i have a question: where did you find the bay that keeps place for 5.25"bays.
i can't find anywhere this bay. can you help me please....
i think you're referring to the Lian Li EX-23NB drive bay.
see here for more lian li options : http://www.lian-li.com/v2/en/product...=5&ss_index=12
ok it looks like my coolmax
http://www.abload.de/img/unbenannt-2i0gv.jpg
And don't worry.............more perfectly clean and soulless pics will come soon...............but I've not photoshoped them to death already *gg
Tommy when are we going to see case :)
poparamiro, is your motherboard on a carpet/rug? D:
Tommy I personal love your pictures, I think you show off the pieces of metal amazingly but in a simple way.
Great pics Tommy and popa. Keep up the PC hardware pr0n!
Megahalems with Thermalright fans... priceless. :D
I just bought a few Xilence Red Wing fans for my case/cpu, and I very slightly modified one of my case fans so that there would be a colour theme :yepp:
Xilence Red Wing 120mm x6 (using only 5 at the moment)
http://i293.photobucket.com/albums/m...Rhys/Stack.jpg
Antec 900 top 200mm tricool fan painted with two coats of cadmium red acrylic:
http://i293.photobucket.com/albums/m...s/200mmtop.jpg
http://i293.photobucket.com/albums/m...00mmbottom.jpg
Installed and showing push/pull on black TRUE:
http://i293.photobucket.com/albums/m...hys/Inside.jpg
http://i293.photobucket.com/albums/m...nyRhys/Top.jpg
I much prefer this to the blue LED fans, which I have had for 2 years now :D
http://i293.photobucket.com/albums/m...s/Outside1.jpg
For those of you not familiar with these fans:
The fan speed varies from 1300 to 1400; three of the five fans are at 1350rpm, one at 1300, and one at 1400. All of them are plugged into motherboard 3-pin headers, so I was able to remove a molex cable from my PSU, making the case a lot less cluttered. Fab. :up:
The fan motors are inaudible but there is A LOT of air moving through the case now, much more than there was with my tricool fans. These fans move about as much air as the tricool fans did at the medium setting (pretty loud), so mission accomplished. Motherboard/chipset and CPU temps have dropped substantially. :up:
The Red Wing push/pull config on the TRUE is absolutely awesome; they move a lot of air and they are so quiet. My CPU temps are the same as they were with the noisy Sliverstone FM122, almost double the speed at 2500rpm.
TT ultra 120 Extreme lapped and washer mod with dual 120mm SanAce Fans
http://img41.imageshack.us/img41/1624/1001638m.jpg
Lenny nice job painting the blades there looks really good.
AT Volkswagen really clean job good looking rig.
Thanks HuffPCair- I gotta sleve the fan wires off the SanAces and it will be even better :)
Xigmatek's XLF-F1253 would be better:up:XLF-F1253 is very nice fan, but it is more expensive than Xilence Red WingQuote:
Originally Posted by LennyRhys
http://i556.photobucket.com/albums/s...o/DSCN0137.jpg
http://i556.photobucket.com/albums/s...o/DSCN0136.jpg
http://i556.photobucket.com/albums/s...o/DSCN0135.jpg
http://i556.photobucket.com/albums/s...o/DSCN0132.jpg
http://i556.photobucket.com/albums/s...o/DSCN0133.jpg
http://i556.photobucket.com/albums/s...o/DSCN0131.jpg
http://i556.photobucket.com/albums/s...o/DSCN0140.jpg
Great mod! Looks like a P150/Solo upside down? How did you do that?
i've just fully disassembled the case then coat painted it and then finally remounted it in i-atx configuration :) (there are also a few minor changes like window, top ventilation hole, pwr/reset buttons and more to come, for example i will try to turn out the psu too - so it would be able to take clean and fresh air from outside)
sweet case!!
kvadzio: great job, i love your work ... this pink screws are AWESOME :) You are my number one dude ;)
FTF! Kva you're mine hero :hump:
