kool
kool
I love that tach, amazing idea.
C'DaleRider what tubes u use ? I see bend on CPU-NB tube....
Very nice. Good attention to detail!
I have a single device and 2 device silver round cables I'm not using if you're interested. I think it would look better in place of that blue ribbon cable.
If you're interested, PM me, I'll send one to you no charge.
nice system C'DaleRider
Here's mine. I'm not quite done yet, but the inside is close.
iadstudio, what NB cooling are you using?
The tubing is Tygon 3603 in 3/8" ID-1/2" OD. No matter how I tried to lengthen or shorten the tubing, it always developed a kink, so I put a ziptie where it kinks....about 99% is gone now and really doesn't seem to be hurting my temps.
I'm getting high 50's at load (a Xeon X3210 OC'd to 3.4GHz) and mid-to-upper 30's at idle. I'll take those temps.
I guess the solution is to run the tubing from the upper barb on the cpu block to the NB block, but hate to drain it right now. Probably will get to it eventually, though.
My VERY ugly p180b Build:
http://photos-d.ak.facebook.com/phot...15267_8945.jpg
http://photos-b.ak.facebook.com/phot...15265_8330.jpg
Sorry for the poor quality. I only have a camera phone at the moment.
This is my first build and it was completed over a period of months. I had to keep buying parts b/c I basically forgot what I need for a build, lol. I haven't build a computer since 05 and I had most of the parts on hand and most of it was recycled.
I know its VERY ugly inside. It was originally a very clean build, but as I kept adding stuff, I figured I'd just let the inside go to hell b/c I didn't feel like making it look pretty, especially considering the side of the case stays on 24/7. Its a nice case, but cramped for water cooling, especially w/ a large pump. The only positive about having such a large rad and high performance pump is that I can run prime 95 24/7 w/o turning the fans up and the CPU never reaches a critical temp limit. My house is around 72*F usually, although my room is between 72 and 74*F.
BTW, I do have 3 fans on the radiator. I was waiting for another 2 in the mail at that point.
The more useful it is, the uglier its allowed to be. Theres an equation for it I'm sure.
@Synthetickiller are you using HDR in your photos?hehehe:)
I wish I knew what HDR is. If I did, I'd probably find it funny. Ignorance sucks.
I used a camera phone and a camera spot light to take those pictures. :D
i think he's talking about high dynamic range...?
Thats only one aspect of it. The other really big one is in photography.
System update..
New pump new blok new rad new tubes new Reservoir
Old System
Aqua Cuplex XT Blok-Aqua Airplex 360 Rad- Eheim 1000l pump- 1/4 tube
http://img73.imageshack.us/img73/356...d174sd7.th.jpghttp://img73.imageshack.us/img73/756...d177na1.th.jpg
New System
Swiftech Apogee GTX Extreme | Swiftech MCR-320 Radiator | Swiftech MCP655-B Pump | EK-RES200 Reservoir
http://img230.imageshack.us/img230/3...h001mr6.th.jpghttp://img230.imageshack.us/img230/2...h007tz5.th.jpghttp://img250.imageshack.us/img250/7...h010cj2.th.jpghttp://img250.imageshack.us/img250/2...h022nq9.th.jpg
http://img47.imageshack.us/img47/651...g036vj5.th.jpghttp://img509.imageshack.us/img509/2...g025tj5.th.jpghttp://img265.imageshack.us/img265/6...g031fj8.th.jpghttp://img509.imageshack.us/img509/7...g034in2.th.jpg
http://img47.imageshack.us/img47/915...g041qn0.th.jpghttp://img253.imageshack.us/img253/4...g046vw4.th.jpghttp://img253.imageshack.us/img253/8...g050fg9.th.jpghttp://img61.imageshack.us/img61/780...g053ol9.th.jpghttp://img146.imageshack.us/img146/7...g055gb0.th.jpg
http://img61.imageshack.us/img61/931...g059vl6.th.jpghttp://img146.imageshack.us/img146/7...g066nt4.th.jpghttp://img61.imageshack.us/img61/332...g074fk4.th.jpghttp://img146.imageshack.us/img146/7...g076tn1.th.jpghttp://img146.imageshack.us/img146/6...g082qx5.th.jpg
what you think ?
Looks great!
PS: It's Reservoir. Not "Rezervuar" ROFL! :p:
thx ;)
Looks too much air bubbles in water...
I'm guessing that you don't travel too often with that case? lol
