Mine varies a lot.......
2 500 MB Western Digital Caviar 5000AKS SE16 16MB cache in RAID0 write back cache enabled
6 500GB + Highpoint RocketRAID 3520 controller 500GB partition
Do Want
Here are my 2x 640GB WD's in raid 0 300GB slice with write cache enabled.
http://img391.imageshack.us/img391/5...gbslicepu0.png
Seagate 500gb 32mb cache x2 in Raid 0
Are they performing like they should? And are they doing good? I had some programs running when I ran the benchmark :P Maybe I should of closed some stuff lol
5x WD RE3 in RAID 5, controller Adaptec 5805
4x 320Gb Western Digital 7200rpm 16mb in Raid 0
Adaptec 5405 Raid controller
http://i62.photobucket.com/albums/h9...p/Untitled.jpg
http://i62.photobucket.com/albums/h9.../Untitled2.jpg
Not much faster than my WD Black 640 GB in my home pc
Update:
This first is a later try, with slightly better results. Whatever was in the background stopped running. I'll leave the original test below the new one.
HD Tune: OCZ CORE_SSD Benchmark
Transfer Rate Minimum : 79.2 MB/sec
Transfer Rate Maximum : 129.7 MB/sec
Transfer Rate Average : 113.3 MB/sec
Access Time : 0.2 ms
Burst Rate : 116.4 MB/sec
CPU Usage : 19.7%
Transfer Rate Minimum : 1.4 MB/sec
Transfer Rate Maximum : 132.7 MB/sec
Transfer Rate Average : 110.6 MB/sec
Access Time : 0.6 ms
Burst Rate : 51.7 MB/sec
CPU Usage : 19.0%
Something was running, it was up and down bet. 125 and 100 mb/sec almost all the way out 'till the end, when something else caught it's eye.
4x OCZ Core v2 30GB SSD on ICH9R - Not bad for 200 bucks
http://www.xtremesystems.org/forums/...1&d=1228597038
Intel X25-M SSD 80GB. Core i7 920 @ 3.2Ghz
What is the maximum bandwidth of the ICH9R SATA controller ?
has 6 ports of 300 MB/s, in theory with RAID0 can provide 1.8 GB/s, is it only theory ? in the practice have any limitations ?
6x intel ssd x25e 250 MB/s read RAID0, total 1.5 GB/s, is it possible ?
this is my current configuration, 4x 500GB 7200.10 RAID0 Slice 32GB system, the rest for data.
http://img408.imageshack.us/img408/6...4xraid0pr1.png
No the ichr 9 or ichr10 controllers typically max out anywhere around 600MB/s regardless how many ports it has. You will need dedicated raid card to go faster
Six SSD's??!!...damn, expensive.
Here is 2 Intel X25-E
I bought myself 8GB of A-DATA DDR2-800 and created a 5GB RAMDisk :)
This drive is used for games but I need a mobo with 16GB limit :(
