Yep. My bad. It should be P5B Deluxe.
i am getting my g0 very very soon its on the way as we speak i was wondering am i good with the ddr2 6400 ram i have or should i go 1066 also i am using a evga 680i sli a1 mb
Anyone have L726A343 batch?
I have to change out my L727A619 to try it.
I got mine today. Here are some pictures.
http://i144.photobucket.com/albums/r...r/PICT0356.jpg
http://i144.photobucket.com/albums/r...r/PICT0368.jpg
http://i144.photobucket.com/albums/r...r/PICT0370.jpg
http://i144.photobucket.com/albums/r...r/PICT0354.jpg
http://i144.photobucket.com/albums/r...r/PICT0361.jpg
http://i144.photobucket.com/albums/r...r/PICT0363.jpg
and this is the Q6600 G0 that im going to use.
http://i144.photobucket.com/albums/r...r/PICT0381.jpg
Going to put in my PC in abit on air. Then water later on tonight when I get my PC back on the floor as my case is going off on wednesday to get powdercoated white inside and a custom laser cut window. :)
Booted up at 3ghz. With 1.4V on air. Very nice. :)
http://i144.photobucket.com/albums/r...G03Ghz-air.jpg
Here is 3.4Ghz with 1.42V
I will go higer later on tonight when I have my PC on the floor and my watercooling set up again.
http://i144.photobucket.com/albums/r...03.4Ghzair.jpg
Seems like a lot of volts just to do 3.0g. The 2 Quad B3's I tested did 3.0g on Abit IP35 1.24v real.
http://www.abit-wolves.com/members/T...3220x9x334.jpg
I'm running 24/7 at 3GHz with the default volts. I suspect I could even undervolt it and be able to run it stable. The G0's might not have increased the headroom that much, but it made for a lot more legspace for low level overclocks.
It's your CPU, but personally I wouldn't crank up the voltage till it was needed. No since in getting it use to
a lot of voltage, to my thinking it might get to liking it & need that kind of voltage all the time just to run 3.0g/3.3g stable.
I did have to crank up the voltage at 3.2 but only to 1.35v (real). This was on air with a cheap heatpipe cooler, room temp 26c/79F.
damn you baron cause of you other don't have chance to get G0.
clubit sold out too....
trend4pc in germany have G0 in stock
alo everyone
just received my G0 today, Batch L726A951 tray version.
so far it has pass prime95 at 3600ghz - 1,43v load and 1,44v idle on a P5K-E and 4x1GB TG Elite.
load
http://img73.imageshack.us/img73/979...rimenc0.th.jpg
idle
http://img73.imageshack.us/img73/160...idlenq7.th.jpg
also was trying to see if the cpu does the 4,0ghz and voila :yepp:
http://img511.imageshack.us/img511/5...idledt9.th.jpg
i think that it has more potencial, need to do more tests soon :)
regards
TheWolf,
How do you set up Orthos to test all 4 cores? I tried running 2 Orthos but it still doesn't test all 4 cores
thanks icon57 :)
to run booth ORTHOS you need to open the task manager, go to "Processes" task and right click on the program (in this case the two instances of orthos) and click "set affinity", then it will show the 4 cores and just need to choose two cores for each instance.
otherwise for me at this point Prime95 and OCCT are better for test because it only need one instance to run the 4 cores.
