Anyone who has removed the heatpipe, did you put as5 on the voltage regualtors too? or did you put the thermal pad back on it?
http://www.dailytech.com/article.aspx?newsid=3948Quote:
Originally Posted by The Nemesis
Originally Posted by malficar
malficar is this the ram your using?
http://www.mushkin.com/doc/products/...ail.asp?id=350
That would be correct.Quote:
Originally Posted by palese
Looks like my board tops out @ 445FSB 1mb Pi with multi set to 8:( Not better than my P5W DH.
http://img222.imageshack.us/img222/9...dmaxhe8.th.jpg
Vapor EDIT: image replaced....
****oops forgot to resize in my haste Damn 1920X 1200 Res Monitor:) ****
That's a good result Nemesis :)
(ps, 6.6Mb bitmap? :eek: get it in jpg/png :fact: )
make it in JPG/GIF ... 6.6MB takes age loading it from 56k speed modem :slapass:
445 nice result ... btw....:banana: :toast: :clap: :woot:
AGhhh damn I just sent this board back to the shop after hearing some bad experiences with it running 1:1 at higher FSB.
Should I go and get it back? :D
AS5 everywhere....Quote:
OT: LOVE the wallpaper!!! :)Quote:
and nice to see the board doing almost 450+ FSB as well.
anyone else notice that the CPU temps are reported a bit higher on this board than others? or is it just me? Im sitting at 36-38C idle and 55C load with high end water at 1.45v 3.6Ghz...
My result:
[IMG]http://img80.imageshack.us/img80/5915/13044pixg8.jpg[/IMG]
CPU-Z:http://valid.x86-secret.com/show_oc.php?id=125778
I love this board!:)
E6600 (L625)
abit AW9D-MAX (Asus P5B Deluxe)
Danger Den&Swiftech Storm watercooling
Thermaltake Extreme Spirit II NB cooler
Mushkin Redline XP2 8000 2x1Gb RAM
OCZ 520 12U PSU
mch & pcie 1.5v voltage
What is this voltage do? any help on O/C?
In the Bios, it said "this voltage feed the PCIe". I thought this feed the NB. Can someone please shed some light here.
That was taken out to show mch only with bios 1.2 you should flash to it because it also allows for downward multiplier adjustments.Quote:
Originally Posted by dragonhunter
@Lalaboy
Are you using that Thermaltake Extreme Spirit II NB cooler on your abit board? If so what did you cool the southbridge & mosfet with?
I am on Bios 1.2 and it's still there :confused:Quote:
Are you on the offical 1.2 from abits ftp? For me the voltages after changing to "user define" are cpu memory, & mch. Doesn't say pci-e anyware anymore. Try using the the link above, thats a direct link to abits ftp. I flashed in windows, selected clear cmos data etc.Quote:
quick question guys.
i'm wondering if you could run a presler on these boards. would the circuitry be able to handle the increased load of an overclocked presler?
Looks like i have a "back up" board if rd600 is a total flopQuote:
Originally Posted by Heidfirst
i looked at their site but couldn't find anything regarding support beyond the core architechture.
thanks
I picked to pieces the heatpipe cooling!:)Quote:
http://img399.imageshack.us/img399/4...pem2fu6.th.jpg
anyone running corsair ddr2 6400 with this board?:stick:
my aw9d-max max fsb 445,stable at 440 (mch 1.8v)
http://img.oc.com.tw/281d03/20061022552818233055303.gif
Yes, a lot of it around.Quote:
Originally Posted by Mr.Bones
Great......Think ill order this board tonight:DQuote:
Hi folks
Does the layout of this board mean the PCI slot is useless if i have two gfx cards. Im specifically thinking of using this card.
http://www.xfxforce.com/web/product/...ationId=638442
