The 4 pin headers are backwards compatable with 3 pin fans. There's a key on the header that positions the connector correctly.Quote:
Good question. I'd like to know that as well.Quote:
Originally Posted by mnemonik23
Thanks for the info. I'm sure it was in this thread too? I'm planning on reading the whole thing soon. :)Quote:
Originally Posted by rick_fx
That's what i read over at toms a few minutes ago as well. 'Ill try and see if it works tomorrow so i can use that 3 pin header I'm using for the cpu fan now with one of my other 120mm fans. Thanks for the info!Quote:
Originally Posted by gtj
could somebody please measure and post the dimensions of NB original heatsink?
just connect the 3pin header to the 4pin header. and there is only one way to connect it right. i dont think it's possible to go wrong there.Quote:
-edit-
QUESTION: Does anybody know how to use the 1333 strap and 1066 strap? I dont know if im using the 1066 or 1333 strap. how to select the strap in bios???
Intel® 975X Express Chipset Thermal and Mechanical Design Guide - For the Intel® 82975X Memory Controller Hub (MCH)Quote:
http://www.intel.com/design/chipsets...nex/310157.htm
Page 19.
thx, I see that 40mm fan will fit in the middle just fine. But will it be enough?Quote:
There's also a 3 pin fan header specifically for a nb fan.
Enough for what? :)Quote:
Well my mb is running great, still a few problems, but their getting worked.
One question, how do I change the fsb:dram ratio? I have it at 2:3, trying to get it to like 5:4 or something.
Im coming from ddr1 so everything is very different.
This isn't directly selectable in BIOS. With most chipsets the setting is done automatically by the BIOS based on the current FSB. I don't know if anyone has started testing this. But the best way to find out how to manipulate it is to run memory bandwidth tests as you run up the FSB. jumping to the 1333 strap from 1066 will result in a hit to bandwidth and latency on the memory. I'm not sure but i also believe that everest will report the current strap.Quote:
Originally Posted by heikis
here's some good reading:
http://www.bleedinedgesupport.com/oc...ad.php?t=22297
http://www.bleedinedgesupport.com/oc...ad.php?t=23803
Post #426Quote:
Originally Posted by Vice
I've read the whole thread, but to clarify please, which programs re-set vcore in bios to default (bios 2395) and do they re-set on the spot as you run them in windows or only after a reboot and what is the quickest way to recover your set vcore other than manually re setting it if even possible?
cpuz?
everest?
speedfan?
memset?
sandra?
etc.
Yes i saw that post, but i dont really understand it.Quote:
Originally Posted by Blauhung
Which are compatible with ddr2-800 ram ?
all of them are compatible with 800MHz ram. by changing the reference frequency and memory frequency you are setting the divider. It's not the most user friendly method of setting this because it makes you do some math, but it works. Use the table in the post listed to set your divider, then do the math to figure out your true memory frequency.Quote:
Anyone know if the tigerdirect version is the boxed retail version or the bulk version?
Im not sure Im doing this right, I keep getting decimals.
for instance, say you want to run DDR2-800 with a FSB of 300. That would require a 3:4 divider on your memory. 300/(3/4)=400*2(because its ddr)=800Quote:
to get this divider you can use the setting below:
REF MEM RATIO
200 533 3/4
also any time you start dividing fractions, you will end up with a chance decimal. just round to the nearest whole #
Yeah i just figured that out... im an idiot =)
Box retail.Quote:
Originally Posted by Teratism
cpuz: No. Works OK.Quote:
Originally Posted by xgman
Everest: Yes. As soon as you try to read the sensors it will hang.
Speedfan: I think it works OK but since Speedfan doesn't read the aSC7621 chip on this board, it's not of much use.
Memset. No. Works great.
Sandra: Yes: You can run the benchmarks but if you try to read MB info, instant hang.
To recover from a vcore reset, you MUST remove all power from the MB. I.E. unplug or power off the PSU and wait for the green light on the MB to go out.
i cant figure this out. im using the latest bios and i cant hit 440FSB at maximum MCH/FSB voltages. it just doesnt POST or freezes at POST.
BUT im perfectly stable at 400FSB at minimum MCH/FSB voltages.
it seems like the vcore to the CPU is not changing after adjusting some extra vcore.
Did you just jump to 440 or did you work your way up to it? I did find that with this board more voltage isn't always a good thing. At several 400+ steps, lowering the voltage actually made things more stable.Quote:
They have a good price for the BX2. The only place cheaper is Amazon @ $199.99 shipped but what kind of RMA Policy would they have? Probably none right?Quote:
yup, jumped from 400 to 440 :P i will try to figure it out and tomorrow im probably gonna test if the vcore is raising or not after adjusting to higher in bios.Quote:
btw im using everest ultimate very easy to monitor temperatures :P
I tried getting it off tigerdirect but their site kept on saying the info for the card was wrong so I couldn't use them, the exact same info worked on newegg though. I think the amazon sales is actually through tigerdirect if you look at the 17 used or new section. Damn extra cash spent better be helpful if anything goes wrong.
I am now or more like in 3 days will be a proud BX2 owner anything I need to know? Haha just kidding I will read through the thread again but actually does anyone if super talent ram works fine with this mobo?
