks in europe/asia..
2000Mhz still stock
Anyone have any idea what I can do to try to get my RAM stable over 800Mhz
CPU VID: +0.025
NB VID: +0.1
NB Core: +0.025
NB @ 2000
Just got a new combo,
0922MPMW - RussC - ASUS M4N78 PRO - 1004 - Success
Success with caveot, with 4 cores enabled, will lock up always. Disabled one core with msconfig and 3 cores work fine. Ran prime95 for 7hrs overclocked to 3.5GHz and FSB 210, Memory 1:2 to 420MHz. Sill testing to see how far it will go. I also added a fan to the chipset IC, the nVidia MCP78S(GeForce 8200). This set is one IC for the whole motherboard. May give some more headroom for overcloaking. The IC gets very hot in normal running. I wonder why ASUS didn't put a fan on it.
This CPU was a good part on air(Zalman 9700) with 2 cores and was able to do a few benchs @ 4.0GHz before crash with no voltage uppers(super PI-1M @ 17.3s). So far this part doesn't seem to like alot of voltage. Ill post some pics later.
System:
AMD Phenom II 550BE
M4N78 PRO
2GB OCZ2N1066SR1G
Raid 0 2x WD Raptor 150GB
Antec 500W PS
Fan added to chipset nVidia MCP78S(GeForce 8200)
RussC
russC
did u try to up the voltage?
or straight away got ur motherboard, updated ur BIOS and tried unlocking?
what do you mean by "4 cores unlocked but lock up always?
im inteding to get that mobo with 710,will appreciate any information u could provide
P1.20 BIOS (4/24/2009)
BIOS > Advanced > Chipset Configuration > Advanced Clock Calibration > [Auto], save changes and exit. Thats all. :up:
