Nice Build Kevintrisha!! I'm saving up for a MM's case. Bu ti do love the look of Lian li cases
zipties ftw ;)
nice rig, you gave me an idea...
i have hard time fitting tripple and dualrad + 2*pump into case ~40x40x20cm
Kevin: what a great and creative job packing it all in. How is the PA120.3 mounted in the front of the case...is it secured with screws into the fan?
-alex
i have 2 triple rads in my v2000
not huge thermochill's though they take up 2 much space... my rig is in my sig if you wanna see it...
cheers
http://www.xtremesystems.org/forums/...1&d=1192431460
um... what's with the brass knuckles?
it's a paperweight.. i have some too. :D
don't be jealous that I've been chatting online with babes all day. Besides, we both know that I'm training to be a cage fighter.
I used the radiator brackets normally used for the Lian Li 343B case to mount the thermochill into the front of my PC-V2000. All I had to do was cut a square hole in the divider and line it with the black vehicle door edge guard. It all went together with screws after that. The bottom radiator required the standard cut of three 120mm holes in the bottom of the case.
The only issue you get from this mod is a small amount of heat that blows out the front and bottom of the case. I have the rear fan blowing in for cool air. I am going to add two 80mm fans blowing in below the PSU for air flow. So far it is almost inaudible.
Kevin
I forgot.....I also replaced all of the solid drive covers with the covers that have the holes in them. It gives it an even look and allows for the front air flow. I wanted that APPLE CASE look with all the holes anyway.
Kevin
Yes the brass knuckles are paper weights. I just thought they looked neat. I did not mean for those to be in the picture.
Kevin
LOL . . .yesterday I was having lunch and happened to have a UFC shirt a friend got me from UFC 76 (I got him and his wife tickets for their honeymoon) some dork asked if I was involved with the UFC . . .I told him I am a cage fighter in training . . .dude clearly never watched Napoleaon Dynomite . . .
http://img.photobucket.com/albums/v1...7;20500/03.jpg
http://img.photobucket.com/albums/v1...s%20500/07.jpg
http://img.photobucket.com/albums/v1...s2meters01.jpg
http://img.photobucket.com/albums/v1...s2meters03.jpg
http://img.photobucket.com/albums/v1...s2meters04.jpg
http://img.photobucket.com/albums/v1...s%20500/11.jpg
im guessing you used 4 light strips from ikea to light that?
hey megadethcl, what tubing is the cpu loop? tygon 2705?
NicePants42,
I love your setup and tj07! lookin' good my friend :D
Can't wait to order some new WC stuff...
Hey Mega what exactly are the devices inline after the pumps? Flowmeters? Where'd they come from?
That's a lot of LCS in a small case! Nice work. I see you also appreciate a good DVD burner :)
Read all about it in this thread.
And yeah, that Plextor burner kicks ass.
MegadetHCl, how do you do CMOS or change memoryes?:p:
:up:
i made a little video of my sys, you may have a look :) :
http://www.youtube.com/watch?v=ofEWhTqjh5o
