i know a pic is worth a thousand words but i still wanr to know whats under the hood:ROTF:
owned on air ;)
i found it on internet on hardforum [; :D:D
http://i42.tinypic.com/33wa4h4.jpg
2x4870//pII es
http://www.hardforum.com/showthread.php?t=1376983
Still massive result from Phenom 9950BE!!
Congrats supercoolin! :clap::clap:
Very crowded case, but it it works who cares!!:up:
http://service.futuremark.com/compare?3dm06=9363631
Total: 12,361 3dMarks
SM 2.0 = 5082
SM 3.0 = 5213
CPU = 4042
8800GTX 576/900
nForce 175.19
OS = Vista 32bit
:up:
SOme update 14800 .. HD4850 with VGPU pencilmod 1,44Vcore at load. Its odd that the memory clock raises too if i put more juice to the GPU, original was 1100MHz, now with updated Vcore it gives 1225MHz.. and these settings I found with CCC automatic overclock .. so it was quickrun :) Perhaps some tweaking to break 15k. I have modded bios in it(upperlimits in CCC etc). Im going with original cooling too :D With window wide open ofcourse. I probably get my accelero S1 next week, so more testing coming up.
Nice gain though.
Here you go guys :D Just a new bios with 990MHz limit in CCC, automated clock gave 865 but I wasnt able to run that high because of the heat, at the end of first 3dmark test it gave so much artifacts that it stalled. I think its because the heat, because the artifacts were multiplying as the test ran to an end. And the memory is at its CCC limit.. :( I had a bios with core limit of 800 and memory 1300, then I could run like 790/1225MHz. .now with the new bios 865 and only 1200... it has something to do with the signatures or smth, had to flash with 4870 signature which had 990core and 1200 memory, altought memory could go higher. (if Id OC with ATT more, it crashes just after I push apply.. )
weird stuff.. Hope I find a signatures like 950 CCC core limit and 1300 memory limit.. before that im little stuck
looks like you guys gotta step your game up:rofl:
http://www.xtremesystems.org/forums/...52#post3535986
My new record with TwinTurbo cooler
http://service.futuremark.com/compare?3dm06=9434923
17,813 9950be@3.33ghz 4850x2@755/1150 http://service.futuremark.com/compare?3dm06=9309990
with my Asus M3A79T Deluxe coming today I may get higher scores due to higher voltages in the bios than the MSI DKA790GX I did this run with.
M-ATX result on my dfi lanparty junior 790GX m2rs
http://service.futuremark.com/compare?3dm06=8946070
Pretty neat for 8/8x no vga oc =)
I wanted to be the first one to post a 20,000+ score with a Phenom II so here it is. It probably wont last long and will get beaten pretty easy by someone (if not me) in the coming days/weeks, but it's nice to see the potential. :D
Phenom II 940 BE (ES) @ 4.0GHz
2x 4870 512MB @ 830/1030 (still have not enabled the third one yet woohoo)
Since I cannot publish the scores with the Phenom II yet all I have is a screen shot.
Nice score, im still working on my new mobo (yes the MA379-T)
Also for UK AMD nutters scan jusst listed both the 920 and 940 for retail in stock. Quite annoying as i was at the trade counter the day earlier :)
BTW Ben you need to update your sig also ;)
back to the drawing board :D I need to push harder on the VGA's and CPU but always running into trouble when trying CF oc or CFX :(
http://s11b.directupload.net/images/090107/jsuuhnst.png
SOF can you pull a 3.6g run with a single 4870 for me with 815/925 please untweaked OS.
maybe a bit later today as I am preparing session for tomorrow today. but I have to restore my vista first and test some other RAM etc. ;)
Great score guys my kids cars took a dump on them had to fix them use up my cpu money i had set side so it going to be about a month before i can get into the mix with you all again on the 3dmark-06 score any how great job ! :clap:
The screen shot shows XP and I know I can't publish my compare links on ORB yet so maybe he cannot either.
3DMark06
3DMark Score 21008
SM 2.0 Score 7538
SM 3.0 Score 11593
CPU Score 4977
AMD Phenom II 940 @3745 Mhz
DFI LanParty 790FXB-M2RSH
2X 2GB OCZ Reaper DDR2-1066 @ 554 Mhz
2x Powercolor HD4870 X2 in Crossfire @ 800/960
http://service.futuremark.com/compare?3dm06=9566115
http://img.photobucket.com/albums/v1...pdog/21008.jpg
