Rampage Formula Bios 0403 - No Tested
Heh I not a salesman. Other cheap 2x2gb ddr1000 ram are the G.Skill F2-8000CL5D-4GBPQ which usually can do less than 1050-1066 mhz.
http://www.xtremesystems.org/forums/...163668&page=22
The other one is OCZ Platinum XTC OCZ2P10004GK which I have no idea how it perform with this mobo. Just go to OCZ forum to find out or use the advance search function.
edit : Btw that Mushkin XP2 PC6400 4-4-4-12 has black or white model. Just pick the white one but I think it the same.
Hi guys, I have a question for my pc in sign, how use occt.
When occt is running while I use internet , I get BSOD.
I did many tests about this, but I can't use occt togheter internet connection.
I used occt "alone" and was ok even for 8 hours.
There are only bsod, no code errors.
I don't still understand the cause of this problem, or if it is a problem.
Because I don't know if it is normal use occt while other program running.
Anyone tested 0403 yet?
WIth 0401 i could run my E8400 at 450x9 with 1.35, now with 0403 it wont boot windows. So no go for me......
See, when I ask, nobody answeres, But yes, thats exactly what I just asked a week back.
What is or was your bad experience with OCZ? I'm curious because I have used them w/ everything and always had good results from everything to overvolting to great heat cooling on stock and better with add ons. Now I've only used the Platinums of 2x 1g and 2x 2g on DDR2, looking to try a DDR3 set.
http://www.mushkin.com/doc/products/...ail.asp?id=647 is what you mean?
That's the cheapest kit out of the lot.... ugh.
I've seen a slight increase in bandwidth over 0401 with 0403. I am as close to 0219 as I've gotten yet:
http://i228.photobucket.com/albums/e...Capture-31.jpg
The ram is ok I'm not saying it wont do what they advertise it to do.
There rma policy tho is questionable at best. 7 months and still waiting for my return kit... this and this alone has soured me on OCZ ram... I would never buy from them again because of this. I could go into great detail but this is not the place for it...so that is the short version of my OCZ experience.
regardless of price the redlines are a very good deal for the money, they will hit 1100MHz with no effort but Corsair Dominators would be my first choice then gskill for sure then mushkin
Dominators are out of my price range. So I guess G.Skills is it.
Thanks.
These seem to work well for me on the Maximus, and cheep too!
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Produc...82E16820231145
I'm interested in a 2x 2g kit to hit 1153~1200MHz on 2.22v (@ 1153). Can I see some daily results of G-Skill PC2-8500's to over 1153 to 1200 compared to Crucilas, on same machine if possable? I know my Ballistix can do and hold 1280 for hrs cooled @ 2.34v wich gives me plenty of headroom at loewer 1200. So this is what I'm sort of looking for. I dont want RAM that is stretching for 1150MHz barely. For me , it's not so much the budget as it is more the quality of overclockability.
Hey I just noticed the northbridge of my maximus formula only has two screws in it diagonal from each other with two other empty sockets aren't there supposed to be four screws. It looks to me like they just forgot to install the other two at the factory. Is anyone elses north bridge installed like that.
I never touched mine they just forgot the other two screws the ones in the board are installed Diagonal just like a push pin northbridge cooler would be but the other two holes are empty. WTF I never realized they shouldn't be that way until I look at a review and saw 4 screws. :shocked:
